Weird rear brake issue... Help!
Old Aug 26, 2010 | 05:24 AM
shifter's Avatar
Well my 5.5 has been making some very weird issues in regards to the rear brakes the last week or so but got very bad last night. When driving in reverse the rear brakes make a LOUD screeching noise when im not touching the brakes (goes away when i touch the brakes). Then when i drive forward you can hear the pads rubbing on the disc (but no screeching or anything). When the wheel is off the brakes spin freely once i compress the piston in on the caliper. However as soon as i hit the brakes it drags the pads.
I went ahead and did a full brake job on it, pads, rotors and even went so far as to replace the calipers with rebuilt ones as the old ones did not want to compress very easily anymore. While doing this I bled the rear brakes and even disconnected the parking brake entirely from the rear calipers (i was thinking this was the problem possibly).
Even after doing all of this... the problem STILL arrises. Nothing has changed after 300 dollars in new brake parts
HELP!!!!!
Old Aug 26, 2010 | 10:47 AM
vinco's Avatar
How are you "compressing the piston in on the caliper"? You do know that you can't just push it in to retract it, don't you? You have to turn it clockwise while pressing. The cube tool they sell at parts stores is worth 10 times the asking price for doing this.
Did you clean and lubricate all the moving parts, retainer bolt sliders, pad sliders, stainless steel clips, etc? If any of them are gummed up, then it will tend to hang up/stick.
Good, not cheap, pads are a must. I like ceramics for DD/street use.
Outside possibility is a sticking master cylinder.
My 2K used to groan horribly in the back brakes while backing up, but never while going forward. I never really got it solved before selling the car.
Old Aug 26, 2010 | 11:08 AM
TallTom's Avatar
Check to see if you have a sticking e-brake cable.
Old Aug 26, 2010 | 11:11 AM
shifter's Avatar
Yep I compressed them while turning clockwise using the appropriate tool.
All parts are adiquately lubricated with new sliders.
Pads are ceramics
Im starting to think it is either a colapsing brake line or the master cylinder. Im probably just going to order both.
Old Aug 26, 2010 | 11:12 AM
shifter's Avatar
As I mentioned previously, the e-brake cable is completely disconnected from the rear calipers at this time.... doing so yielded no change in the issue. However I left it disconnected.
I was sure hoping it was the e-brake cable tho. a
Old Aug 26, 2010 | 12:03 PM
TallTom's Avatar
Doh! That's what I get for reading with a headache.
After popping 2 excederins, I googled and noticed that deteriorated brake lines can cause the same issue. I would order them first since they are cheaper. And flush the fluid.
Old Aug 26, 2010 | 12:18 PM
shifter's Avatar
Haha thatll happen... good thing excedrin is some decent stuff I couldnt live with out it.
Yeah i think thats the plan, rock auto has them for 9 bucks each... so im just gonna replace both rear lines and do a full bleed with new fluid and hope it works.
Old Aug 26, 2010 | 12:27 PM
shifter's Avatar
Ordered two rear brake lines from rock auto..... $9 bucks a pop! not too shabby.
I hope this fixes it. Guess she'll be out of commission for a few days until the parts show up. Oh well.
Old Aug 26, 2010 | 01:36 PM
TallTom's Avatar
It should be drivable. It's not like the pads are clamping down hard. Just don't drive cross country like that.
Old Aug 26, 2010 | 01:54 PM
TallTom's Avatar
OK, I'm not losing my mind. I honestly thought I replied to this earlier in the day. Turns out you have the same thread on OT.
Old Aug 27, 2010 | 05:58 AM
shifter's Avatar
HAHAHA thats pretty funny actually. Yep, posted it on OT first actually. 5speedSER over there.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
Jcof88
Aug 3, 2015 10:43 PM
