Some new rims maybe
Old Apr 21, 2011 | 04:49 AM
  #41
jeff5347's Avatar
you dont think the gunmetal clashes with the silver? I was thinking the silver rims would have gone better. I like these rims they just need t ogrow on me.
Old Apr 21, 2011 | 04:51 AM
  #42
phatboislim's Avatar
i see what you mean...get some better pics...i think its fine though...if anything..tape it up and paint it something else
Old Apr 21, 2011 | 09:39 AM
  #43
Prophecy99's Avatar
Jeff pretty sure our hub is 66.2, just ordered spacers with that spec'd and they fit nice a tight. and if that hub number for the Hiros is correct then yes get that ring adapter. I would get an extra few (5 total) if u can. Try not drive far without the hubcentric ring adapters not a great idea
And a piece of advice. if you ever have shops take your aftermarket wheels on and off for whatever reasons (mount and ballance, tire change, wheel weights, labor whatever) alllways DOUBLE check you have your hubcentric rings on there after the work is done. because alot of the times they do not really take notice of them,
Once example I checked prior to leaving the establishment and what do you know it wasnt on there. The place found it stuck on the balancing machine and put it back on.
edit-
and the rims are sick btw, If things were different I probably would be rocking these.
also I just notice some wheels may be hard to simply visually check if u have your ring adapters on there, mine have a center cap that you can remove and visualy check with out takin the wheel off
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
