tire pressure?
Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
Originally posted by BuddyWh
This leads me to draw a controversial conclusion: what difference does it make how it behaves? so what if a tire pressure change has altered it "for the worse"? I can't deal with it (at the limits) even if it were at it's best... it's a given I would probably loose it as I am just not trained to deal with it. What I should do instead is optimize within the areas I do drive, and focus on staying out of the regimes in which I don't drive.
For anybody who normally drives mildly to moderately, I'd strongly recommend staying close to the OE recommendations. Those who regularly explore substantially more of their cars' capabilities can be expected to eventually develop enough experience and "feel" to deviate a little further. That does sort of tie in with the concept of tuning for "preferred behavior in the regime that you mostly drive in", in that the normal range of driving intensity is somewhat wider for the hard driver and the gap between normal driving and limit behavior is somewhat smaller. I'll add here the strong caution to avoid overestimating one's abilities.
But then, I read another article that actually advocates leaving pressures at around 35-38 PSI (if normal is 31-33). Why? it's a safety thing again: so many people neglect checking pressure for so long, the idea is to delay when the pressure drops to into the extreme hazardous range of the teens that much longer. Go figure!
That's scary, for that much extra pressure to be (apparently) publicly recommended without regard for individual drivers and vehicles. All in deference to lowest-common-denominator mentality in not making such a simple check. Aaaaarrrggghhhhh!!!!
Norm
Re: Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
Buddywh
AWESOME Info....(LONG)
I'm just sorry I didn't learn all this sooner. I too am one of the "myth" believers who really didn't know jack about what I was doing to my car or risks I've been taking. I figured 43psi F/R cold pressure(44psi rated MAX pressure on the side wall) with typically 2.5 people and moderate luggage was my best choice in pressure, since it's all hwy travel and I was more interested in reducing rolling resistance to make the high speeds easier on the engine. I don't really care about fuel economy or tire life, just engine wear.
Now I realize, I regularly like to push the canyon corners for about a 20-mile section of my monthly 380-mile trip, which never "scared" me, but felt a little twitchy. I just figured it was the floaty suspension and that I needed a FSTB, RSB, and to lower the car some or at least do near speed limit. I'm betting HIGH tire pressure is adding to the feeling.
My car sees pretty much 95+% hwy travel at an average of 80-95mph. However, I pretty much ALWAYS have 40+psi, when I actually drive the car around town. I knew the crappy ride was aggrevated by the higher pressure, but really didn't think it would make that much difference. Now I realize, I've been playing with fire and should IMMEDIATELY drop to 1-3psi ABOVE manufacturer specs(32psi?) F/R for my stock 17" blowtenzas.
Now that you've guys made me realize how STUPID I was being, it will be corrected as soon as I get home.
BTW, I have pushed the car to it's limits and slightly beyond once or twice. At least enough to start sliding(pushing?), but at VERY low speeds on a switchback with decreasing radius corners. It felt very controllable, but of course this has NO relevance to emergency high speed handling. I just thought I should try and as safely as possible feel what the car does when it begins to "let go".
Questions:
1) How do I know what tire pressure to run once I upgrade to say 18" or even 19" rims and tires?
2) How will I know what tire pressure is applicable for MY vehicle when all I'll have is the MAX pressure on the side of the tire?
I will keep the overall rim/tire diameter as close as possible to OEM to keep the speedometer accurate.
AWESOME debate guys!
Questions:
Re: Re: Re: Re: tire pressure?
Originally posted by Larrfry
You are right --- no one cares. But they(your rims) are a thing of rare beauty and I'm sure your 17" (bigger is better - right?) are Formula One in handling. Thanks for informing us. I'm sure they kick "****", whatever that means, and I'll change my pressures immediately!
Another intelligent post from the members of Maxima.org. God help us
Re: AWESOME Info....(LONG)
Questions:
Questions:
It is very hard to really balance a car and I repeat - manufacturers are pretty close to being right. Without training, a test facility - (I know you don't want to hear that, but it is true), it is impossible to really set your car up beyond what the manufacturer has recommended. If you look at some of the posts, the pressure suggestions are impossible - simply stupid - yet believed by their authors. Those recommendations are the results of beginners who havn't crashed yet / nothing more.
