Please help me! SECU Electrical mess!!
Old Jan 26, 2011 | 10:55 AM
bgawad's Avatar
ok heres the story i was changing the bulb in my trunk, then i saw a spark then it went out. I thought no big deal ill change the fuse. I change the fuse and its still a no go. Then i realize my key less entry, rear defogger, and map lights don't work. I search and find out its my secu i go back to the car look around the gas pedal and theres nothing there. I see the bracket that holds the secu but the secu is no where to be found. This car's killing me... can someone please!!!!!!!!!! tell me where to trace the secu with pictures. I dont know what the previous owner did but i went outside mulitple times to continue to look for it but i cant find it all!!
please help me!!!!!!
Old Jan 26, 2011 | 02:50 PM
DennisMik's Avatar
I have a 2000 Max and mine is up under the dash on the driver's side about even with the console. If I were to cut everything free, I could not move it around very much, there is not very much slack in the wire harness. My SECU is a beige plastic box with 2 connectors on it. In late production 2001 and there after, the SECU had 3 connectors on it.
You could also try disconnecting the battery for 10-15 minutes and this may reset the SECU.
Here is a photo of mine, taken from outside the car on the driver's side, looking up under the dash towards the console.
Old Jan 26, 2011 | 04:29 PM
bgawad's Avatar
yea i have the beige box as well. I called Dave B. and told him my situation he said that beige box is for the pats (passive theft system). He said theres another box that is the secu. Im so confused is there one box or 2? what is the beige box? ughh thanks DennisMik
btw i switched this beige box already from the totaled one and theres still no change
Old Jan 26, 2011 | 06:47 PM
DennisMik's Avatar
That's very interesting. I am unable to find any reference to a "pats" in the FSM and I have found two locator drawings that show the beige box as being the SECU. I hope another org mamber can expand upon Dave B's statement.
Old Jan 26, 2011 | 07:26 PM
bgawad's Avatar
yes im so confused on this one, i need my keyless entry and maplights... now i have to manually unlock and lock the rear and front doors when i have guests... plus its always snowing now and i have no rear defrost anyone????
i searched the parts number on google and secu is coming up... ugh this makes no sense, i even switched it out... why is it still not working?
bump
Old Jan 27, 2011 | 04:49 AM
VQP0WER's Avatar
Have you looked at all the fuses?
Old Jan 27, 2011 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
Dome some leg work, then bump. Look at your fuses.
Old Jan 27, 2011 | 06:40 AM
bgawad's Avatar
i did look at my fuses, i literally purchased a 100 pack for $30 and replaced every single one under the steering column. I wouldn't even post this thread if i didn't check fuses.
i read something on google about a circuit breaker? can anyone tell me more about this?
Old Jan 27, 2011 | 06:55 AM
NmexMAX's Avatar
dot dot dot ...
Now check under the good for that fuse box/panel, and before changing all of them try and find the one that is burnt.
Old Jan 27, 2011 | 08:56 AM
luvlexus101's Avatar
maybe it blew again when you put it in, i believe its either room light or electronic parts fuse...weird issue.
Old Jan 27, 2011 | 11:20 AM
bgawad's Avatar
i'm not an idiot NmexMAX. After SEARCHING, ive read about people who couldn't find a bad fuse... but after replacing them all, they got it to work. Sometimes the broken metal in the fuse is to small to see.. thus i replaced them all. Anyone know about any relays that could be the problem? thanks!
Old Jan 27, 2011 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
Ok, then try being a little more informative in your posts, as always on a forum, you need to help us help you.
Check the fuses under the hood and the relays too.
http://forums.maxima.org/7907254-post4.html
Old Jan 27, 2011 | 01:54 PM
bgawad's Avatar
okay thanks NmexMAX, by the looks of it; theres no specific fuses controlling the SECU, (i dont know if someone can tell me otherwise). I changed the secu, checked all fuses in the car and under the hood. i dont know what else can be the problem?? it makes no sense
Old Jan 27, 2011 | 05:26 PM
P. Samson's Avatar
The circuit breaker that you are looking for is behind (towards the firewall) the main fuse block under the instrument panel. Looks like it's above the dead pedal.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
