Tire Decision/ HELP!!!
Old Apr 13, 2011 | 01:16 PM
mrfxho's Avatar
So I dont remeber if you guys remembered that I posted on here a couple of months ago that my bro in law was giving me his stock G35 rims for $200 which are these...
well im finally going to buy some new tires for them before mounting. Im currently running 225/55/17 stock 02 maxima se wheels ( this is after a fresh wash with NO WAX!!! , think it looks so sexy lol) ...
Now my question is, am I able to fit 255/45/18 on the car without any rubbing, major issue or should i just play it say and go with 245/45/18 like how everyone else has it. **Plus as you guys see I do have a hitch on the car because I use it as well to tow my jet ski to the marina** BTW the wheels im thinking of running are the Nexen N300...
Any input, advice, negative, pretty much all feed back whether its negative or positive would be greatly appreciated.
Old Apr 13, 2011 | 02:02 PM
RLW001's Avatar
I would keep looking... IMHO tires is not area where you should go cheap.
I hear they are a hard tire tread tire with soft sidewall.
Try Tirerack.com.
http://www.caranddriver.com/var/ezfl...5364f66014.pdf
Old Apr 13, 2011 | 02:29 PM
Scottwax's Avatar
That's Mr. Detail to you
Agree, don't cheap out on tires.
Old Apr 13, 2011 | 02:52 PM
Xarles's Avatar
Im not sure about the tire sizes, but I have yokohama sdrive tires and love the grip, there are other good options for ~$100-125. how do you drive? Do you take an on ramp at 80 mph? or do you just use your v6 to power around slow cars and continue along at the speed limit?
Old Apr 13, 2011 | 09:02 PM
mrfxho's Avatar
ok so lets say I dont go with the Nexen N300, would that tire size fit my max with those G35 wheels? The size again is 255/45/18
Anyone?
Old Apr 14, 2011 | 05:56 AM
matt06's Avatar
i wouldnt go bigger than 245-45-18
im running those on my rear right now and personally i wouldnt go bigger. the tire will have too much sidewall. go with a 255-40 or 275-35 if you want a wider tire
Old Apr 14, 2011 | 06:42 AM
NmexMAX's Avatar
dot dot dot ...
I should know this because these are pretty bandwagon just like the Z33 tracks :O,
but IIRC, the tire is the only difference in this case, correct, not the offset and width (Fr/R)?
If that's the case and you're not lowered, I wouldn't go larger than a 245-45.
Old Apr 14, 2011 | 12:43 PM
JohnWEngle's Avatar
Bridgestone Potenza RE960AS Pole Position
Old Apr 14, 2011 | 02:36 PM
nismopc's Avatar
I had Nexen N7000's on my stock 17's and absolutely loved them.
Only issue I ever had with them is the tread life is poor, but that should be expected from a low priced performance tire.
You will see reviews of all tires name brand/off-brand/generic that contradict each other. Go with what you feel is the best overall value, performance and safety based on research.
Old Apr 14, 2011 | 02:45 PM
exandr's Avatar
I agree with the others...don't go cheap. Go wider, with a nice tread pattern.
Old Apr 14, 2011 | 02:50 PM
NmexMAX's Avatar
dot dot dot ...
Wider than 255?
I wouldn't.
Tires are more than just a cool looking tread pattern.
Old Apr 14, 2011 | 03:44 PM
nismopc's Avatar
...and here I thought tires were always form over function.
Old Apr 14, 2011 | 03:50 PM
vinco's Avatar
245 is pretty much the ideal width for the Maxima, IMO. The 45 series will be fine. The G35 wheels are not staggered. Just the tires were staggered from the factory.
Old Apr 14, 2011 | 08:24 PM
knight_yyz's Avatar
Toolie
After much research, I decided to go with the hankook ventus k110 tires. They scored higher than the much more expensive michelin ps2. I haven't driven on them yet, install happens Monday. But I saved about 600 dollars by not going with the Toyo t1r's I've used the last 2 seasons
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