Regarding bigger tires. The Maxima really doesn't handle very well. It lifts a rear tire when cornering and is somewhat unstable. So I question a move to bigger tires when so much more needs to be done to make it stable. IN SHORT - Why - bigger tires or low profiles with a marginal handling vehicle??? You don't have much to gain! Big bucks/ little or no gains. WHAT WOULD BE BETTER IS A WAY TO TAME THIS INSTABILITY. If one is after "cool looks" - I guess ultra low profile tires meets the current standards. Looks good performs little better--- being the current fad. Tires help a good handling vehicle perform significantly better but, to a much lesser degree, do great tires help a poorly handling one. The Maxima, at least in 2000, is very marginal in its handling. Save your money on larger tires unless you are looking to impress the uninformed.
Larrfry
Re: Re: AWESOME Info....(LONG)
Thanks for the post. Makes me feel not every word has been in vain. It is so hard to really balance a car and I repeat - manufacturers are prety close to being right. Without training, a test facility - (I know you don't want to hear that, but it is true), it is impossible to really set your car up. If you look at some of the posts, the pressure suggestions are impossible - simply stupid - yet believed by their authors. Those recommendations are the results of beginners who havn't crashed yet/ nothing more.
Regarding bigger tires. The Maxima really doesn't handle so good. It lifts a rear tire when cornering and is somewhat unstable. Why - bigger tires or low profiles with a marginal handling vehicle??? You don't have much to gain. Big bucks/ no gains. WHAT WOULD BE BETTER IS A WAY TO TAIM THIS INSTABILITY. If you are after 'cool looks" - I guess low profile meets the current standards.
The bigger wheels are for looks mostly. The low profile is also mostly for looks, but mainly to keep the overall diameter the same to keep the speedometer and odometer accurate at least until the warranty wears off.
So with a different brand, but same spec tire for my stock 17" rims, should I still run the FACTORY recommended pressures? I'm sure this is what you've said, but I'm just double checking, since I'll probably need another set of tires before I go with 18-19" rims/tires and all I have to go with is the MAX pressure on the sidewall.
Once I go bigger, how do I know what psi to run since the FACTORY recommendations won't apply? I don't mean optimal for performance, just safe. Do I look at what the tire manufacturer recommends and then try to guesstimate according to what Nissan recommends for a Maxima according to it's load capacity?
Thanks.
Re: Re: Re: AWESOME Info....(LONG)
No, thank you for the reply. It's definitely NOT in "vain". You will NOT hear from at least 90% of the people who will value and appreciate your information. We here at the .org have a habit of only responding when we DISagree or feel the need to flame, so if you only get a limited response(mostly by flamers) do NOT think your posts are in vain. Lots of others(myself definitely NOT included), prefer to only read/learn from the wealth of information here and stay out of the cat "fights" and debates.
That makes sense, but you know what - it hard - I want an intelligent debate and I am sick of flammers. I don't want a cat-fight. It is a waste of time and frankly depressing. Secondly, one only engages in a debate to learn more!!!!
In short, thanks for your post and encouragement!
If you are running the same diameter wheels, and same stock tires ----- stick with manufacturer's pressures.
Second point - why are changing wheels and tires in the future??? For looks??? The Maxima is , at best, mid horsepower, so more rubber on the ground really doesn't give up much on acceleration?
I have no idea nor has a single post suggested they have an idea!!!!!!!!!!!!!!!!
The sidewall lists MAXIMUM HOT PRESSURE, meaning what the manufacturer figures is very close to dangerous - Hot Pressure. I've seen pressures jump 8psi in minutes on a track or autocross or maybe , in aggressive driving. Forget even looking at maximum sidewall pressures as a guide!!!!!!!!!!!!!!!!!!!
Thanks.
Thanks.
Re: Re: Re: Re: AWESOME Info....(LONG)
In short, thanks for your post and encouragement!@
Just kidding, but I've learned more than I've ever cared to know debating with some of the "oil" gurus.
