HELP WITH AC PROBLOM
Old Dec 13, 2010 | 05:29 PM
arthur glazier's Avatar
My AC stoped working, When I press the AC button nothing but warm air comes out. I looked at the compressor and its NOT ingaged. I checked the 2 fuses and the relay and they seem to be ok. When I press the relay I can hear and see the ac cluch ingage but it does not get cold while doing so. Their is 12v at the relay . When I press the AC button it does light-up. What am I missing? I have seen alot of posts about bad blower motor, but mine runs and sound fine.
Old Dec 13, 2010 | 05:49 PM
GBAUER's Avatar
you have low freon. Probably a leak somewhere.
Old Dec 13, 2010 | 06:14 PM
No, the cluch does not ingage
Old Dec 13, 2010 | 06:36 PM
GBAUER's Avatar
that's because there's a pressure switch that won't allow it to engage if the pressure is too low.
Old Dec 13, 2010 | 06:39 PM
Kidnasty's Avatar
I have the same problem with my ac clutch not engaging, I never checked the relays. Does the ac/heat use the same relay/fuses? and it wont take freon the line is just full of air.
Old Dec 13, 2010 | 06:53 PM
JagerBlunt's Avatar
you must get an A/C service done and have them put the leak detection dye in the system, but the only thing i know is that its snowing in jersey and IDK why in hell you would need A/C
Old Dec 13, 2010 | 09:07 PM
DennisMik's Avatar
If you need to de-fog the windows, you need the AC to pull out the humidity.
Old Dec 13, 2010 | 11:41 PM
I did not know about the pressure switch, thanks. Ill check it out.
Old Dec 14, 2010 | 04:22 PM
I rechared with freon and it works!!!! Now I just need to check to make sure theirs no leaks. Im in Calif. and 1 week its in the 60's and the next its in the 80's.
Old Dec 14, 2010 | 04:30 PM
JagerBlunt's Avatar
not really though, yes the A/C kicks on when you hit defrost but all you really need to do is get the window hotter than the dew point, i have my A/C belt off my VG ATM and it clears em up just fine, at OP temp of course
Old Dec 14, 2010 | 05:46 PM
DennisMik's Avatar
The more moisture in the air, the faster it will defog with the A/C working.
arthur glazier
Wheels/Tires
May 1, 2010 08:24 AM
arthur glazier
Sep 29, 2009 08:33 PM
arthur glazier
Apr 8, 2009 12:07 AM
arthur glazier
Aug 24, 2008 09:56 PM
MadMax92
Jan 29, 2007 09:51 PM
