Cluster Issues
Old Aug 26, 2011 | 03:46 PM
97KcMax's Avatar
Cluster Issues
My cluster is acting up and I was wondering if i could replace the cluster while keeping my mileage the same? I seen a write up in the How-To section but the link was dead.
Old Aug 26, 2011 | 04:12 PM
michael454rs's Avatar
nop my cluster had a broken gas gauge and burnt out led's. either you buy a used one and have it reprogrammed to your current mileage. funny today i just received my brand new cluster original from nissan came with my current m ileage and its all good now. decided to buy it new because i dint have any luck with the used ones i had purchased. i bought mine from nissanparts.cc give them a call and talk to cliff hes the one that helped me out.
Old Aug 26, 2011 | 08:35 PM
TunerMaxima3000's Avatar
Yes you can, there is a little chip that has to be de-soldered and swapped over, not horribly difficult if you have any soldering experience.
Old Aug 27, 2011 | 11:09 AM
97KcMax's Avatar
So I just read my CEL... And it was a P0500 which is wheel speed sensor A. Now, my car has 16" 4th Gen SE wheels. I think my cluster problem is caused by a misreading of the speed sensor because of the undersized wheels. The cluster just dies like it has no power at all. Im not sure if the issues are related.
Old Aug 27, 2011 | 11:48 AM
nelledge's Avatar
"I'm just sayin'..."
Wheel speed sensor is actually reading the cv shaft ring. It shouldn't matter the wheel size. I doubt your cluster issue is directly related to the wheel speed sensor.
Old Aug 27, 2011 | 03:40 PM
Yup, a bad speed sensor won't cause your problem, although, the speed sensor is not on the CV shaft, you're thinking of the ABS sensor nelledge.
In either case, you're absolutely correct it won't make any difference except the speedometer won't read accurately if the Outside diameter of the tire is different from stock.
On another note, I would suspect this problem is NOT the gauge cluster itself, but rather the power supplyto the cluster. Check the METER fuse in your fuse panel, I suggest replacing it with a new fuse just in case youhave a bad connection.
Old Aug 27, 2011 | 04:29 PM
nelledge's Avatar
Yup, a bad speed sensor won't cause your problem, although, the speed sensor is not on the CV shaft, you're thinking of the ABS sensor nelledge...
Actually, he used the term "wheel speed sensor" which is, indeed, for the ABS.
...wheel speed sensor...
I assumed he would have said vehicle speed sensor if he meant otherwise. My bad.
Old Aug 27, 2011 | 06:10 PM
I guess only the OP can say for sure, however, he obviously pulled the codes, and the SES doesn't go off for a bad ABS sensor, that is the ABS module, which is obviously a separate system and requires complicated methods to check, or the dealer. He said SES was on
And, to bring conclusion to my suspicions, I checked and a P0500 is for the VSS
We are so semantical, no matter which sensor it is, it obviously has nothing to do with his problem
Old Aug 27, 2011 | 07:11 PM
nelledge's Avatar
...We are so semantical,...
I wish that was the first time my arguments were described in this manner.
Old Aug 28, 2011 | 01:39 PM
97KcMax's Avatar
Lol haha. Well now that we got all that sorted out, weird thing about the cluster is that it totally resets, meaning trip mileage and everything. I dont go to my automotive classes this semester so I dont have access to wiring diagrams anymore :/ Could anyone find me which fuses power the cluster?
Old Aug 28, 2011 | 03:11 PM
nelledge's Avatar
This is how to fish.
Start at EL-123.
Old Aug 28, 2011 | 06:25 PM
^ yes.
And as I said, the fuse is clearly labled in the interior fuse panel as "METER", replace that fuse just in case it's bad.
Old Aug 28, 2011 | 08:23 PM
DennisMik's Avatar
nicoclub is playing games with the FSMs. They used to list this as the 2000.5 FSM. What they used to list as the 2000 FSM is now properly labeled as the 2000.5.
The FSM that is currently listed as the 2000 FSM is for the Maxima QV that is sold in Europe. If you read the bottom left corner of FWD-1, it states that it is printed in Amsterdam. At the top of page 2 it says this is for the Maxima QV. I don't know exactly how similiar or different the QV is from the USA early 2000, but it does seem to be based on the early production model we have here in the USA. However there are differences in the electrical section (EL). The US FSM has 370 pages while the QV EL section has 376 pages.
If you go to pmohr's website for the manuals, he has the correct ones. His website is:
http://boredmder.com/FSMs/NISSAN/
Old Aug 28, 2011 | 08:31 PM
nelledge's Avatar
nicoclub is playing games with the FSMs. They used to list this as the 2000.5 FSM. What they used to list as the 2000 FSM is now properly labeled as the 2000.5....
Good to know for future reference. You'll need a slight adjustment, though. The link you posted in not currently active. You'll have to use the cached link for now. Slight modification. Just don't use all caps in Nissan to use it. http://boredmder.com/FSMs/Nissan/
Old Aug 28, 2011 | 08:38 PM
DennisMik's Avatar
My bad. I typed it from my head. I knew there were caps in there, but I got carried away. I use a bookmark.
Old Aug 28, 2011 | 08:44 PM
nelledge's Avatar
It happens.
Old Aug 28, 2011 | 08:47 PM
DennisMik's Avatar
FYI, there are 2 versions of the 2002 FSM. I have them both but I don't have any info as to how you figure out which version is for a specific car. For the 2000 model, I have VIN number divisions.
Old Aug 29, 2011 | 04:17 PM
97KcMax's Avatar
Thanks a lot guys! Will let you guys know what I come up with.
