quick question about rear brake pad install
Old Apr 27, 2011 | 12:59 AM
hotstartup's Avatar
I was installing the rear brake pads and wanted to check with you guys if the groove in the piston is suppose to line up with the little "bump" on the brake pad (the bottom grove on the piston, part you use to compress the piston and line it up with brake pad bump?)
thanks
Old Apr 27, 2011 | 04:55 AM
TunerMaxima3000's Avatar
yes
Old Apr 27, 2011 | 07:13 AM
Andy2000max's Avatar
make sure you are turning the piston at the same time you are compressing the piston. when you get it compressed enough, make sure a slot is lined up with the pad.
Old Apr 27, 2011 | 07:21 AM
ctsmith39's Avatar
Why do you need to have the grooves lined up?
Old Apr 27, 2011 | 07:28 AM
hotstartup's Avatar
the piston I dont think will sit proper otherwise against the pad.
sasha87's Avatar
might cause uneven brake wear or even failure.
hotstartup's Avatar
another question, how do i get brake fluid out of the reservior mine is way too full now!
Old Apr 27, 2011 | 07:33 AM
sasha87's Avatar
syphon pump
Old Apr 27, 2011 | 07:39 AM
hotstartup's Avatar
does the filter come out on the master cylinder? I have a syphon pump but wasnt sure if the filter on there is part of the master cylinder or can be seperated.
Old Apr 27, 2011 | 07:50 AM
Don't mess with the screen. I use an old one of these for brake fluid. If you have kids, you know what this is.
Old Apr 27, 2011 | 08:09 AM
hotstartup's Avatar
how are you sucking fluid with that? and what is that? lol
Old Apr 27, 2011 | 09:44 AM
fitness stain's Avatar
snot sucker .. works everytime
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
classymax420
Aug 6, 2015 06:35 PM
RealityCheck
Aug 5, 2015 06:18 AM
