Fix front bumper gap?
Old Nov 16, 2010 | 08:26 AM
viperboy's Avatar
It seems like my front bumper is sagging a little, kinda makes the front look stupid. Where would you adjust that? I've never had to take the bumper off, so I'm not sure. I figured there might be a quick fix for this
Old Nov 16, 2010 | 09:10 AM
scarface4522's Avatar
Hopefully someone knows a lil trick..mine is saggin too..
Old Nov 16, 2010 | 09:12 AM
cjandura's Avatar
If you find a fix or solution could you post it.i have the same issue but have a 1/2 gap under the light on the pass side after a bodyshop repair
Old Nov 16, 2010 | 09:15 AM
Maxy91's Avatar
i have that too my mechanic said to change the clips cause they are broken
Old Nov 16, 2010 | 09:17 AM
Maxy91's Avatar
Old Nov 16, 2010 | 09:23 AM
It seems like everyone who has this problem has a front lip..the weight of it must weigh it down after a while
Stormzusmc's Avatar
lol wow that sucks
Old Nov 16, 2010 | 09:25 AM
Old Nov 16, 2010 | 09:26 AM
RLW001's Avatar
I know if there are two bolts (10 mm Nissan part# [085666205A] SCREW-TAPP) that hold the bumper cover to the fender. I bet they are just loose.
Old Nov 16, 2010 | 09:27 AM
Ominous OP's Avatar
Maybe you can get some zip ties in there for temp fix?
Old Nov 16, 2010 | 09:28 AM
Stormzusmc's Avatar
the second that happens to my car..if it does...it will be fixed...i couldnt stand that
Old Nov 16, 2010 | 09:33 AM
Just searched and found this- http://forums.maxima.org/5th-generat...nt-bumper.html
Old Nov 16, 2010 | 09:37 AM
Maxy91's Avatar
Myabe you can grab something off this, http://www.courtesyparts.com/maxima-...2070_2071.html
Old Nov 16, 2010 | 11:57 AM
Tee00Max's Avatar
wow mine is sagging as well...
Old Nov 16, 2010 | 12:01 PM
KBCobra's Avatar
The tabs under the headlights probably came out. I'm not sure if the 5.5 has the tabs but I know my 5th gen does.
i broke mine off when removing the bumper cause it was going to the trash anyway!
HOKUSMAX
Nov 13, 2017 04:34 AM
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Max139617
Aug 29, 2015 02:55 PM
