finally installed jwt flywheel now starter issue
Old Oct 17, 2010 | 06:59 PM
blkbat_77's Avatar
ok guys so i finally installed my lightweight jwt flywheel and long story short when i turn the key to start it, nothing happens no crank no click but if i manually jump the starter with a screwdriver touching the power connected to the starter and the metal peice on the solenoid thats connected to the wire i can crank the car. so basically i have to have someone push in the clutch and turn the key as if i was trying to start the car and manually jump the starter and it will turn on
got a new starter thnking that the starter and/or power wire for the starter was bad but new starter and same issue??
any ideas?
did research and found out possibly the new flywheel may not line up with the crank shaft position sensor if so how can i go about fixing this??
Old Oct 17, 2010 | 07:23 PM
NiZMo1o1's Avatar
theres a clutch switch on the pedal , did you check for that ?
Old Oct 17, 2010 | 10:26 PM
blkbat_77's Avatar
Well kinda I saw the switch nd the pedal def pushes it in and I held it down with my finger and tried to start it with still nothing idk how about knowing if the switch is good or bad though
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
maxinout93
Aug 16, 2015 07:25 PM
