horriable sound coming from rear of the car, help!
Old Sep 4, 2010 | 02:44 PM
soto2635's Avatar
i got this sound coming from the back of the car it only really becomes loud when im on going around 60mph, i check the exhaust thinking i had a leak some where but its all good sounds air coming into the trunk through the drain holes if i shut them you guys think the sound will go away?
Old Sep 4, 2010 | 02:54 PM
Mr. Brett's Avatar
Be more specific? What kind of sound?
Maybe try recording the sound...
Old Sep 4, 2010 | 03:55 PM
soto2635's Avatar
is like a humming sound
Old Sep 4, 2010 | 05:08 PM
DennisMik's Avatar
You could have tire noise (also called road noise). It can happen when you get a tire with a tread design that isn't compatible with the pavement surface. Can also happen when a tire starts to wear out.
Old Sep 4, 2010 | 05:39 PM
fflint_18's Avatar
Dennis is right
Look at the outside edges of your tires. If they are not all a uniform shape your tires are cupped.
Cupped tires will give you a heck of a hum at speed.
It's why big 4X4's have so much tire noise. The big outer ***** on their cause a horrific hum.
Or you could have a rear wheel bearing issue. They sometimes get worse at speed.
Old Sep 4, 2010 | 05:55 PM
maxpilot53's Avatar
I agree! Could be too many things. Be very specific or record a clip.
Old Sep 4, 2010 | 06:26 PM
soto2635's Avatar
Originally Posted by fflint_18
Dennis is right
my tires are starting to bald at the other part
Old Sep 4, 2010 | 06:27 PM
soto2635's Avatar
Dennis is right
ima try to record a clip
Old Sep 4, 2010 | 06:28 PM
soto2635's Avatar
i plugged up the darin hole still making that noise
Old Sep 5, 2010 | 11:23 AM
DennisMik's Avatar
Plugging the drain hole is only going to maybe reduce how loud the noise is, not stop it. If you know somebody with a Maxima that you can swap tires with and do a test drive, do it and either prove or eliminate tire noise as your problem. The test tires don't have to be the same size as yours, just different tires.
Old Sep 5, 2010 | 01:44 PM
soto2635's Avatar
true i got a buddy who has an extra set of maxima rims
Old Sep 6, 2010 | 01:13 PM
ed_maxima14's Avatar
catalic converter not connected fully......
Old Sep 6, 2010 | 01:24 PM
Rods03Max619's Avatar
Yeah I would saay try that or check all the piping!!
Old Sep 6, 2010 | 05:41 PM
Lemonhawk's Avatar
I had a very loud noise at 75 show up. Turned out to be the plastic wind guard for the sunroof! Sounded like the tread coming off the tire and hitting the fender!
Old Sep 6, 2010 | 11:43 PM
DennisMik's Avatar
I had a 94 Max that did that. Scared the s**t out of me the first time.
Old Sep 7, 2010 | 03:07 AM
bob-lee's Avatar
try lowering the tyre pressure to about 26 psi and see if the problem stops if it does it's time for a tyre change
Old Sep 7, 2010 | 01:42 PM
J-Rod's Avatar
I vote wheel bearing.
Reason sound only produces at higher speed. Lower speed would still give you the tire and/ road noise. Another posters comparision of 4x4 tires with passenger tires is far from an equal comparision.
I would start with the cheaper things first. Tire wear, balance of wheel, correct psi, swapping wheel and tire (they don't have to be maxima wheels and tires just get same size like 235/45/17r with a similiar 235/45/17, then if no find... look at bearing. They will go out over time and if you are lowered sooner than later. They are about 60.00 at the dealer and are simple swap out in the driveway.
Old Sep 7, 2010 | 02:45 PM
fflint_18's Avatar
Not that it matters, but I wasn't comparing the sound to a 4X4.
I said if the tires got cupped you can get the sound because of uneven rubber surfaces.
It's why big 4X4's have so much tire noise. The big outer ***** on their tires cause a horrific hum.
I also suggested that it may be a bearing.
Lakersallday24
Jun 16, 2019 01:35 AM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
