Passenger side front window switch broken
Old Nov 24, 2010 | 03:35 PM
Whitebread's Avatar
The passenger side front window switch in my 2003 has failed me and, I would like to just short the correct terminals in the connector to get the window to wind up. Unfortunately, I'm having a bit of trouble figuring out what terminals are what in the window switch connector. The FSM says:
Front Door RH
Ground is supplied
to front power window switch RH terminal 11
through body grounds M9, M25 and M87.
WINDOW UP
When the front RH switch in the front power window switch is pressed in the UP position, power is supplied
POWER WINDOW
System Description (Cont’d)
to front power window regulator RH terminal 1
through front power window switch RH terminal 8.
Ground is supplied
to front power window regulator RH terminal 3
through front power window switch RH terminal 9.
Then, the motor raises the window until the switch is released.
This info is great except, I do not know which terminals 1,3,8 and 9 are. Does anyone know? The FSM references connector D43.
Thanks.
Old Nov 24, 2010 | 03:43 PM
Whitebread's Avatar
I think ground is terminal 11 but, I do not know what terminal corresponds to power. Does anyone know?
Old Nov 24, 2010 | 04:34 PM
Whitebread's Avatar
I figured it out. The window motor is shot. Does anyone know of a way to get the window up without replacing the motor assembly outright? I don't want to drive around with a garbage bag on my car, if possible.
HOKUSMAX
Nov 13, 2017 04:34 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
mpbclutch33
Aug 21, 2015 06:09 AM
KGMtech
Aug 18, 2015 09:21 AM
kjm900r
Aug 5, 2015 07:14 AM
