SSIM (pics), AFR.. whole smorgashboard
Old Nov 5, 2010 | 08:44 PM
jeff5347's Avatar
So in the last month i have Re-SSIM'd the UIM, gutted the pre-cats, installed a new 04 rear VC and fixed my oil catch can.
Had the oil in #5 so did the rear VC. I havent taken the UIM off since to check if it fixed the problem but im assuming and hoping thats all set.
I gutted the pre-cats hoping to fix an erratic WB but it doesnt seemed to have helped. I can say the exhaust not became a little louder but also a more deeper aggressive sound. Gutting the rear Pre-cat was a b!t$h and thats putting it lightly.
I had SSIM'd the UM before but didnt have a grinder that was long enough to get inside and clean it nice and smooth. So i went to Harbor Freight and bought
It was 30 bucks and i figured it would do the job, but i can say for 30 bucks it exceeded my expectations. I had 4 different carbide burrs to get the results i needed. I will post pics of the SSIM i did tomorrow sometime.
This is a question i have that im assuming involves all the stuff i did and NMexMAx helped me before and maybe he can this time or if anyone else knows.
My AFR while driving fluctuates quite a bit. Coming to work tonight and being at a steady 2500 rpm the gauge will swing from 13.8-15.2. Just like a pendulum and will do this roughly 3X in 1 sec if im under a light load. If im just cruising and not really in the throttle it doesnt fluc to bad. But gewt in the gas and it swings like Tarzan on a busy day. Is this normal or is something kinda iffy?
Old Nov 5, 2010 | 09:46 PM
maxima dude's Avatar
sounds like ur sensor is crappin out... but thats me guessing...did u try the 'test; for the wideband sensor to see if its bad or not?
Old Nov 5, 2010 | 09:47 PM
MoncefA33's Avatar
My AFR does that at part-throttle, cruise, and slow acceleration.
What's your AFR doing at WOT? It should stay still.
Old Nov 5, 2010 | 10:14 PM
jeff5347's Avatar
The test? I dont know what one that would be
Actually have not had a chance to do a WOT run to see whats going on. I live 1/4 mile from the police station so that is a big no no and i dont have to many straights that wouldnt attract attention. I will try it going home in the morning to see idf i can get a read. Only other place i can try is getting on the hiway....i can try then. I made a bracke tot attach my Cam corder to so i can Rec my run and view while not trying to shift or run into anyones rearend ..
Old Nov 5, 2010 | 10:21 PM
MoncefA33's Avatar
Just jump on the pedal WOT for like 2 seconds and the wideband will respond and settle down.
Old Nov 5, 2010 | 10:26 PM
jeff5347's Avatar
I can say i havent done the WOT run yet but i do get in it hard sometimes (70-80 th) and i never see it get in the 12s or 13. Scratch that maybe a 13.7 or higher but not lower. From what ive read we go closed or open ..cant remember and it goes into the 12s. Should i see that
PS.. Ok i looked on youtube and saw the test you can do. Ill try that tomorrow and see in that does anything and report back on it BTW, i did buy it used and from what i remember the guy said it was in hs Civic racecar (isnt that and oxymoron) and it had about 5000 miles on it.
Old Nov 5, 2010 | 11:52 PM
NmexMAX's Avatar
dot dot dot ...
Log a WOT run and post it. If it is 12.0 - 13.7, you're fine, IMO.
Old Nov 6, 2010 | 05:12 AM
http://www.youtube.com/watch?v=1mb4VmDd0ao
Old Nov 8, 2010 | 10:10 AM
jeff5347's Avatar
Ok so here are the pics of the updated SSIM i did. Also Nmex just to let you know going home the other day got WOT for like 2 secs and i did see it reading 12-13 in the AFR.
Enjoy the pics. You can go to my cardomain site to see all the pics.
http://www.cardomain.com/ride/254781...ter-ma-us?p=12
Here are some teasers.
Old Dec 5, 2010 | 10:33 AM
ima bump this...did u feel any gains? feel like u lost a whole lotta low end?
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
JonBlz
Oct 5, 2015 06:02 PM
bigfrank
Oct 1, 2015 12:51 PM
