Finally, got 30 MPG
Old Jun 17, 2011 | 07:58 AM
OnOiShNo0dl3Z's Avatar
Finally, got 30 MPG
While I know my Maxima isn't the first to break the 30 MPG mark and is most likely not the last to do so, it has been a goal for me to see if my car could really hit the 30 MPG mark since I got it a year and 2 months ago.
I made a trip from Philadelphia to Virginia Beach going down I95 to DE-1 to US-13 and then reverse. The speed ranged from 35 MPH to 70 MPH. It is much less stop and go traffic like you would experience in the city but US-13 had stop lights that caused me not to be able to avoid coming to a complete stop.
The car carried 4 adults and some luggage and a full size spare. No weight reduction, stock rims. I would say the car weighed about 700 +/- 50 lbs over stock. Only modification to engine is a home made Hybrid SRI. KYB GR2 struts and stock springs.
I did make use of the cruise control and the car is a 02 6MT SE w/ Leather Interior. The SES light was on the whole time for bad cats. I didn't beat on it on the drive home after a fresh fill up of Shell V-Power.
I drove 252.6 miles.
The next fill-up at that point took about 8.219 gallons of gas.
The entire time the car's MPG was saying about 36.4 to 36.7.
My total miles driven plus DTE reached as high as 594.
Final calculated MPG was 252.6/8.219 (less than half a tank of gas) was 30.73366. Close to 31 MPG.
Man I love that we can get such amazing mileage out of these cars with a 3.5 V6 from a decade ago.
Old Jun 17, 2011 | 08:04 AM
NmexMAX's Avatar
dot dot dot ...
Fairly common with the 6MT. Not so much with the pathetic 4AT.
Old Jun 17, 2011 | 08:10 AM
tedo007's Avatar
faster than you think
lean it little bit and you will see 40 on the dash lmao.
Old Jun 17, 2011 | 08:48 AM
NmexMAX's Avatar
dot dot dot ...
The dash works on IPW. Add larger injectors, and the ECU thinks ZOMGZ! I need to take more fuel out, so you will get even better dash readings.
Dash readings come from IPW, not MAF. I've been -17% on MAF and no difference on dash.
Coasting just after the Z33 injector install... cannot be in N because then the ECU will add fuel to be @ 14.7 ... coasting in a drive gear, my WB reads off the carts (19.0):
Old Jun 17, 2011 | 10:10 AM
kukx30de's Avatar
LOL... my 01 GLE with 201K still does between 28-29 religiously on the hwy kept between 60-80.... which is rather amazing knowing its a 4 cog slushbox vs a 6spd! So probably think again b4 u say "pathetic"
Old Jun 17, 2011 | 10:11 AM
NmexMAX's Avatar
dot dot dot ...
That's the best I get @ an avg. of 77mph on a tank, (28.7xx) with a 3.5L though, so maybe your #'s are pathetic for a 3.0L .
best I got was 30.4x in my 95 on the highway, same trip, same avg. MPH.
Old Jun 17, 2011 | 11:33 AM
PadawanKnight's Avatar
I haven't had the opportunity to do a full tank of highway driving in the 4 years that I've owned my "pathetic" 4at. With that being said, I've gotten as high as 28 from mixed driving. Our cars tend to do better in the 70-80 mph range than in the 50-60 mph range. At least, that had been my experience.
Waxima's Avatar
Amen to that. I was thrilled that I got 20 mpg on my last fill up. Replacing the camshaft position sensor did wonders, bumping my fuel economy from 17 all the way up to an admirable 20.
Old Jun 17, 2011 | 11:41 AM
NmexMAX's Avatar
dot dot dot ...
Seems like some of you took offense to the pathetic 4AT term. What I meant by it, is that we really should have got the 5AT.
Sheesh.
Old Jun 17, 2011 | 11:51 AM
phatboislim's Avatar
i've done 30 mpg before...right now i'm at abotu 25-26...i'm going to atl today..we'll see how good of a mpg i get
Old Jun 17, 2011 | 11:56 AM
FlawleZ's Avatar
Sheesh.