One more question:
Would an Infared Thermometer allow me to "test" a few tire pressures once I get 18-19" rims and lower profile tires? If so, what would be some valid/conclusive tests to perform? I'd like to see what's happening to my tire pressures while NORMAL driving at hwy speeds at least. Actually, I'll probably get the "Smart Tire" tire pressure monitoring system once I change tires, so that would be easier to monitor and study.
Re: Re: Re: Re: Re: AWESOME Info....(LONG)
Over simplifing the article: you exercise the tires hard, and sustained. Then measure the temp's of the tread surface to ascertain if 1) all tires are working equally hard and 2) the contact patch is equal to the tread area. This all requires a good track so you can avoid worrying about traffic. And all this does is find a pressure where the tires work optimally (not necessarily handle optimally... or safely) on that track! There is much more involved to get the car to handle well.
I think the gist of this whole thread comes down to: if you aren't driving under track conditions, why even try to find an optimal high(er) pressure for handling purposes? The mfr's suggestion is the safest, so stay within a few pounds of that. BUT, the situation you have is interesting, and really applies to everyone else with big wheels/low profile tire combo's (or getting them).
I would ask the question like this: is the data plate pressure still correct for these wheel/tire combo's? if not, how to determine it?
BuddyWh
Totally agree. No problem. If you really want an intelligent debate, go make up some BS story about how synthetic(particularly AMSOIL) suck and post it in the General forum.
Got it, thanks.
Looks and maybe a little function. Supposedly with 8" wide aftermarket rims, I can safely run wider tires and SHOULD have better grip in corners and launching at the track. However, if I my new rims/tires add more unsprung weight it'll probably be counterproductive on braking, acceleration, and handling, but that's the price I'm willing to pay for losing the common Maxima look.
Man that's scary. I've been running 43psi cold F/R! Who knows how hight the HOT pressure rose, while I'm crusing at 85-95mph. I've even ran up to 130 and 142+ once each, without even considering it.
One more question:
Just kidding, but I've learned more than I've ever cared to know debating with some of the "oil" gurus.Got it, thanks.
One more question:
I think something is very wrong in your analysis. Otherwise Nissian is making a massive engineering error and also creating a huge opportunity for lawsuits. That's NOT the case, I believe, here's why.
Remember - first the GVWR (for non-techies that means the weight of the Maxima plus the weight of 4/5 average passengers and their luggage) is the maximum design specification. In my 2000 it is 4333 pounds. That's the absolute total weight for the vehicle with passengers and luggage. HOWEVER, that weight is shared over FOUR tires - not one!!!!!!!!!!! I think you made that mistake in your analysis - correct me if I am wrong. I don't want to get overly technical but on the label you are referring to it also lists maximum front end weight because this is a front wheel drive car with most of the mechanicals up front and therefore most of the weight. Again, even if you look at maximum loading at the front - this is divided by two. I think you'll find none of the tires are close to being overloaded at stock presures but I don't have the charts for your tires to confirm that. But I bet there is excess reserve in abundance!!!!!!.
Finally, maximum tire pressure as embossed on the sidewall of the tire refers to HOT, ABSOLUTE MAXIMUM PRESSURE - not cold. I'd refer you to Road and Track, June 2002, pages 155 to 157
Larrfry
Larrfry
Wish BuddyWh had responded. I think it is important once one expresses a view to either defend it or say " I made a mistake".
Larrfry
Let's see if I understand what you're saying, Larrfry . . .
Originally posted by y2kse
Hi Larrfry --
I'd like to come off topic for just a moment. As you can see from my sig, I've (erroneously) earned the title of Master of All Things Rubber. That's because of the hard stance I've taken against running tires that are out-of-spec for the rims on which they're mounted. Specifically, a running debate exists on the org about whether or not it's safe to mount 235/45R17 and 245/45R17 tires on the stock 5th Gen OEM rims. The OEM rims are 7.0" wide. However, the Tire & Rim Association as well as every manufacturer of tires in those sizes states that 7.5" is the minimum acceptable rim width. (The T&RA contour tables are posted on page 5 of the FAQs if you want to take a look at them.)
