tach needle lag
Old Aug 12, 2011 | 03:56 PM
michael454rs's Avatar
tach needle lag
Hey everyone boguht a cluster to fix my gas gauge problem fix the gas gauge work fine now but the tach on the new cluster seems to no work correctly when i received it the tach needle was not resting on the black small needle. Took off the front plastic cover moved it back but when i rev the needle seems to lag a little. Should i give it some time to see if it will adjust or is this an easy fix. Thanks in advance.
Old Aug 12, 2011 | 04:04 PM
T-Mon3y's Avatar
Return it and get a new one. it won't "adjust" it's broken.
Old Aug 12, 2011 | 08:16 PM
Is it possible to replace the stepper motor? With a working one from another tach
Old Aug 16, 2011 | 07:32 PM
FrankA33's Avatar
I have the same issue, anyone else can chime in on this ?
Old Aug 16, 2011 | 07:58 PM
I returned the cluster. Going fork over 700 for a new one looked everywhere cant find one
Old Aug 16, 2011 | 10:11 PM
datsunzcar84's Avatar
700? Ouch that's a hard pill to swallow .
Old Aug 17, 2011 | 07:32 AM
I know but i have to do it seems i cant find a good working used replacement
Old Aug 17, 2011 | 08:24 AM
djfrestyl's Avatar
Suspension Yoda
$700? That's ridiculous.
Junkyards? www.car-part.com. I'm sure a junkyard somewhere in the US will ship you one for significantly less than $700. Good luck.
PS - you've got PM
James92SE
142
Jan 2, 2024 09:23 AM
captchaos
Mar 15, 2016 12:18 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
Justinmc760
Aug 23, 2015 03:10 AM
maximaham
Aug 7, 2015 01:11 PM
