Two questions about paint..
Old Mar 29, 2011 | 06:14 PM
cmax1's Avatar
The first one is what color is this? Its a 2002 se and i dont know how to read the color code to get the paint..
and how do i remove the chrome trim to get the rust?
Old Mar 29, 2011 | 06:18 PM
Ghost_54's Avatar
check on the plate inside the engine bay mounted on the firewall it lists when your car was made, vin # as well it will have your paint code listed, mine is sterling mist KT3
Old Mar 29, 2011 | 06:57 PM
NJ3ndri's Avatar
under the hood against the firewall most likely on the passangers side theres a plate stamped there with a color code. anyway when you get that trim off try wetsanding that rust with 2000 sand paper then buff it out. see if that will get it a little close to what youre looking for before you start messing with paint
Old Mar 29, 2011 | 07:54 PM
Rods03Max619's Avatar
But mine is Merlot AX5..good luck...
Old Mar 30, 2011 | 11:44 AM
colombian4u_61's Avatar
same here
Old Mar 30, 2011 | 12:04 PM
UGAd13's Avatar
please don't tell me that's a pic of a Glacier Pearl Max... poor baby.
If it is you won't be able to match it without taking it to a shop and if you don't blend properly it'll look like poo.
Old Mar 30, 2011 | 02:27 PM
djfrestyl's Avatar
Suspension Yoda
Glacier Pearl - QX1
Google is your friend. Best of luck. As mentioned above, the pearlescent paint job is impossible to match unless you're a professional body shop.
Old Mar 30, 2011 | 04:10 PM
cmax1's Avatar
I got a friend at a paint shop that deal with dupont paints so im sure he can match it. Base coat and a pearl coat along with some clear. May have to paint the whole door along with some other sections that has rust appearing. If that doesnt work then will have to redo the whole car..
Old Mar 30, 2011 | 06:36 PM
spock's Avatar
2000 grit isn't even going to touch that rust. Then buff it out? Come on, look at it!
Old Mar 30, 2011 | 07:01 PM
Ghost_54's Avatar
^^^Exactly
Sorry to say but I think that is going to proof to be right straight through judging by how much bubbling is showing, more than likely going to have to start with 80 grit and perhaps finish with 2000 grit. (but I fear the worse is there might have to be some filling put it).
Rust tends to start from the inside and then works its way out when it becomes visible (at that point the damage is already done).
Old Mar 30, 2011 | 08:43 PM
bds1304's Avatar
Glacier Pearl - QX1
its not impossible, but then again i dont think i quallify to say other wise, cause i do paint cars.....but basically what u want to do is bring it to ur car to a local body shop or body shop supply store and they can match up the paint, but as far as repair goes looks like ur goin to have take the molding off and strip the rust off, then filll it in with some bondo, sand to its smooth, sand the rest of the door and the rear quarter panel and about have way up the c pillar. but if i was u i would take it to a shop, pearls can be a ***** to match some times, depending on the paint company.
Old Mar 30, 2011 | 08:47 PM
bds1304's Avatar
^^^Exactly
^+1
yeah thats the stuff that makes me but its a easy fix, a good body shop will have that fixxed with in 2-3 days depending on how busy they are,
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
