another fidanza flywheel/clutch?
ok i have searched and couldn't find a definite answer. I need some suggestions on a clutch, for a fidanza fly wheel on a 5.5 gen with just I/E/H. Anything other than the 350z. I don't wanna have to modify the transmission case in order to make that work. Oh the car will be a daily. Thanks in advance.
^^ did you use the z33 PP? from what I have read the PP rubs a little, but the disk is ok. And if you buy a Z33 kit you have to spend extra on the maxima bearing since the Z bearing doesn't work
call competition clutch they have a great product and prices and the lightest flywheel available for 5th gens-10.xx lbs
http://www.competitionclutch.com/
I run the Exedy stage 1 with Fidanza flywheel. Exedy stage 1 is MUCH stiffer than stock and I do have clutch chatter but you get used to it. I love the way the car feels with this setup!
The whole clutch kit was 350Z with a Maxima throw out bearing. No rubbing whatsoever.
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