Well we should be glad Nissan decided to beef up the 4AT for the VQ35. Otherwise we'd all be on our 2nd and 3rd transmissions.
Old Jun 17, 2011 | 12:10 PM
NmexMAX's Avatar
dot dot dot ...
Not sure what they did differently, do you know?
Old Jun 17, 2011 | 12:11 PM
Waxima's Avatar
Sheesh.
I wasn't taking offense. This transmission really is pathetic.
Old Jun 17, 2011 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
Pretty sure they didn't change anything since 99. The 00 was a B suffix in the code, and it denotes the FD change to accommodate the larger diameter tires.
The V denotes VLSD. They're all the same since 97, possibly even 95 IIRC.
Old Jun 17, 2011 | 01:10 PM
Rods03Max619's Avatar
I know I can get 28 or 30 espeacially all hwy at 70...Auto with lighter than stock wheels and some mods...
Old Jun 17, 2011 | 01:35 PM
FlawleZ's Avatar
When I spoke with Jeff at Maxtuning he informed me Nissan did several things to beef up the 02+ transmissions. He referred me to Wayne who actually does all of their transmission work and he said there's a lot of small differences between the 5th and 5.5 gen transmissions. I'm going to continue to dig a little deeper with some additional sources I have.
Old Jun 17, 2011 | 01:38 PM
NmexMAX's Avatar
dot dot dot ...
That's good news for swappers. i know of a few A32B's that their tranny took a poo shortly after a swap.
Probably a combination of age and torque.
Old Jun 17, 2011 | 01:43 PM
ffcbairn's Avatar
What is typical for the 5.0s/5MTs? I get about 24 city and 30 highway (calculated miles driven divided by gallons to fill). IMO this was always higher than what I generally see so I haven't put much effort into improving my mpgs.
Old Jun 17, 2011 | 01:46 PM
NmexMAX's Avatar
dot dot dot ...
For the Love of God, let's not go there with this thread
Old Jun 17, 2011 | 02:04 PM
ffcbairn's Avatar
So wait everyone else can discuss what they get with 5.5/6MT and 4AT but I mention the 5MT and suddenly it's a problem?
Old Jun 17, 2011 | 02:08 PM
NmexMAX's Avatar
dot dot dot ...
No, not you, but I had a horrid visual of what this thread may turn into.
Now I'm starting to wonder what I would get if I didn't have the AC on the whole way and shaved off 500-600 pounds. Planning on replacing my bad cats with headers in the future and will need to install my plenum spacers and possibly a BOP.
Old Jun 17, 2011 | 02:09 PM
NmexMAX's Avatar
dot dot dot ...
500-600 lbs, Jesus!
Old Jun 17, 2011 | 02:11 PM
ffcbairn's Avatar
Not much on the highway. Weight and AC are really only economy killers during stop and go, once you are up to speed it is simply a matter of maintaining and your economy will peak.
Also from my searching it seems like you won't be able to get much more than 200 pounds off and at that point you won't be able to take passengers any more Also as part of your weight removal you will be taking out the compressor so you won't have to worry about AC afterwards lol
Old Jun 17, 2011 | 02:17 PM
kukx30de's Avatar
Lol... Well in that case your 6 Spd needs some tuning too buddy.. My 5spd 330 does almost 34 mpg calculated!
Old Jun 17, 2011 | 02:19 PM
by shaving off 500-600 pounds I meant not having a bunch of passengers and a full trunk. basically just me and my own luggage or possibly one other person.
Old Jun 17, 2011 | 02:27 PM
kukx30de's Avatar
That shud probably bump you into the 32-33 mpg range easily!
Old Jun 17, 2011 | 03:09 PM
Trakkon14's Avatar
thats cool that you got 30 mpg.
Old Jun 17, 2011 | 06:30 PM
crazy97's Avatar
Maybe if a 30mph wind is pushing you...
Old Jun 17, 2011 | 08:14 PM
I'm just giving my personal experience. My car tends to do better when I'm going about 70-75 versus when I'm going 60.
