ANyone upgrade their horn?
Old Oct 29, 2010 | 06:35 PM
  #81
Rochester's Avatar
The first time I ever looked at my horns was this Fall. And Yikes! That's nasty.
Old Oct 29, 2010 | 06:39 PM
  #82
Rochester's Avatar
Originally Posted by knight_yyz
Hey John, are they plastic or metal?
You know, I'm not sure. Certainly the cowl over the horn is plastic.
The more I look at it, the answer is both plastic and metal.
Originally Posted by Ghost_54
Somehow I just knew you would be John, as you are quite correct in saying just how wimpy the OEM horn is on our cars. Every-time I have to use my horn I think that I am riding on a scooter because it just sucks ... Now the sound from those sport PIAA's is very decent.
Now that I hear the PIAA 400/500 from my own car, in person... I am seriously happy with this little mod. In fact, I feel a little awkward never doing anything about it until now.
Old Oct 29, 2010 | 06:48 PM
  #83
trooplewis's Avatar
Yeah, will don't get carried away with tooting your own horn...
Guess it's good I brought this topic up to start with
Old Oct 29, 2010 | 06:53 PM
  #84
Crusher103's Avatar
Originally Posted by sascuderi
You guys got me wondering what the stock horns in the I30 look like.
Went out to the garage to take a look. Instead of the flat disc horn they actually look like the PIAA horns and sound like this:
http://www.youtube.com/watch?v=-fPynR9eUmQ
my horns arent that loud.....or maybe i never stood outside the car to find out......
Old Oct 29, 2010 | 07:33 PM
  #85
Maxgig's Avatar
I bought a pair of hella horns from ebay for $37 bucks. I put them on today and they sound hella better than stock. I did a search and found out how to remove the center piece of the grill, (3 screws and 4 push tabs). It made the job much quicker since I have big hands. I didn't use the hella relay and I had to make a ground wire for the left side other than that they work fine.
Old Oct 29, 2010 | 08:46 PM
  #86
Rochester's Avatar
How did the install go, were you able to mount them as you desired?
I can get the grill on and off again now with my eyes closed. And actually, when I put it all back together this evening, I left the center bolt alone. The two end-bolts and all the clips are plenty to keep the grill in securely. Which is good, because the center bolt is a pain.
The driver-side horn unbolted right away (after some penetrating oil on those rusty M8x20mm bolts.) The passenger side, however, it took a bit before I realized I could just bend this black bracket out of the way. (It's the bracket for the wiring harness on the front airbag impact sensor.)
I intended to use the same holes, and that's not a problem for the passenger side. But on the driver side, the bracket lip gets in the way. No need to dremel that out, just grab some pliers and bend it flat.
Also on the driver side, the power cord doesn't quite reach. So get out the scissors and free up the cable from the main wiring harness. There's a good extra 2 inches of play, and it's just enough.
The power connectors clip right on to the horns nice and secure. Then use the two grounding cables that come with the kit to ground each, using a grounding point that's already being tapped by something else. I don't know what that is, but there's a wire grounded to the hood latch bracket. So that's what I used.
And you're done.
Perfect job? Um, no way. There's all kind of rusty hardware involved, but less than I started with. I replaced all the affected hardware with stainless steel parts from Lowes.
Does it look good? Meh. I'm not overly proud of it. But then again, it looks better than what was there, and as long as I have that OEM grill, you can't see much of anything, even if you try. So I'm actually OK with this as-is. It's a horn, you hear it, you don't look at it.
The best tip I can share about installing these PIAA horns is not to be shy about bending things. Go right ahead and bend the wings on the hood latch bracket, and the wire harness bracket on the airbag impact sensor, and the extension brackets on the new horns themselves. Push things around so you can get access, and position the horns the way you want.
Here's a picture after the install. Nothing to look at, but here it is none-the-less.
And one close-up:
Old Oct 29, 2010 | 10:29 PM
  #87
trooplewis's Avatar
Glad installing the PIAA was not a PITA
Looks good, and like you said, sounds way better!
My condensor has WAY more bugs smashed into it than yours does. Did you detail that as well?
Old Oct 30, 2010 | 06:55 AM
  #88
Rochester's Avatar
Thanks, Troop. It was more of a PITA than I thought it would be, but less than it could have been once you realize it's OK to start bending things to fit.
I think I might turn the horn back on with the key-fob lock, just for a while until it becomes normal and annoying again.
About my AC condenser... beats me, man. I haven't touched it. Ever.
Old Oct 30, 2010 | 08:58 AM
  #89
Eirik's Avatar
Hmmm... Is there any way to just double the horns, double the fun? I think the Maxima horn would sound better if it were louder. Maybe. But I'm guessing their just isn't enough room to fit in another pair?