Do you have a position with respect to this issue? In other words, do you believe it's safe to exceed manufacturer specifications with respect to acceptable rim/tire combinations? If so, would be good enough to share your view with us?
Hi Larrfry --
I saw this in one of your previous posts:
"Regarding bigger tires. The Maxima really doesn't handle very well. It lifts a rear tire when cornering and is somewhat unstable. So I question a move to bigger tires when so much more needs to be done to make it stable. IN SHORT - Why - bigger tires or low profiles with a marginal handling vehicle??? You don't have much to gain! Big bucks/ little or no gains. WHAT WOULD BE BETTER IS A WAY TO TAME THIS INSTABILITY. If one is after "cool looks" - I guess ultra low profile tires meets the current standards. Looks good performs little better--- being the current fad. Tires help a good handling vehicle perform significantly better but, to a much lesser degree, do great tires help a poorly handling one. The Maxima, at least in 2000, is very marginal in its handling. Save your money on larger tires unless you are looking to impress the uninformed."
If I read this properly, your position is that whether or not a tire/rim combination on a 5th Gen Maxima is out of spec, you would NOT recommend running a tire larger than the OEM size of 225/50R17 for handling reasons alone. Is that correct?
Re: Let's see if I understand what you're saying, Larrfry . . .
Hi Larrfry --
Hi Larrfry --
I thought I responded TO YOUR PREVIOUS EMAIL (including your private emails asking for my support??)
Maybe not.
In short - I'd never violate the manufacturer's recommendations without EXPERT knowledge. Regarding handling - I don't think there is much to gain with wider tires but a wider tire always affords some degree of better handling in the dry - asumming the tire stays on the rim!!! So in theory, yes - a wider tire is better in the dry but it may be completely unsuitable to the rim and therefore dangereous.
I think the instability of the Maxima is a key issue in getting this car to handle and larger tires (within/without the manufacturer's specifications) will NOT produce significant improvements
First - y2kse - has done a great deal of research - and I respect that. I don't have any expertise on rim/tire size except that I would respect what the manufacturer said as well as what tire companies and wheel manufacturers have said. I certainly have no special expertise in that regard and would look to what the car/tire/wheel manufacturers had to say. Thankfully, y2kse has done the researcH!! Every source supports y2kse's position!!!! I GUESS IF YOU HAVE EXPERT KNOWLEDGE, VIOLATE That data BUT THEN TELL US WHY.
Regarding wider tires in general, forgetting whether they fit on the rim or not, they have to give marginally better acceleration or cornering in the DRY!!!! In theory, that has to be true but ignores the very significant problems that y2kse has raised regarding overSize tires!!!!
Secondly wide tires produce VERY negative results in the rain!!!!! Hydroplaning is a result of tire pressure and tire width - largely. Also with a car like the Maxima , which has significant problems cornering and really isn't capable of accelerating aggressively because it is front wheel drive - I question any emphasis on larger/lower profile tires. Very little to gain by changing the tires - period.
Larrfry
Hmmmmm. No comment, Larrfry?
Pushy!!!!!!!!!!!!!!!!!!!
I don't read the posts on a daily basis.
I support your general views regarding oversize tires -- they are well researched. But please don't put words into my mouth!!!!!!!! While I support your general premises, I resent your public/private emails that attempt to dictate my position.
I'd predict some flamming now.
Thank you for supporting my position.
Larrfry
Larrfry
The problem is... Yokohama has changed their site and I can't find the load/pressure tables for my tire anymore. This seems to be the problem with most p-metric tires: there seem to be no published pressure/load tables, unlike LT tires which mfr's do publish.
Your argument for not straying far from the vehicle recommended pressures seems to be one of assured safe handling. I agree that is a good rule to follow if not also straying far from nominal loading.
My point is that, operating within the bounds of the tire's max pressue at top and the mfr's rec'd pressure, the vehicle is perfectly safe, except with regards to handling.
So consider the following: when four adult passengers and their weekend luggage are loaded into a Max, that handling has been severely affected. This is the baseline from which we are operating: a severely compromised vehicle. Is the car overloaded beyond the GVWR? probably. Is this commonly done? all the time.
