My oil light comes on then goes off **STEP INSIDE AND HELP PLEASE**
Old Apr 29, 2011 | 04:25 AM
phatboislim's Avatar
Since the threads i've posted in have yielded no results and my only google and org searchs have either come to a dead end or not a complete diagnosis, i'm starting this thread.
So after leaving the track to test out my car and see what kind of numbers my car was doing as it sat, i went home. Everything is still going absolutely fine no issues no nothing. I go to my mothers house that evening to move furniture around...my car is parked for maybe an hour or more ---> problem occurs:
So I go back to the car to start it up, low and behold, my oil light is on and there is a rattle/clacking noise to be heard *oh great i'm low on oil* so i figure ill baby it until i get to walmart, no more than a mile away from my moms house, and get a quart of oil. before i even get half a mile to walmart, the oil light goes off and immediately the rattle/clacking noise does as well. Boggles my mind, so i figured ill just go home and get to bed because by this time its 12:00am and i have to get up at 5am. So i get up to go to work, i check the oil, although its low its not out of the norm for it to be that low. So i start the car up w/ the same symptoms as the previous night, and it goes away just like it did before, noise and light simultaneously.
This morning going to work, it stayed on the longest, about a mile, then the light goes off and so does the noise.
My thoughts are that while on the track, of course the oil was 'sloshing' around in teh engine and not being where it needed to be, possible killing the oil pump, as some of my google search has shown, yes it could be the oil pump. Then i'm reading some of these threads (which i've gotten no response from) and the synopsis is the person has a spun bearing/bent rod/etc etc...To me it doesnt make any sense for my particular situation, because if those things were wrong, then it would be a permanent knock/clack/noise in my engine bay, but when the light goes off, so does my noise.
With all that said (oil light and noise stop/go off after riding for a little while) can you say that my issue IS the oil pump? or is it something else?
Also if it is the oil pump, is the 3.5 compatible/interchangeable with the DE-k? and if it is, is it an upgrade?
Old Apr 29, 2011 | 04:26 AM
These are the threads that i found:
http://forums.maxima.org/4th-generat...e-tapping.html
http://forums.maxima.org/4th-generat...-plz-help.html
Old Apr 29, 2011 | 04:29 AM
Shift_Max's Avatar
The light comes on when low oil pressure is detected. I was going to say it might be the switch, but since you say there is a noise made, sounds like your pump is on its way out
Old Apr 29, 2011 | 04:31 AM
while i read those threads, the switch is only there to show that teh oil pressure is low. that being said because if its unplugged it will never show that oil light. i'm thinking the oil pump too, my guess is either once the car gets warmed up, or the oil pump gets oil around it..it loosens it up and it starts working again.
do you know the procedure/how to in replacing the oil pump? is it located around the timing components?
Old Apr 29, 2011 | 04:42 AM
Shift_Max's Avatar
Oil pump is located under the front timing cover and it is a PITA to replace with the motor in the car
Old Apr 29, 2011 | 04:46 AM
oh snap lol. sounds like my father in law is going to hate me a bit more. do you know about the compatibility of the DE-k and the VQ35 oil pumps?
Old Apr 29, 2011 | 05:07 AM
Shift_Max's Avatar
Wish I could answer that question but I do not know what works between the de-k and the vq35 motors. Maybe somebody else will chime in to answer that question.
BTW that viscosity oil do you run? Just wondering because it might be worth a shot to try something thicker to see what happens to the noise.
Old Apr 29, 2011 | 05:11 AM
val max life 10w40...when i ran heavier 20w50 it smoked even more.
Old Apr 29, 2011 | 05:34 AM
Originally Posted by sasha87
nice way too beat a dead horse with a stick.
you have yet, in all your posts, post anything worthwhile. take your bull**** out of this thread unless you are going to contribute
Old Apr 29, 2011 | 07:28 AM
adroitcaptor's Avatar
Phatboislim DO NOT DRIVE YOUR CAR!!!