The only downside to that "Superior Bass" horn is that the lower the frequency, the harder it is to pinpoint the source of the sound. Higher pitches and, thus, shorter wavelengths would be more immediately identified as "Woah... I think there's a dude right next to me that I'm currently running off the road." Now, whether "more immediately" is defined as 500ms faster or just 5ms faster, I don't know.
Old Oct 30, 2010 | 09:59 AM
  #90
VQP0WER's Avatar
All this horn talk made me just order my set of PIAA 500/600mhz horns. Can't wait! HA!
Old Oct 30, 2010 | 12:12 PM
  #91
Rochester's Avatar
You could, but you should probably wire a new relay into the circuit because of the added hardware. Either way, this is what you get when you double-up the OEM horn:
Old Oct 31, 2010 | 01:02 AM
  #92
kbohip's Avatar
HO.....ly Cow! When I took my crappy stock horns off last year they were still coated in the factory green paint, complete with stock numbers in case any of you want to re-order these wonderful things. Have I ever mentioned I HATE salt?
Old Nov 1, 2010 | 06:00 AM
  #93
Rochester's Avatar
I've come to the (unmeasured) conclusion that these PIAA horns aren't really any more or less loud than the OEM horns. They just sound more appealing... which isn't necessarily a good thing in a horn, from a purposeful point of view.
Of course, I'm still keeping them, but I thought that opinion was worth mentioning.
Old Nov 1, 2010 | 07:57 AM
  #94
trooplewis's Avatar
Rochester, that's pretty interesting. Everyone seems to think that they are much louder than the stock "beep beep" horns, maybe it is just the different tone they are hearing.
I've got a set of 400/500 PIAA's ordered from Amazon, should be here in a couple of days.
Old Nov 1, 2010 | 08:12 AM
  #95
Rochester's Avatar
I know, it doesn't seem to fly with the consensus opinion. Troop, I'm entirely deaf in one ear, so I hear the world in mono. I understand what stereo is, but only in the academic sense. That might have something to do with it. IDK.
By all means, post your opinions when you get the PIAA's installed. Remember for the installation, it's OK to bend things.
Old Nov 1, 2010 | 09:26 AM
  #96
Crusher103's Avatar
this is interesting imma go check out NCSU_MAX horns on his 4th gen to see if they are the same compared to mine.
Old Nov 1, 2010 | 03:36 PM
  #97
TallTom's Avatar
I ordered my 500/600 set last night on Amazon. Hope to install them this weekend sometime. I may try to reuse the bracket that Rochester has attached this his rusty OEM horns so they are pointing downward.
Old Nov 1, 2010 | 04:17 PM
  #98
Rochester's Avatar
My driver side PIAA horn is in the 5:00 position. The passenger side is in the 8:00 position. Both are bent a little towards the AC condenser so the horns don't touch the front piece.
It's not perfect. Not sure if it has to be.
Let's see what you guys come up with.
Old Nov 1, 2010 | 06:47 PM
  #99
TallTom's Avatar
It doesn't have to be perfect. I'm not even sure what I will do with the install until I get that grill off.
Old Nov 1, 2010 | 06:56 PM
  #100
Rochester's Avatar
Even though I scoped it out with the grill off about a week before installing the horns, it still didn't quite work out as easy as I thought it would. Bend, stretch, uneven orientation, etc.
I'm really curious to hear what you do. I've been rattling around the idea of creating an extension piece to better position the horns... but I'd have to find something to work, drill some holes, buy extra SS hardware, paint the bracket, and basically invest a whole extra day into this thing when it probably doesn't matter. IDK.
Old Nov 1, 2010 | 08:12 PM
  #101
kbohip's Avatar
Ugh, you and I have something crappy in common it seems. I'm deaf in the left ear. Of course I DO have a really annoying ringing that emanates from that ear 100% of the time so I've got that going for me. One good thing is I don't worry about spending any money on an expensive sound system for my home theater. It's all display for me.
I'm thinking of ordering these same horns tomorrow Rochester. I can't decide between the 400/500's or the 500/600's though. I like the lower tone though so I'll probably go with the formers.
Old Nov 1, 2010 | 08:15 PM
  #102
trooplewis's Avatar
LOL, you guys remind me of the cop in Wild Hogs who was deaf in one ear, people kept talking bad about him as long as they were on the deaf side...
Old Nov 1, 2010 | 08:29 PM
  #103
jowo9's Avatar
Wow John, you're the master of macro photos. That picture of the rusty horns is almost artistic. You should get a really big print, frame it, and hang it in your garage. Not sure why... it's just a really nice picture is all
Old Nov 1, 2010 | 08:43 PM
  #104
TallTom's Avatar
Can't you just reuse the plates that are still attached to the old horns? That's what I was going to look into.