Old Sep 1, 2011 | 12:45 PM
97KcMax's Avatar
Is there a write up on doing this? I have failed in finding anything for this.
Old Sep 1, 2011 | 06:34 PM
^No, if you are interested in doing it I can dig through my pictures and circle the chip that needs to be swapped.
Old Sep 2, 2011 | 04:28 PM
97KcMax's Avatar
I would very much appreciate it!
Old Sep 2, 2011 | 07:24 PM
Viewed with Gauges removed from circuit board.
Old Sep 2, 2011 | 07:32 PM
Oh sorry dude, that's the 5th gen board, I'll leave the pic up though for others.
Here's what your 5.5 board will look like
Old Sep 3, 2011 | 11:33 AM
CobraKing's Avatar
Sorry to hijack the post, but where on the transaxle is the VSS located? My wife's car is throwing P0500 but the instrument cluster appears to be working. Car's about 11 years old, so it could just be the sensor going bad. I'm gonna follow the diagnostic procedures in the FSM but if I have to replace the VSS I'd like to know where I should be looking.
Thanks in advance.
Old Sep 3, 2011 | 11:38 AM
97KcMax's Avatar
I have a 5Gen. Its all good though, thanks man very much appreciated!
Old Nov 10, 2012 | 01:24 PM
DjHackStyle's Avatar
hey guys i need some help i have a 5.5 gen and im trying to transplant the mileage chip into my newer cluster from my old one and my cluster looks completely different than the 2 clusters that tunermax posted up. i have an idea of which chip it could be but im not certain, heres the pictures of my cluster from a 2003, btw i have like 4 of these clusters lying around and they're all 02-03 and look the same
i know the picture quality sucks, its the best the ipod 4 could do!!!
Old Nov 10, 2012 | 02:24 PM
DennisMik's Avatar
I thik the chip is in the first picture, near the top right corner. It looks to be down maybe an inch from the top and in maybe 3/4 of an inch from the right in a small green "finger". The chip should have a number on it, 93C56EN.
Old Nov 10, 2012 | 05:55 PM
Yes looks like this guy
Old Nov 11, 2012 | 10:04 AM
that chip is not soldered from the back its like very flat, looks like hell to take off and transplant.
Old Nov 11, 2012 | 01:43 PM
The circled chip has the following numbers on it, its not exact but similar so i juss wanna confirm with you guys and ill go ahead and transplant it
S93c5
6dv21
3985
Old Nov 11, 2012 | 04:29 PM
Don't remember if there are holes and soldered from the back. If you want to wait I can take a picture of it and check that.
Otherwise you need to post a better picture so we can see the chip.
Old Nov 11, 2012 | 04:47 PM
I juss checked theres no holes, its more difficult than the older clusters i hope it comes out ok i dont wanna mess it up
Old Nov 11, 2012 | 05:24 PM
FLUX. Don't try heating it without flux.
You' should also use electrical cleaner spray for when you are finished soldering back on to clean off all the solder. Most electrical supply shops carry it.
Flux one side then heat all 4 contacts at the same time with a precision flathead under the center of the chip, twist the flathead so that it lifts on the portion you're heating, do this VERY gently until it moves, just moves.
Once it does go to the other side and do the same. Work back and forth, allowing the contacts to cool completely in between so you don't overheat the chip.
And make sure to apply flux before each heating session. When you do get it off clean it thoroughly.
Another technique to use alongside this is to heat the one side up and use solder wick/Sucker to remove as much solder from the contacts as possible, do the same for the other side, then attempt the screwdriver method above.
Old Nov 11, 2012 | 05:44 PM
ok i think i understand the flux part, i checked this video on youtube which was amazing, im going out to buy a new tip for my soldering iron and will try your method and the flux is supposed to be inside the soldering material right?
youtube soldering video for reference
Old Nov 11, 2012 | 06:09 PM
That is a brilliant video, thanks for posting it!!!!
The Flux I'm talking about using is brush-on, just the flux alone.
But yes most solder comes with it in the center. You want to apply additional flux to heat it all up because you are not using solder to take them off. You just want them clean so the solder melts quick and you don't overheat things.
This is the method to use a solder sucker as mentioned earlier
Old Nov 11, 2012 | 06:38 PM
Ok i have a solder sucker so will do thanks for the advice n video very helpful, and that circled chip is indeed the correct chip for mileage right?
Old Nov 12, 2012 | 07:33 AM
It's a guess based off the picture you posted. Without a better picture I can't tell you 100%, sorry dude.
But you can see it, if it's the same as the one I pictured then yes. Does the circuit board say IC2 on it next to the chip like in my picture?
Old Nov 12, 2012 | 09:09 AM
DennisMik's Avatar
It looks like the op's cluster uses surface mount components, including the odometer chip. The designation of IC2 may or may not be the same and really doesn't matter. All that matters is that it is the 93C56 chip, which is a 2K eprom.
Old Nov 12, 2012 | 09:38 AM
S93c5
6dv21
3985
These are the numbers written on the circled chip and it does say IC2 under it on the board
Old Dec 2, 2012 | 09:22 AM
i just tried to swap the mileage chip in my 2003 cluster the one that is pictured, and i just want to let everyone out there know, DO NOT TRY THIS ON A 2002 OR 2003 CLUSTER. it does not work. it is impossible to remove the chip safely. once you remove the chip it rips the little contacts off the board, i tried 3 different clusters and being more and more careful each time and its impossible. i have 5 clusters laying around and i tried and RUINED 3 clusters. i used flux, this chip is surface mounted and very precise, it is impossible it cant be done and i dont wanna hear it!!! im done venting now.
