Right headlamp not working
Old Mar 14, 2011 | 06:54 PM
kpmikey808's Avatar
Replaced connectors, bulbs
Right head lamp only parking lights work
Left headlamp low & I beam work
Checked all fuses & everything
Need help please
Old Mar 14, 2011 | 07:22 PM
TunerMaxima3000's Avatar
What year is your car?
Old Mar 14, 2011 | 09:42 PM
Amave's Avatar
have you tested wiring ? test wiring from switch to light bulb , you'll need the wring diagram
sounds like its a wiring issue, critters can get in there and chew up wires
i have seen it
Old Mar 15, 2011 | 06:39 PM
kpmikey808's Avatar
2000 maxima- wiring sounds like the problem
I had these aftermarket blue bulbs for like 3 years
The right hi beam work recently
Where wouldmi check the switch to lightbulb
Old Mar 15, 2011 | 07:00 PM
Need help please
To clear this up, the RIGHT headlight High beam works?
But the LOW beam doesn't?
You said you changed bulbs out correct? Did you swap them left/right? (this will tell you for sure that you're testing with a GOOD bulb, because you are using the LEFT headlight bulb, that was just working)
If it doesnt work, then you absolutely have a wiring issue, could be a few things, but most common is a corroded harness (what plugs into the headlight).
Do you have a test light or DMM?
Old Mar 16, 2011 | 11:10 AM
DennisMik's Avatar
If both the high & low beam doesn't work, you could also try swapping the Head Lamp 1 and Head Lamp 2 relays (by the power steering oil reservour) and see if that changes things.
Also, each headlight has its own fuse, numbers 68 and 69, 15amp, (under the hood by the battery). I forget which is left and right.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
