SC'd Manual Owners....advice/help!
Old Dec 28, 2001 | 06:42 AM
Deac's Avatar
I finally got my car back from the shop...SC installed! But on my initial run, testing it out, I noticed that while I was coasting along at about 80mph, I took it out of gear and let it coast...but the RPM's dropped all the way down and the car shut off while I was coasting at between 70-80 mph!!! Of corse when I threw it back into gear, the car cut back on. When driving normally in traffic, it idles fine but when I'm at higher speed and I take it out of gear, it cut off a couple of times! It dosn't seem like a big deal but it didn't do this "pre-SC" so I need to get this right! I guess I should take it back to these guys and let them look at it again! Has anyone else with a manual sc'd max noticed this problem...and if so is there a simple fix? I guess I'try Stillen tech support also but if anyone has any info, let me know...Thanx.
Deac
Old Dec 28, 2001 | 07:15 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
You are bleeding off too much air through your BOV... tighten it a bit and try again.
Did you get the intercooler installed yet? How much boost (or what size pulley) are you running?
Old Dec 28, 2001 | 07:29 AM
Sprint's Avatar
you don't own an SC'ed Manual
Old Dec 28, 2001 | 07:33 AM
Y2KevSE's Avatar
You don't own a SC at all so why'd you reply?
Old Dec 28, 2001 | 07:35 AM
Sprint's Avatar
I wasn't trying to answer his question
Old Dec 28, 2001 | 07:37 AM
Y2KevSE's Avatar
SC owners talking... step away NOS boy.
Old Dec 28, 2001 | 07:38 AM
Sprint's Avatar
I have half the right to be in this thread as you do.. SC'd Manual owners.. you have an SC.. i have a Manual.. if you can be here.. i can be here
Old Dec 28, 2001 | 07:40 AM
Y2KevSE's Avatar
But he put "SC" before "manual" so it relates more to me than you.
Old Dec 28, 2001 | 07:44 AM
Sprint's Avatar
yes but your rpm's wouldn't drop at high speeds because you are not SHIFTING MANUALLY and you don't have a CLUTCH so the title may relate to you.. but the problem lies more in my area
Old Dec 28, 2001 | 07:47 AM
Y2KevSE's Avatar
So did you really know how to answer his question regarding stalling? This doesn't really happen if you're N/A or nitrous'ed, right?
Old Dec 28, 2001 | 08:16 AM
Sprint's Avatar
Actually i do.. when lots of carbon builds up or the Butterfly in the TB starts to stick.. this will cause stalling.. so it might be realated somehow.. who knows
Old Dec 28, 2001 | 08:28 AM
Y2KevSE's Avatar
Riiiiiiiiight..... but not in this case.
Old Dec 28, 2001 | 08:51 AM
Sprint's Avatar
wrong.. in every case
Old Dec 28, 2001 | 08:59 AM
Y2KevSE's Avatar
OK, time for you to step away from this thread... nitrous *****.
Old Dec 28, 2001 | 09:06 AM
Sprint's Avatar
i will step away .. when you step away.. auto *****
Old Dec 28, 2001 | 09:12 AM
Y2KevSE's Avatar
You dyno yet?
5th gen variable intake ownz jOO.
Old Dec 28, 2001 | 09:15 AM
Deac's Avatar
I'll try that...
Thanx Kev,
I'm at work now but tomorrow I'll tighten the BOV and try it again...It did seem to be a simple fix. The guys told be to break in the SC for about 2 weeks before they start the install on the intercooler...the guy that doing it will use the piping from my Place Racing CAI and customize it for my intercooler...I'm still running the stock pulley though...
Deac
Old Dec 28, 2001 | 09:16 AM
Sprint's Avatar
You dyno yet?
no
lack of torque apparently ownzs jOO
Old Dec 28, 2001 | 09:19 AM
Y2KevSE's Avatar
Re: I'll try that...
Originally posted by Deac
Thanx Kev,
Deac
No need to break in the SC. You can floor your car as much as you want... if you haven't already, reset the ECU.
Old Dec 28, 2001 | 09:22 AM
Y2KevSE's Avatar
no
Only by 7 ft-lbs.
Lack of breath up top ownz jOO.
Old Dec 28, 2001 | 09:24 AM
Sprint's Avatar
Only by 7 ft-lbs.
too bad NOS Maxima's with the same hp put out 100 ft-lbs more and you got beat by a Maxima with 40 less hp having more tq than you
Old Dec 28, 2001 | 09:32 AM
Y2KevSE's Avatar
Thomas is an exception. Let's see your dyno (with bent valve and all).
Try and take a deep breath Sprite... What? Can't? Sorry, forgot you had a 4th gen. What?
Old Dec 28, 2001 | 09:45 AM
Deac's Avatar
Re: Re: I'll try that...
Didnt know about the ECU reset...why do I need to do it and how do i do it?
Old Dec 28, 2001 | 09:53 AM
Y2KevSE's Avatar
Re: Re: Re: I'll try that...
If you can get access to a scan tool then you can reset it easily, otherwise disconnect your negative terminal and leave it off for about 3 hours.
Old Dec 28, 2001 | 09:58 AM
Sprint's Avatar
do i have to bring out stone cold and his dirty mouth?
Old Dec 28, 2001 | 10:04 AM
jsangha's Avatar
How much did the install cost?
What type of shop was it that did the install?
Thanks,
Jay
Old Dec 28, 2001 | 10:37 AM
Max_Gator's Avatar
yawn . . . SSDD.
Old Dec 28, 2001 | 11:03 AM
jsangha's Avatar
Originally posted by Max_Gator
yawn . . . SSDD.
Then get a life!!!
Old Dec 28, 2001 | 12:30 PM
ehughes's Avatar
This is all very interesting...but lets cut to the real question:
Sprintmax VS. Y2Kevse...1/4 mile...who wins? Tq, no Tq...Hp, no Hp...does not matter. Who wins?
Should we start a thread to this effect?
Old Dec 28, 2001 | 12:33 PM
Sprint's Avatar
Old Dec 28, 2001 | 12:40 PM
ehughes's Avatar
That's what I thought.
Good luck Deac!
Old Dec 28, 2001 | 04:11 PM
Y2KevSE's Avatar
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
