2k maxima
Old May 4, 2011 | 12:23 PM
aleem's Avatar
2k maxima
When i turn key to second position(all lights light up on dash) there is a loud buzzing noise coming from engine bay it seems to be around the tranny area. It sounds i like a high power transformer. I haven't check it out yet but gonna check relays first any suggestions?
Old May 4, 2011 | 12:37 PM
michaelm815's Avatar
Same exact problem here in my 2k. Haven't located the origin of the buzz but I'll check back if I find something.
Old May 4, 2011 | 12:38 PM
aleem's Avatar
ok buzzing noise is comming from inside transmission...
Old May 4, 2011 | 12:40 PM
Mr. Blue Sky's Avatar
It could very possibly be your electronic motor mounts( if you have an automatic). They tend to buzz when they are going, and when they go they can fry your ecu. Just disconnect them. They will not cause any harm disconnected.
Old May 4, 2011 | 12:49 PM
Most likely our electronic motor mounts.
Heres a good thread on it:
http://forums.maxima.org/5th-generat...e-startup.html
If the buzzing continues after you shut off your car, its getting bad and you can unplug them if you want (not a bad idea because when they go for good, then can fry your computer on the way out).
Old May 4, 2011 | 12:59 PM
aleem's Avatar
i have have es mounts and the wires are un plugged. My car does not run...still trying to figure out why. Noise is 100 percent coming from inside transmission
Old May 4, 2011 | 01:34 PM
pkrainert's Avatar
When I replaced my VB I forgot to plug the harness in and when I tuned the car on it was making a weird noise as well. But that was with the car running so I am not sure.
Old May 4, 2011 | 11:41 PM
mrjamaica98mx's Avatar
having same problem
Old May 5, 2011 | 01:16 AM
NAVY00MAXIMA's Avatar
That's your fuel pump priming
Old May 6, 2011 | 03:25 PM
aleem's Avatar
no, the noise is coming from inside transmission. ill try to get a vid up later
Old May 6, 2011 | 04:18 PM
NmexMAX's Avatar
dot dot dot ...
ABS light on?
Old May 6, 2011 | 05:42 PM
beefster's Avatar
i get a buzz sometimes when i start the car
but i kinda feel it on the brake
Old May 6, 2011 | 09:27 PM
ProjectX7's Avatar
LMAO.....
Nice
Old May 8, 2011 | 09:00 AM
Originally Posted by ProjectX7
LMAO.....
Nice
Is your fuel pump priming?
Old May 8, 2011 | 09:08 AM
I believe there is a relay related to the fuel pump priming in the left kick panel that gets noisy and buzzes. I've replaced in other Nissans but not a Maxima. Mines not loud. I wait everytime for the fuel pump to prime in every car I drive. It ended my random misfire code CEL.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
