2001 I30 No Start
Old Feb 5, 2011 | 11:01 AM
bluebriscoe's Avatar
2001 I30 No Start
Hello Im having trouble with my I30 not starting.When i bought it it had the high idle symptom from the idle air control valve.I then replaced the iacv sensor but the problem did not go away so i researched and found out it could have shorted out the ecm...in which it did, but all through out the car still drove no problem just had high idle,but one day it just stopped in traffic on me so i started it back up and further down the road it stopped again.Now it wont start at all any more (crank but no start).So I sent in the ecm to be repair got it back and still no start. I bought some starting fluid and it would run as long as im spraying it in the intake so i thought maybe the fuel pump was bad replaced the fuel pump and still no start..What is wrong with my car has the whole ecm need to be replaced?.....Some one please help me
Old Feb 5, 2011 | 12:19 PM
marco polo's Avatar
Have you checked the fuses. Do you here the fuel pump prime up when you turn the key to start?
Old Feb 12, 2011 | 06:14 PM
yes i hear it
Old Feb 12, 2011 | 06:19 PM
NAVY00MAXIMA's Avatar
Cam/ crank sensors?
Old Feb 12, 2011 | 07:07 PM
Ghost_54's Avatar
No start, and you had it die on you once .. I would go with replacing the "Crank Position Sensor"
Old Feb 13, 2011 | 03:31 PM
I took it to a shop and they replaced both sensor supposely and they said still no start....any way to test if it is the sensors
Old Feb 17, 2011 | 02:51 PM
no one knows any thing about this problem?
Old Feb 17, 2011 | 08:17 PM
AbominableSnowmax's Avatar
Had a similar problem with my car dying out. My crankshaft sensor **** the bed on me
9aj9
Apr 5, 2020 12:11 AM
RinconI30
Nov 10, 2015 10:55 PM
mikebla
Sep 3, 2015 05:37 PM