What has also happened is, under the greatly increased load, the tire sidewall flexes more and the tire heats more. This temperature rise leads to early tire failure and tread separation at highway speeds. In order to maximize tire performance/life, the pressure has to be increased. You can ignore this principle if you want, but it is clearly evident the safety margin inherent in the original pressure recommendations has been greatly reduced by the extra load. To suggest otherwise is irresponsible.
Furthermore, increasing pressure can only improve handling from the greatly compromised handling situation you started from as sidewall flexure is reduced. Not to that of a lightly loaded vehicle, but we aren't doing this to facilitate auto-x performance, we are doing this to allow a loaded vehicle to travel to it's destination without an accident due to tire failure.
And my observation from any vehicle I have ever owned: handling was/is very bad with a heavy load, just in normal maneauvers. When I increased tire pressure handling always, without fail, got much better and I'd feel safe again on the highway.
I am not saying to exceed the "max pressure" imprinted on the sidewall as you suggest: that is an absolute limit never to be exceeded, cold or hot. And, in fact, one rarely has to get to that point but should feel free to increase pressure to it in order to guarantee their safety on the highway, especially if they aren't sure of their load but know "it's a lot".
After all, that's why it was put there in the first place (and not to make the oil change guy's job easier!)
Finally, IIRC from the tables, in order to operate my Max with the Yokohama OE tires at GVWR I had to run at 35psi which is well above Nissan's recommended but still well below the max pressure on the sidewall, and also well below each tire's max load. I can effectively increase the GVWR of the max simply by increasing the tire pressure further.
BuddyWh
No mistakes made... I stand by what I said.
Hmmm - they must exist
The gross vehicle weight contemplates 4,333 pounds. That's quite a load. About a thousand pounds for passengers and luggage!
I'd agree and disagree - I believe the recommended pressures contemplate these maximum loads (passengers). Lawsuit city if that's not the case!!!!!!!!!! At the same time the safety margins are reduced theoretically but that doesn't mean there still isn't ample cushion!
Again, the myth that higher pressures are always better!!!!!!!!
If you routinely carry close to the maximum weight - a subtle increase in pressures may help
Maximum pressures are that ----- Maximum HOT PRESSURES
Still think you are misreading charts
BuddyWh
BuddyWh
Re: Re: Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
They must exist!
They must exist!
Contrary to any opinion you may voice, increasing tire pressure is the safer for load carrying. It is not a myth no matter how you may like to make it so.
And please, quit trying to imply I am saying to operate beyond the max pressure when I have clearly stated that it is the max pressure whether cold or hot.
BuddyWh
They must exist!
They must exist!
What I was doing then was reference my LI 91 tires' rating of 1366 lbs to that table. But for the reasons Norm stated when he revised his posting, that was incorrect.
So, based on what I now know, 1366 lbs would be safe, and give good margin for my front GAWR, at 35psi. But I do NOT know how it compares at 32psi! On your assurances, I suppose I should feel comfortable that Nissan wants to minimize their exposure and will have spec'd it correctly. Like Ford did with Explorers.
I still stand by the premise of my statement: it is safer to increase pressure when loading a vehicle. Even if not necessary, it poses by far the lower risk vs. NOT increasing pressure and running under-inflated for the load. There is NO DOWNSIDE to doing so and much safety advantage to be gained.
This is what the ITRA has to say about the max-pressure being present on the sidewall as they defend keeping it.
http://www.itra.com/NHSTAtirelabeling.html
"We clearly understand that the maximum inflation pressure marked on todays tires is normally higher than the recommended pressure. However, in most cases, it is not high enough to create major problems, and it presents less risk than if the markings are removed from the tire and replaced with a load symbol that some people may not understand."
I observe that "some people" should be changed to "most people". I cannot find any decent information on the LI system, short of purchasing the commercial specifications.
BuddyWh
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
And it WAS lawsuit city... have you forgotten the Firestone/Bridgestone Ford debacle?
