flywheel torque specs
Old Aug 8, 2011 | 01:53 PM
dnice02's Avatar
I tried looking at the fsm from nico club but it's acting crazy. Can some one tell me the torque specs for the flywheel? Also any tips on hold the motor from rotating while tightening? thanks
Old Aug 8, 2011 | 02:31 PM
nelledge's Avatar
"I'm just sayin'..."
61-69 ft*lb Feel free to PM me if you need any tips for changing it.
Old Aug 8, 2011 | 02:35 PM
aackshun's Avatar
Long breaker bar on the crank bolt, that's what I did yo.
Old Aug 8, 2011 | 04:12 PM
datsunzcar84's Avatar
Don't forget the loc-tite just to be safe.
Old Aug 8, 2011 | 04:28 PM
QT1 5MT AE's Avatar
Gram Lights addict
for OEM or fidanza? +1 on loctite
Old Aug 8, 2011 | 05:33 PM
dnice02's Avatar
Fidanza and I have thread lock on hand
Old Aug 8, 2011 | 08:14 PM
nelledge's Avatar
Reference post #2. It is the specification given by the FSM.
Originally Posted by fidanza.com/FAQ
WHAT TORQUE SHOULD I USE TO TIGHTEN MY NEW FLYWHEEL? – For both the clutch and flywheel mounting bolts you should follow the original manufacturers torque specs for your car. We do recommend using a small amount of semi-permanent Loctite on the flywheel mounting bolts. We also recommend replacing both sets of bolts. These can be gotten from your local dealer or from a company such as ARP Fasteners.
Old Aug 9, 2011 | 04:42 AM
Shift_Max's Avatar
Make sure its on right so the timing is correct for the maxima and not the 350z.
Old Aug 9, 2011 | 05:34 AM
dnice02's Avatar
Yeah thanks I made a little mark on the front to ensure I set it on fwd.
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
The Wizard
24
Oct 1, 2015 08:47 PM