The OP you made in this thread is exactly the information we needed. Testing with a gauge would only confirm. The reason I was asking you to test is when there is a short 5 seconds or so it can be caused from three areas. (Two of which are super easy to address.) HOWEVER the issue you have described can only be explained by a bad pump. (I make 1 exception that is so far fetched your engine would be hosed anyway.)
If you want to verify this issue you can pull the valve covers off, apply oil, then start up the engine. If the noise is mitigated you have affirmed what we are assured is true.
Old Apr 29, 2011 | 07:32 AM
For the good of the order:
JUST because you hear valve train noise does NOT mean your pump is bad. This is the stipulation I was TSing in phatboislim's other thread. (http://forums.maxima.org/4th-generat...-plz-help.html)
Also, if on start up your oil light is on and you hear clacking / metal-on-metal noise for more than 10 seconds, shut your engine off. It is common with synthetic oil, low oil, old oil, low viscosity oil, etc to hear some valve noise on start up (3seconds is 'normal'). That said I would seek to solve the issue as this is hard on an engine over time.
If you autocross your car make SURE that you have slightly overfilled your oil OR confirmed that you have sufficient baffles to retain oil supply to the pump. Starving your pump will burn it out quite quickly.
Old Apr 29, 2011 | 07:35 AM
well..i've driven it like this since wednesday night. the noise goes away. if the engine goes, it goes. it seems easier to swap the engine than to do the oil pump anyway lol. besides a fresh engine wouldnt hurt. but i will drive it home for work, but if the light/knock doesnt stop within the alloted time it does, i will pull over (although it'd probably be too late). i appreciate your input x1000 dude. i've already searched for engines and i have my friend pricing out an oil pump and oil switch for me right now. when i get back to home side, i will have my father in law take a listen and get his final synopsis on it....then ill just get ready to pay the piper
Old Apr 29, 2011 | 07:39 AM
i believe this is what happened...i starved my pump the last couple of times i ran on teh 1/4 mile and in essence burned my pump out. but my oil was topped off before i hit the track..it IS possible, highly possible, that during the 4th/5th run that the oil could have gotten too low and when i ran those times it burned up the oil pump.
BTW i've NEVER had issues w/ val max life causing that sort of sound in either of my vehicles, so i'm not going to blame that on the oil. i never had that sound in my DE-k and neither did i have it in my 22r and it was going on 300k before i sold it..only noise i had on that truck was the timing chain tensioner was bad.
FTR: the other thread you were responding to me at wasnt my original thread, i pretty much bumped an old thread
one other question. where can i obtain a baffled oil pan so i wont have to worry about oil starvation/burnt oil pump again?
Old Apr 29, 2011 | 08:09 AM
ajm8127's Avatar
I retract my statements in the other tread about the problem not being your pump. It was not clear in that thread how long the light was on.
I agree that having low oil and starving the pump could wear more metal from the pump. It sounds like when it is cold (cooler than operating temperature), and the parts have not yet expanded, the tolerances in the pump are too large and not enough pressure is being built up. Once the pump warms up and the parts expand, you get just enough pressure to turn off the light. Testing with a real gauge is a great idea. Just make sure to get an adapter for the 1/8 BPT thread in the oil pan.
I do think you should still do the leak down test to determine where the disappearing oil is leaking into the combustion chamber from. If it is the valve seals, it should be possible to change them without pulling the head.
Your oil pan should have a baffle in it already. I think the level of your oil had more to do with your problem than anything.