Buddywh
Buddywh
The Ford/Firestone debacle, having listened to almost the entire testimony was one of Ford blaming Firestone, and Firestone blaming Ford. Firestone blamed Ford for trying to use as low a tire pressure as possible (presumably for ride comfort) that still met the FULL Load rating of the Firestone tire with almost no margin for error. In short , from Firestone's point of view the tire was loaded at absolute maximum with zero room for error. In fact, a higher pressure was recommended by Firestone to Ford.
Ford said their recommendations met the load specs of the Firestone tires. They also noted the tire were often defective. The tires in question had a statistically higher failure rate.
The Ford debacle was, in my view, the result of three causes.
1. Pressure specifications were at the limit for a full load as recommended by Ford
2. Defective tires produced by Firestone
3. Users who never checked their tire pressures, allowed them to run low, and also ran with full loads.
Absent any other data - that is a pretty unique set of circumstances.
That still could be viewed as an endorsement for higher pressures with full loads but it ignores the fact that many manufacturers have already provided a great deal of excess capacity for a full load in their tire pressure recommendations to begin with. A tire chart will tell you all you need to know. More importantly if you start raising pressures indiscriminately you could easily create a vehicle that handles so badly it wants to have an accident.
I wish the world was so simple that if you raise tire pressures really high, you will be safe. Not the case - you can really create a bad handling vehicle with indiscriminate pressure changes!!!!!!
But not accessable.
BuddyWh
But not accessable.
BuddyWh
I'll ignore the fact that you originally thought and even posted your opinion that your Yoko Avid V4 tires couldn't meet the maximum design load that Nissan specified for the Maxima unless they were at 44 psi!!!!!!!!! Now it seems you are sure this was wrong and there is a great deal of margin for error at much lower pressures. In short your recommendation of 44 psi as a minimum pressure, even for full load, was in error by a large amount!!!!!!!!!!!!!
You've now changed your opinion, no problem, except I wish you had added an apology or an edit to your previous post.
Regarding whether I misrepresented your position regarding "max pressure whether hot or cold". If I did, I apologize. I simply don't understand the "hot or cold" references - completely wrong. Apples and oranges. Cold is as close as it gets to a universal standard for good reason. It's repeatable. If you drive, tire pressures can jump 3 -5 - 7- 10- - or more in psi. So I really have trouble with you talking about pressures "hot or cold" like they meant the same thing. That was confusing and you never offered a warning to readers.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
...So I really have trouble with you talking about pressures "hot or cold" like they meant the same thing. That was confusing and you never offered a warning to readers.
When traveling on the highway one should check tire pressures at fill-ups. If ever above the pressure, for whatever reason, it must be reduced to or below that pressure. Hot.
Never exceed, cold or hot. Get it?
It shouldn't be a contest of any sort, it's a simple matter of safety. It is extremely common to see overloaded vehicles on streets, but it is much rarer to see extreme auto-x handling maneauvers attempted. For public safety reasons, it just makes good sense to advise adding a few extra lbs when loading a vehicle heavily.
BuddyWh
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
BuddyWh
BuddyWh
You really don't want they pyro readings...
Max pressure is imprinted on the sidewall for a variety of reasons. One critical user is a tire "professional" for mounting tires. When first mountng a tire, they frequently over-pressure (vs. operating pressure) setting the bead... they must not exceed that pressure. Cold.
BuddyWh
BuddyWh
So you are now aware that cold pressures are not hot pressures and also it appears you now realize that the maximum tire pressure embossed on the sidewall of the tire is an absolute max!! A step in the right direction!!!!!
Now it appears you are struggling to figure whether cold pressures as recommended by Nissan adequately support a heavy load. You have misread tire charts before (as in your post of recommending 44psi) but now your position is that at 35 psi ( a rather dramatic change from your previous post of 44 psi) is fine, in fact, has a great deal of excess capacity even at full load by your analysis. You admit you are unsure whether 32 psi meets the same criteria because you don't have the data. Hmmmm - why express an opinion.
