Heads and the VIAS Gasket name?
Old Apr 6, 2011 | 11:07 AM
killer00's Avatar
I need to buy the gasket between the heads and the intake manifold. And the gasket between the VIAS, where you place the NWP block off plate gasket, i need to know what they are called? Because I'm looking for them online. I have a 2002
Old Apr 6, 2011 | 11:08 AM
NmexMAX's Avatar
dot dot dot ...
Year of car
I assume 2000, re: your SN.
Or, since you're asking for BOP related items
Courtesy has their own way of calling these things, but that's it.
14033+A.
BUT, it's a metal gasket and, IMO< shouldn't need to be replaced if all you're doing is adding a BOP. Jesus people, would it kill anyone to be semi descriptive as to why and what they're doing?
Old Apr 6, 2011 | 11:14 AM
killer00's Avatar
2002
Old Apr 6, 2011 | 11:15 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by killer00
2002
And are you doing what do you need and why do you think you need it?
Old Apr 6, 2011 | 11:18 AM
killer00's Avatar
I'm in the process of cleaning the Intake manifold and then adding the BOP.
should i change it or not?
Old Apr 6, 2011 | 11:19 AM
NmexMAX's Avatar
dot dot dot ...
I wouldn't.
And if you do, it's such a small part, you'd be better off going to your local dealer and getting it.
Have you read the instructions?
Note: This block plate is designed to be installed with the OEM VIAS gasket. But, RTV silicone sealant can be used instead of the gasket.
Note: It is ok to reuse the stock VIAS gasket to seal the block plate as las the gasket is in good condition. If you feel the OEM gasket is in poor condition or you don’t have an OEM gasket, you can use Black RTV Silicone Gasket Maker without using a VIAS gasket.
Old Apr 6, 2011 | 12:01 PM
killer00's Avatar
I read the instructions but I was just thinking of getting new ones for the sake of getting new ones vs old. I guess I'm going to keep the old ones because Nissan dealership is 68 bucks for one gasket. I prefer to use that for the thermal spacers.
Old Apr 6, 2011 | 12:11 PM
2000_MAXIMA_KING's Avatar
You can get a felpro gasket kit that comes with all the intake manifold gaskets even though you're confusing me because you stated you need a gasket for the heads???
Old Apr 6, 2011 | 01:04 PM
NmexMAX's Avatar
dot dot dot ...
Jesus ....
wat?
If you're adding spacers, you don't need another gasket, that's what they are, thermal gaskets and that's what the RTV is for.
Old Apr 6, 2011 | 01:14 PM
Rochester's Avatar
Before NmexMAX glows a gasket (nice pun), I think Killer here means he'd prefer to use *the money* for the thermal spacers.
But yeah, when someone says they've read the instructions, then explain things seemingly contrary to said instructions...
Old Apr 6, 2011 | 01:17 PM
NmexMAX's Avatar
dot dot dot ...
Oh ... ya. haha ... that makes sense.
I've removed my IM about ... 6 times before my spacers and never once changed the gasket.
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