Old Nov 1, 2010 | 08:45 PM
  #105
TallTom's Avatar
Originally Posted by kbohip
Ugh, you and I have something crappy in common it seems. I'm deaf in the left ear. Of course I DO have a really annoying ringing that emanates from that ear 100% of the time so I've got that going for me. .
My stepmpm has the same thing but buzzing instead of ringing and she has the strongest hearing aid you can get in the other ear.
My sister got her into a special program at University of Penn for cochlear implant for the deaf side and it went really well. Maybe you and John could look into that.
Old Nov 2, 2010 | 05:42 AM
  #106
Rochester's Avatar
Re-use what, exactly? Remember this photo?
I'm just going to wait and see what you guys do before or if I do anything further.
As to all the deaf-in-one-ear talk... yeah, I've probably saved a bundle on stereo equipment, LOL! And it's really easy to go to sleep at night. But I still think I'd rather hear in both ears. Had some re-constructive surgery 15 years ago, and for about one month I could hear normal. It really freaked me out, then slowly faded away. Maybe someday I'll try again.
Old Nov 2, 2010 | 09:16 AM
  #107
mandyfig's Avatar
Tell you what, I get decent respect when they hear my horns now.
Old Nov 2, 2010 | 09:17 AM
  #108
mandyfig's Avatar
No longer the beep beep. Now it is hump hump, or is it?
Old Nov 2, 2010 | 09:27 AM
  #109
trooplewis's Avatar
Which horns did you install?
Old Nov 2, 2010 | 11:52 AM
  #110
Rochester's Avatar
Here's the cross-reference:
http://forums.maxima.org/5th-generat...grade-diy.html
Old Nov 2, 2010 | 05:02 PM
  #111
Clashez's Avatar
All this horn talk can make a man kind of...... horny
Thinking about upgrading mine
Old Nov 2, 2010 | 08:22 PM
  #112
jaxter09's Avatar
agree with clashez1983 i had never thought bout replacing my horns but just looking at this thread new louder horns really sound like a nice upgrade
Old Nov 2, 2010 | 09:04 PM
  #113
Majestic Ken's Avatar
i cant decide which ones i want, youtube doesnt help at all either. they say most vehicles come stock 400/500 hz these days. but i see that 500/600 is the loudest but also sounds sissy-ish loud. which ones should i get. i want something loud (besides annoying train horns) thats says GTF outta my way. 400/500 or 500/600hz
Old Nov 2, 2010 | 09:07 PM
  #114
gixxer_751's Avatar
crazy
Old Nov 3, 2010 | 05:45 PM
  #115
TallTom's Avatar
And you're done.
And one close-up:
OK, I got tired of staring at them when I get home from work so I took a crack at installing them in the driveway as the sun was setting. I didn't take the grill off but probably should.
I mounted them with the brackets that the OEM horns attach to. When pointing down, they rub against the front side which I wasn't happy with, so I have them mounted with the horns pointing to the sides. My new position is better but I'm still not thrilled with it. I think Rochester has the best idea. Mount them where he did (and not use the plates like I did), but point the horns outto the sides. This way, the sound pierces through the grill.
And I agree with Rochester in another post of his, I don't think they sound louder. Just a different pitch.
Old Nov 3, 2010 | 05:58 PM
  #116
Rochester's Avatar
Way to go, Tom. It seems like such a simple thing to do, really. But the reality is that you have to be creative and patient.
So in the final analysis, are you glad you bought them?
Old Nov 3, 2010 | 06:04 PM
  #117
TallTom's Avatar
Yeah, I'm happy with them, but will redo them this weekend. I will need to pop the grill off to get to do what I want. I cannot get a socket to the bolt on the left side that you have your horn connected to. I can easily do the right side with the grill on.
Old Nov 3, 2010 | 06:24 PM
  #118
Kountz430's Avatar
bald aggression est 78
and heres one for a good laugh its http://www.youtube.com/watch?v=YnPE6nGXVqE
Old Nov 3, 2010 | 07:17 PM
  #119
Rochester's Avatar
You can if you remove the grill and gently bend the wire harness bracket out of the way. And once you remove the grill, you'll realize how easy it is to take on & off, and then you'll wonder why you didn't do that in the first place.
BTW, that wire harness is for your front airbag impact sensor. With that in mind, you might want to disconnect the battery before banging around there with a socket wrench. It probably doesn't matter, but still...
Old Nov 3, 2010 | 07:38 PM
  #120
trooplewis's Avatar
Crap yes, that would be an expensive mistake. About $2000 total if I remember.
Think the airbags would deploy without the key being in the ignition and the ignition in the "on" position?
