Clear Side Marker question
Old Mar 9, 2011 | 07:23 AM
maxatlast's Avatar
I just purchased a set from Ipex Motoring.
I have not removed the originals yet.
The Front's came with a bulb and socket (that appears to accept a plug) already inserted into the Clear Marker housing. The Rears did not. Is there a reason for this difference ? For the Rears I assume I'll just replace the bulb when I replace the Side Marker but do I need to use the socket that came with the Fronts ?
thanks
Old Mar 9, 2011 | 08:20 AM
TheOnlyMax88's Avatar
When i put mine on it was just take the old off, stick the existing bulbs into the new markers and put them on. im not sure why your running into a problem. I dont rememebr where i got mine from tho, long time ago
Old Mar 9, 2011 | 08:36 AM
maxatlast's Avatar
I'm not running into a problem yet as I haven't started the install.
My question pertains is there a reason the fronts have a socket on the Clear Marker and the rears do not. (i.e. do I need to use this socket or can I just take the bulb out and use the socket from the OEM)
I just wanted to find this out before I started.
Old Mar 9, 2011 | 01:59 PM
nismopc's Avatar
I did not try when I put mine on, but assume it will fit. What I did for the rears though was install red bulbs instead of the stock clear so it lights up properly at night, but 'stealth' during the day.
Old Mar 9, 2011 | 02:25 PM
maxatlast's Avatar
nismopc,
To clarify - did you use the socket that came with the Front Clears or discard that (except bulb) and insert the OEM socket into the Clear housing ?
I guess another way to ask my question - is the socket that came with the Front Clears the same socket that exists with the OEMs thus interchangeable.
thanks for your input
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
rtirbany
Sep 8, 2015 11:46 AM
papo99
Aug 9, 2015 07:32 AM