Old Apr 29, 2011 | 08:39 AM
I topped off my oil before running, i guess that by my 4th run i was teetering on the 'burning too much oil' especially when i missed 4th gear twice at the end of my runs. i have alot of things to check i guess...but to tell you the truth, i kinda dont want to have to go back into the top end of this car.
but your thoughts on the pump, is sorta my thoughts as well, i guess just a more detailed way of what i'm thinking of whats going on. ill let my mechanic/father in law do all of that. ive spent alot of time on my car last two weeks trying to save money by doing all that work i did to it. ill just let him do it and get it done quicker and more effectively than i can. i need my car back sooner than the whole wk that it was already down
Old Apr 29, 2011 | 08:59 AM
VQP0WER's Avatar
Last time I had an oil light flash on and off was in my dads old Jag. About 5 minutes later I threw a rod through the oil pan. Not good, don't drive until fixed.
Old Apr 29, 2011 | 09:20 AM
Eirik's Avatar
When you missed 4th, what did you shift into? 6th? I don't really get how you could burn more than two quarts of oil after 5 1/4mi runs. My oil-burning VQ35 didn't even burn a quarter of a quart after 3 consecutive 1/4 miles. When you said "track," I was picturing you turning through a cone with one wheel off the ground, engine leaning hard and sucking oil away from key areas, not sloshing backwards on acceleration.
Regardless, congratulations on a respectable time from your session!
Old Apr 29, 2011 | 09:54 AM
P. Samson's Avatar
For Pete's sake!......you had the low oil pressure light on/flickering (and associated ugly noises on top of that).......and you drove the car to Walmat?? The discussion on the oil pump is a moot point. The engine is done......oil pressure and a positive supply of oil during engine operation is rather basic to it's "survival".
Old Apr 29, 2011 | 09:59 AM
i have an 00 (5 speed)...not a 02-03 naw i tried again and went into 4th on the 2nd attempt. but it burnt i guess 1/2 qt, i just put more in there when i got to get a quart of oil (maybe 3/4 or just a tad less) to give it 'extra', but not too much. but yea...i dont get oil starvation of that extreme...but motion IS motion. so i mean anything is possible.
yea i read your post in the other thread that i posted in post #2. i'm aware i'm treading on thin ice right now
Old Apr 29, 2011 | 10:03 AM
1992maximase30's Avatar
the motor may last long too...who knows.
i have a friend who has a vq30 with a knock and oil light.
he saved up money for a new engine...just waiting for it to blow and this has been 2 1/2 months already.
Old Apr 29, 2011 | 10:10 AM
^sorta reassuring. but i'm dropping it off tonight or at least parking it home and getting my moms car or brothers car. if i have to get an engine ima cop an I30 since supposedly thats whats supposedly in the AE max
Old Apr 29, 2011 | 03:22 PM
Product_Of_Korea's Avatar
Have you check the strainer in the lower oil pan? Maybe theres a restriction in there causing the lack of pressure...
Old Apr 29, 2011 | 04:24 PM
Eirik's Avatar
Ugggggh. I seriously, honestly, can't keep you and ghustle separated in my mind! So GHustle has the 6-speed '00 GLE and you just have a normal 5th gen with a normal DE-K and normal 5 speed?
*muses* You really think this was caused by being a little low at the 'strip? You sure it isn't coincidence? If only Sparks had posted on here in the past couple of weeks, he'd probably be able to offer some greater insight.
Old Apr 30, 2011 | 07:24 AM
you are correct w/ me, but GH17 has a 5.5. GLE w/ the 6 speed swap....i'm confused as to why you get us confused
but i really dont know what caused teh frying of my oil pump, i mean ive had noise, but my mechanic and i assumed it was the air compressor as at idle w/ the a/c off, it made noise and w/ the a/c on it made noise, but both times, since the compressor 'pulley' is 'run' by its belt at all times and we saw it moving, we assumed thats what it was/is (which doesnt negate it NOT being needing to be swapped out) but only thing that i can figure is that oil was moving around and maybe on those missed gears while iwas flat shifting(shifting at full throttle) it burned oil and had enough low oil to where it starved the oil pump, causing what problem i'm having right now. THAT MY HYPOTHESIS. i cant say thats what caused it
Dennis Twohy
Oct 1, 2015 06:01 PM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
acw
Aug 13, 2015 12:50 AM