Correct me if am wrong but your current position is that somewhere between the manufacturers recommended tire pressures (which are cold) and the maximum pressures printed on the sidewall of the tire (which are the absolute maximums - presumably hot and very hard to determine) are the correct pressure Range and you also suggest we should adjust the pressures on a daily basis solely so as not to exceed the hot pressure (max pressure) limits!!!!!!!!!
Well, very crudely, you finally have figured out the broad range of tire pressures for the Maxima or any car. Now - how about handling and the best possible pressure RANGE when set from cold ????????????
I guess we could start again at "square one" in this forum, and maybe we should --- thanks to the confusion Buddy has created with his posts, which fragments the whole debate with his confused opinions/posts which lack any real understanding of the issues involved.
I'm not going to repeat all the other posts but I'd advise all to consider Buddy's opinions in light of all the information presented.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
Ok - you now recommend we check our tires at every rest stop. This is unbelieveable!!!! I gather you have now realize that hot ...
Goodbye...
<plonk>
Originally posted by BEJAY1
So 62.5lbs hot fronts is a bit high right? Just got through reading all the posts and had to chime in.
BuddyWh just likes to express an opinion -- no matter how little he understands the issues at hand.
I'm sure anyone, like BEJAY1, who has a clue, will have a similar negative opinion regarding BuddyWh 's posts !!!!!!!!!!!!!!!.
But I worry about those "innocents" who read BuddyWh and actually listen to him???
Larrfry
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: keeping mine at 35-38
You are a sadly confused person who reads what you want to read, and remembers what you want to remember. Any conversation with you would be an exercise in futility. I can see that now.
Goodbye...
<plonk>
Goodbye...
<plonk>
Perhaps....but you won't be surprised if I disagree.
Your various posts regarding tire pressures are filled with misconceptions, bad advice, bad research, and some fundamental misunderstandings.
Set the record straight if I, among others, are wrong. But please address all your opinions starting from your first post.
larrfry
Tire Gauge
Originally posted by 2KSE
I went to the Hunter website and found my Nissan dealer has a GSP9700, I'll probably take it to them when I do A rotate. I should be ready to rotate them the end of January. The web site also mentioned (as someone else did on this thread)that tire pressure effects balance but it didn't say HOW it effected it. I check my tires weekly when cold with a dial guage and keep them right on. A 1/2 lb difference shouldn't cause a vibration should it?
Where can I get a good dial gauge. I want the kind that locks in the measurement until you press a button to release it. Those are the most accurate, right?
Re: Tire Gauge
I have three working gauges - two of a pencil type and one that is a dial gauge. They have read the same over many years. Most gauges seem accurate in my experience and only one gauge (that is the heavily advertised Accu - something)) failed almost immediately!. I'm working from memory but I believe Consumer Reports also found the Accu - something subject to easy MIScalibration.
Re: Re: Tire Gauge
Consumer Reports did a test - sorry I don't have the data in front of me but do a search to see the results. I'm not sure dial gauges or electronic ones are more accurate than others. A few years ago I purchased a pretty expensive gauge made by Accu -something. It was not a wise purchase. I really tried to take care of it but it went out of calibration with the slightest bump.
Re: Re: Re: Tire Gauge
You mean Accu-Tire? The little black digital gauges? Yeah those are horrible. I had one before. I have 2 pencil type gauges right now. I'm looking for a good dial gauge that locks in the reading.
The BEST digital gauge available is supposedly AccuTire(Still looking to order mine). The "pen" gauges are usually pretty accurate and that's what I've been using, but ONLY the digital will allow you to read in 1/2 lb. increments.
Originally posted by spaaz14
Noticed that just 1/2 psi difference between the right and left side tires will result in a shimmy. Car is very sensitive to tire pressure.
My 1997 Max tire pressure label under center console lid states pressure s/b 29 rear, 31 front. If I put in more pressure, I get more vibration.
Re: Re: Re: Re: Tire Gauge
No, he's referencing "TireGauge". If you drop them they will NEVER be accurate again. You can take it apart and fiddle with it till you get it relatively close, but it's never the same.
They are on sale 1/2 price once in a while.
_BR
Re: tire pressure?
Originally posted by rob van dam
what tire pressure should i run in my tires?...i have the stock 17"...AE rims and tires
