wheel play front passanger side
Old Jan 24, 2011 | 09:14 PM
importcf's Avatar
So i go to midas the other say to get my dynomax vt installed and upon there inspection they say i need a wheel bearing on the front passenger side they brought me out to the shop and they grab it at 12 and 6 and there is noticeable play i say hold off because i have an extended warr. w/nissan. i bring it to nissan to get checked out and they say they cant find the issue? hey im no mechanic but wheel play cant be good. I said midas said it was the wheel bearing they say its fine. WTF i told them ill be in tomorrow to check it out because i saw it move on the lift. Any tips? are they trying to avoid warranty work
03 max w/ 72k miles lots o pot holes around here
Old Jan 24, 2011 | 09:52 PM
Scottwax's Avatar
That's Mr. Detail to you
Take your car to a good independent garage and see what they say. Wheel bearing issues are pretty common for 5.5 gens.
Old Jan 24, 2011 | 10:02 PM
importcf's Avatar
Well I figured I will have them show ne the car on the lift and and show me the wheel without any play. I know it will move I saw it at Midas.
Old Jan 24, 2011 | 10:31 PM
BigLou55's Avatar
They may work but some stealerships will "claim" they dont allow customers in that area, hope you dont have that kind in your area.
Old Jan 25, 2011 | 05:17 AM
Mr. Brett's Avatar
Why not try taking your spare tire jack out, if you don't have any others, jack the suspect wheel up into the air, and try grabbing the wheel at 3 & 9 and wiggling it back and forth to show your techs what you're talking about?
Old Jan 25, 2011 | 05:47 AM
importcf's Avatar
well luckily for me this dealership you basicly drive right in and park so your walking in the shop so they will not be using that excuse and worst case ill jack the car up myself
Old Jan 25, 2011 | 06:42 AM
importcf's Avatar
Update: so now they call me and say "oh we found slight play in the front wheel not something we would mention but since you have a warranty we could replace it." i brought it in for that ii obv want it replaced! There should be NO Play. It sounds like to me they missed it and makes me wonder what else they missed because i brought it in for fact mait also.
Old Jan 25, 2011 | 03:33 PM
pkrainert's Avatar
I had slight play on my 96 when I had it, I don't know how they could miss it all you have to do is wiggle the tire when its in the air lol.
Old Jan 25, 2011 | 05:28 PM
Scottwax's Avatar
You definitely want it fixed right and make sure they inspect the hub when they replace the bearing.
Old Feb 12, 2011 | 11:49 AM
vybz05's Avatar
fix your wheel bearing. And hub. do not wait till it is too late.
Old Feb 12, 2011 | 11:58 AM
Child_uv_KoRn's Avatar
Bad *** Newb
^^ +1
My bearing went out and the hub welded itself to the knuckle (bearing was shredded, idk how it happened so fast). That's an extra 300+ dollars you don't want to spend. More than that actually b/c the abs sensor has to be replaced.
Also, check wheel nut tightness. Crank those *****es on there. That can ruin these parts by itself.
Old Feb 12, 2011 | 04:04 PM
roggeezy's Avatar
Definitely get your wheel bearing changed out. I drove on a bad wheel bearing (not knowing it was bad) and it snapped the axle nut right off with part of the bolt. Had to replace the axle, wheel bearing, and hub.
HOKUSMAX
Nov 13, 2017 04:34 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