Old Jun 17, 2011 | 08:53 PM
00Lightsout's Avatar
S**t...i'm in the 17/18 range b/c i've got 1 bad precat with an auto. Man, what I would do to swap all my stuff to a 6MT!! That's it...i'm pull'n my y-pipe right now(at least start that phase tonight)...
did it...and now it's time to fab up my own 3" y-pipe into 3" cat+catback....then wrap it in heat shield
Old Jun 17, 2011 | 09:25 PM
rbaksi@gmail.com's Avatar
I don't really think that 30mpg for this is a big deal. Before I got my I35 i had a 95 Trans am with a 5.7L V8 and 4spd Auto. On highway trips back and forth from school I would regularly see 30-31 mpg. And i would have the car stuffed to the roof with stuff. Probably because the rear end ratio was low enough that the engine would be turning at 16-1700 rpm at 70mph. Boy do I miss that cruiser.
Old Jun 17, 2011 | 09:55 PM
2000_MAXIMA_KING's Avatar
Hey my 4AT does 31 mpg on the highway and that's calculated true mpg not some estimated dashboard read which is always innacurate. Too bad it only does 18 mpg in crappy Chicago city driving. I really found it weird when I was able to get 400+ to the tank with mixed driving mostly on highway and out of Chicago (25mpg), and driving in Chicago I only get 18 mpg. That's a big difference!
Old Jun 17, 2011 | 09:59 PM
Sheesh.
My MKV VW has a 6AT, beat that
Old Jun 17, 2011 | 10:28 PM
It probably isn't to many people. It was just a goal I had in mind. Seeing as how I live in a city that has a significant amount of stop and go traffic, 30 mpg isn't something I always see even on my 1.5L Mitsubishi Mirage or 1.7L Civic EX when driving mostly city.
That's not to say I haven't seen over 35 mpg from both of those cars, but I like to see if the car I've switched to is capable of breaking that 30 mpg barrier. I don't do regular all highway trips and for this roadtrip, I was excited to see if it was capable of doing so.
Old Jun 18, 2011 | 04:35 PM
MONTE 01&97 SE's Avatar
Absolutely, as the 5spd auto in the 6th gen is crap.....Failure after failure/issue after issue. They have tons of failure threads and a class action Lawsuit thread about it in the 6th gen forum. As you posted further down, there are several internal differences that strengthened the 02/03 and early 04 SL Maxima 4spd auto from the older ones to handle the additional torque and power. Nissan also stated back then that they beefed it up quite a bit for the 02 Max.
Old Jun 20, 2011 | 10:37 AM
NmexMAX's Avatar
dot dot dot ...
I used to get 30+ MPG from my VQ30. Not too common with the 4AT and 3.5L.
7AT from the new Infiniti G.
I still say MT > AT no matter how many gears.
Old Jun 20, 2011 | 10:57 AM
jr schultz's Avatar
I've been changing my driving habits lately to improve fuel economy. www.cleanmpg.com has a lot of tips to do so. Some "hypermiling" tricks are easy to implement, and some may be a bit extreme for some. A simple highway trick I found is instead of using cruise control you drive with load. That means keeping the engine at a constant load, rather than maintaining a constant speeed. For instance...Approaching a hill driving in cc the car will maintain the speed by increasing engine load. That wastes a bit more gas. It's better to keep steady pressure on the gas pedal and allow the car to bleed a little speed going up a hill and regain the speed going down the hill. This can be monitored with those that have a VAFC/SAFC by looking at the % of throttle. I actually purchased an Ultra-Gauge that plugs into my OBD2 port allowing me to have various gauges to watch including instant MPG and Engine load %.
Old Jun 20, 2011 | 02:24 PM
^ good point. When It got to hilly areas, I took it off of cruise control. I'd hold steady for uphills and throw it in neutral for downhills depending on how steep it was. Cruise control is useful, but when driving on roads that aren't flat, it's not necessarily the best way to obtain higher fuel economy.
Old Jun 21, 2011 | 01:04 AM
tcb_02_max's Avatar
"throw it in neutral" FTL
Modern cars will cut fuel to the cylinders when you are a little above idle (~1000+ rpm) and coasting in gear (i.e. throttle closed). Shifting to neutral thus uses more fuel...
