(PICS) ABS light on and Speedo and odometer not working after clutch change
Old Sep 27, 2010 | 08:47 PM
malifat's Avatar
im having problems guys. and im on the verge of giving up as winter is starting to set in. when i bought my 2000 SE maxima 5spd the clutch was on its way out and when it finally died on me i decided to change the clutch myself. the change out went pretty smooth, wheni started it up for the first time with the new clutch my abs light was on and my speedo and odometer are no longer working .
I had to move the above ABS actuator/motor in order to get the starter out to drop the gearbox. because i disconnected the ABS harness could that be a cause for my speedo and abs light coming on ? and if so how would i rest or solve this issue.
From reading other threads i got the idea that it might be my speedo gear . the car is throwing a p0500 code VSS . the pic above is the connector that attached to the sensor at the bottom on the gearbox below
so yea no gear there. look like there are some internal parts that transfer signals to this wire. im hoping there is nothing wrong with the internal parts because i do not want to open the gear box plus i never opened it before i am thinking that i may have damaged the external wire when the bell housing was on the floor or in the back of my truck.
what do u think guys ? i could really use your help its getting cold and i need to fix this problem asap
thanks alot
malifat
Old Sep 27, 2010 | 09:07 PM
nelledge's Avatar
"I'm just sayin'..."
The sensor at the bottom of the gearbox with the wiring harness is the position sensor. You can get one from DaveB for like 30 bucks. I had to replace mine because I snapped the plastic ear when reinstalling(I didn't have it completely flush).
I think, however, that you should be looking at what Nissan calls the 'speedometer pinion'. Looks like there are two different styles: Probably run you about 15-25 dollars for oem. You may want to locate it and make sure no pins got broken or bent and that it is plugged in correctly.
Old Sep 27, 2010 | 10:19 PM
zero2sixtyZ's Avatar
You embarrass me.
What do I think? I think you're a jackass for bull****ting your first 15 posts.
Old Sep 27, 2010 | 11:00 PM
malifat's Avatar
now now.. no need for name calling big man. i just got the car dont have much info to help other yet and i needed to get this post out before it snows ( im in edmonton Canada) sorry if i hurt your feelings , ill make my contribution
Old Sep 28, 2010 | 05:03 PM
malifat's Avatar
got it sorted out . went over all the electrical connections disconnected and reconnected all the harness and sensors and bingo . thanks for your help nelledge
Old Sep 28, 2010 | 08:14 PM
nelledge's Avatar
Of course, you're welcome. I'm happy it was an easy fix for you.
Dennis Twohy
Oct 1, 2015 06:01 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
jholley
Aug 11, 2015 09:38 AM
kenc15
Aug 5, 2015 08:29 AM
RealityCheck
Aug 5, 2015 06:18 AM
