That vibrating license plate...
Old Aug 10, 2011 | 02:17 PM
xfimpg's Avatar
Hi Folks
My license plate only has screws on top, none on the bottom and it vibrates incessantly when the music is slightly cranked up.
Does anyone have any experience or ideas for quieting down the vibration?
Or do I have to drill holes and add 2 more screws to secure the bottom?
Old Aug 10, 2011 | 03:46 PM
RA121625's Avatar
3M double sided tape works wonders.
Old Aug 10, 2011 | 05:34 PM
djshwini's Avatar
Put a small amount of dynamite behind the plate and it will completely quiet.
Old Aug 10, 2011 | 06:25 PM
cammo's Avatar
3m tape or foam tape the back of your license plate. will get rid of almost all vibration
Old Aug 10, 2011 | 06:33 PM
Nelsito65's Avatar
To the OP, if you put dynamite behind the plate, be sure nobody smokes around it; it could get pretty ugly. ...or you can try Dynamat...
Old Aug 10, 2011 | 08:45 PM
nismopc's Avatar
I use black plastic license plate screws for the top and bottom. On the bottom, I purchase rubber nipples (vacuum hose caps), cut them to length of the screw and then push screw into them. Looks like license plate is mounted with all 4 screws and the rubber keeps it from vibrating against the car...
Old Aug 11, 2011 | 04:30 AM
Gizm0's Avatar
Just remove it
Old Aug 11, 2011 | 04:50 AM
xfimpg's Avatar
Good idea, even better than the dynamite, which would quiet a lot of noises.
Is this what you mean by vacuum hose caps?
Old Aug 11, 2011 | 04:52 AM
xfimpg's Avatar
I'm thinking that if the top screws are screwed inside the sheet metal, doesnt that mean that the bottom screws will push the license plate outwards, even may have to bend it?
Trying to visulaize...
Old Aug 11, 2011 | 07:56 AM
zero2sixtyZ's Avatar
You embarrass me.
Dollar store, cheap sponge, shove it between the plate. Will work better than dynamat, I promise.
Old Aug 11, 2011 | 08:08 AM
nismopc's Avatar
YES! I use the black ones that are readily available at all local parts stores.
Not at all. Let me see if I can get a picture of it. Looks perfect...
Just make sure you use the plastic license plate screws or same length metal screws.
Old Aug 11, 2011 | 07:05 PM
xfimpg's Avatar
lol
i'll try the different options here and see how it goes!
methinks that removing the plastic license plate liner would solve most of it.
Old Aug 11, 2011 | 07:53 PM
sascuderi's Avatar
put a small amount of clear caulk behind the lower section of the plate..thats what I did to stop the rattle when you close the trunk
Old Aug 11, 2011 | 08:15 PM
xfimpg's Avatar
not the rattle for the trunk so much as for the bass.
Old Aug 19, 2011 | 05:01 PM
xfimpg's Avatar
I followed your suggestions and placed the 3m tape under the license plate and got rid of the hard plastic liner the dealership provided.
There is still some vibration, but it's coming from top of the trunk where the sub-woofer is located. Do I assume the vibration is normal or should I checking for loose screws or adding 3M tape in some strategic places?
Old Aug 20, 2011 | 05:53 AM
hondaeatingtsi's Avatar
i bent my plate slightly so it would make any noise. and it was free!!
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
ricky7780
Sep 24, 2015 06:50 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
