drivers side headlight not working
Old Apr 29, 2011 | 05:08 AM
shortymust23's Avatar
i got pulled over the other day for my headlight and had to pay 430 in tickets ,and when i
changed the bulb yesterday its still not working. the high beams work but not the low.
Old Apr 29, 2011 | 05:20 AM
sasha87's Avatar
grab a continuity tester and test the pigtail, wire, fuse. double check also if the bulb was properly installed.
Old Apr 29, 2011 | 08:28 AM
MerlotMax's Avatar
I you have HID's you may have to check the ballast.
http://www.prolighting.com/hidtr.html
click on this - Download troubleshooting guide - 106KB
Old Apr 29, 2011 | 08:33 AM
nissandrvr98's Avatar
x2 on ballast...they do fail.
Old Apr 29, 2011 | 08:42 AM
If it's not the bulb then it's probably the ballast. Could be the fuse but I don't think the high beam works if the fuse is blown.
Old Apr 29, 2011 | 09:46 AM
MyMommaBiscuits's Avatar
I'm havin the same problem wit my Max. (2K2 SE) I swapped da bulbs n da ballast wit da workin headlight... they r both fine. If I have time today, I'm gonna swap the HID Igniter n then post what happens...
Old Apr 29, 2011 | 03:31 PM
RLW001's Avatar
$430 for a headlight being out? I thought if you got fixed in a set amount of time the ticket was revoked?
Like already said, use the trouble shooting guide to correct the problem.
Old Apr 29, 2011 | 04:34 PM
Gizm0's Avatar
I've got two ballasts here I can sell you if you need it. just PM me.
Old Apr 29, 2011 | 05:21 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Since when is a headlight ticket the same price as speeding 40 mph over the limit?
Old Apr 29, 2011 | 06:02 PM
DennisMik's Avatar
There are 4 fuses associated with the headlights, all of them under the hood.
Fuse # 68 - 15a left side high beam
Fuse # 54 - 20a left side low beam
Fuse # 69 - 15a right side high beam
Fuse # 55 - right side low beam
There a 2 relays, one for the left side and one for the right side. Each relay has 2 sets of contacts, one for the low beam and one for the high beam.
Hope this helps.
Old Apr 30, 2011 | 03:45 AM
i got a seat belt ticket and one i cant say
Old Apr 30, 2011 | 03:54 AM
i got 00-01 headlights they came with the car i think someone stoll the hid headlights before i got the car does that have anything to do with this problem .
Old Apr 30, 2011 | 03:20 PM
DennisMik's Avatar
It very well could. Switching between 00/01 and 02/03 headlighs IS NOT plug and play. Check the wire harnesses going to the headlights for splices. You may find a bad splice.
There was someone that posted the wiring modifications for converting a 00/01 to 02/03 headlights not all that long ago. Might have been TunerMaxima3000.
EDIT:
I found the link to the wiring conversion for putting 02/03 headlights in a 00/01. It is by TunerMaxima3000 and he did a great job.
http://forums.maxima.org/5th-generat...guide-diy.html
After you read this conversion thread, if someone put the older headlights in your car, they had to do some wiring changes and that's probably where you problem lies.
Old May 2, 2011 | 08:02 AM
MerlotMax's Avatar
This kind of information should be given up front! It would have steered you into right direction from the begining. Not to mention getting postings that turned out to be of absolutly no use to you. Hope that they may help someone else, down the road.
Dennis Twohy
Oct 1, 2015 06:01 PM
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
KGMtech
Aug 18, 2015 09:21 AM
