Test Pipe Q's
Old Sep 6, 2011 | 11:43 AM
nishfish871's Avatar
Test Pipe Q's
So I've seen a few no name test pipes on ebay and they seem to look very similar to some name brand ones. Is it worth spending more on a name brand one or just buy the ebay one for under $30. Btw the 240sx one fits our vehicles, so it works out a lot cheaper for a 3" version. I've seen them range from $25 to over $100. I am aware of a Fast-Cat, but there are no emissions in FL so it's not worth the money for me.
Also, will a resonated compared to non-resonated test pipe make a sound difference? If so, what type?
Old Sep 6, 2011 | 01:16 PM
NmexMAX's Avatar
dot dot dot ...
I found the Megan to be too long. I needed on exactly 1'. I got mine from LSSexhaust in Canada. Was like 33.xx$ shipped.
No complaints. It's a test pipe, it will add sound, so I wouldn't worry if it's resonated or not.
Old Sep 6, 2011 | 01:36 PM
036mtmax's Avatar
Megan sucks, I had to cut an inch out and re weld it to fit right
Old Sep 6, 2011 | 02:03 PM
schmellyfart's Avatar
A resonated test pipe will quiet the exhaust down a bit.
My exhaust got louder when I switched from a resonated ebay 2.5" test pipe to an unresonated 3" test pipe.
Old Sep 6, 2011 | 02:19 PM
spock's Avatar
Two factors involved there, stinky. Non resonated and 2.5" to 3". I think both may have contributed.
Old Sep 6, 2011 | 02:44 PM
I do agree that the size may have played a part in the noise level. However, I have also gone from stock cat to the 2.5" resonated test pipe which resulted in a quieter exhaust.
Old Sep 6, 2011 | 03:02 PM
Mr. Blue Sky's Avatar
i know the OP said that the 240sx test pipe would fit (lengthwise I suppose), but would the flange holes line up, or would it have to be modified?
Old Sep 6, 2011 | 03:20 PM
NmexMAX's Avatar
dot dot dot ...
Anybody adding a test pipe shouldn't be worried about noise.
Old Sep 6, 2011 | 03:27 PM
Rods03Max619's Avatar
When I get a testpipe just going to get one off ebay for like 30 bucks, don't think it matters the brand just some resonated and some not, the 95-99the ones is the correct ones since they measure the 12" and not the 13" but if you want a 3" one not sure about those if there on ebay.....
Old Sep 6, 2011 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
Shouldn't hurt power too much.
I gained a decent amount of power from changing a test pipe on the exhaust side, and straight pipe on the intake removing the Helmholtz resonator when I went from the Cattman fastcat to a 2.5" test pipe, non resonated.
Old Sep 6, 2011 | 04:55 PM
http://forums.maxima.org/8179642-post24.html
I know you can't see one of the bolt holes, but it does line up with the maxima cat.
Old Sep 6, 2011 | 05:25 PM
cool that it looks like it will fit. it also appears as though the resonator on the test pipe of the 240sx is a bit bigger than those sold for our max's. This may lead to even more decreased noise.
Old Sep 6, 2011 | 05:27 PM
Glad to see people jumping on this, the ebay ones for 240sx measure 12 3/8". Isn't that close to the stock cat?
Old Sep 6, 2011 | 05:29 PM
btw im looking to get a 3" one, it's either custom if the 240sx doesnt fit because there isnt one made for the maxima that size.
Old Sep 6, 2011 | 05:33 PM
maxspeed96CT's Avatar
The original VQ...
Im pretty sure all 95-03 test pipes are the same.
As far as price, the $30 one will be just as good as any other. With any other parts I normaly only go for a well known name brand but with a test pipe the $30 one will be fine.
I purcahsed one from ebay but the gaskets it came with sucked, had to but a small beed of high temp RTV on the gaskets to get it to seal....
Old Sep 6, 2011 | 05:58 PM
Waxima's Avatar
Dumb question probably but will installing a test pipe throw a CEL?
Do you have a link?
My stock cat measures in at 12.5". The cheapest 3" 240sx test pipes I see on ebay are 12.25"
Old Sep 6, 2011 | 06:06 PM
spock's Avatar
.25" amongst friends doesn't really come into play.
Old Sep 6, 2011 | 06:32 PM
I figured that, looks like I'll be ordering the cheapest ebay one (every penny counts). Good call on the gasket, I've got some RTV laying around somewhere.
Old Sep 6, 2011 | 08:21 PM
L36's Avatar
L36
Get under your car and see if you main cat has a o2 sensor behind it. If it does not, then no.
I have a modified test pipe on my 01, exhaust smells very rich without cats...
Old Sep 6, 2011 | 09:29 PM
Do you have a link?
http://cgi.ebay.com/ebaymotors/Nissa...item4841df0104
that is the one that seems like it is larger
New 5th gen site is up: click the link
my5thgen.org
Old Sep 6, 2011 | 09:32 PM
my5thgen.org
Link no worky for me
Old Sep 6, 2011 | 09:34 PM
JK, it was my internet
Old Sep 6, 2011 | 10:12 PM
7speed's Avatar
So you believe in the test pipe? Also, I thought you were firm believer in the helmholtz. I thought it made for more linear flow. I have tb to pipe to helholtz to maf to filter setup.
Old Sep 6, 2011 | 11:02 PM
my5thgen.org
Oh I thought you were talking about a resonated 3" test pipe.
Old Sep 7, 2011 | 07:40 AM
NmexMAX's Avatar
dot dot dot ...
Correct on both accounts, until my recent dyno.
Differences :
RPM__hp___tq
3750 10 13.98
3800 8.72 12.03
3850 8.41 11.47
3900 9.03 12.17
3950 9.27 12.32
4000 8.79 11.54
4050 7.34 9.53
4100 5.02 6.43
4150 2.9 3.68
4200 1.48 1.86
4250 -0.08 -0.11
4300 -1.88 -2.29
4350 -0.32 -0.39
4400 1.77 2.12
4450 1.48 1.75
4500 3.91 4.56
4550 4.75 5.48
4600 6.29 7.18
4650 7.03 7.94
4700 6.52 7.27
4750 4.56 5.04
4800 4.64 5.08
4850 4.28 4.64
4900 2.65 2.84
4950 5.06 5.37
5000 1.5 1.57
5050 4.02 4.17
5100 2.07 2.13
5150 2.47 2.52
5200 2.04 2.06
5250 0.82 0.82
5300 1.42 1.42
5350 1.03 1
5400 1.73 1.68
5450 1.16 1.12
5500 2.96 2.82
5550 3.25 3.08
5600 3.53 3.31
5650 3.46 3.21
5700 4.33 3.99
5750 3.72 3.39
5800 5.67 5.14
5850 6.31 5.66
5900 5.91 5.26
5950 8.08 7.13
6000 8.75 7.66
6050 11.09 9.62
6100 10.21 8.79
6150 10.35 8.84
6200 10.34 8.77
6250 7.78 6.55
6300 8.02 6.69
6350 5.39 4.46
6400 5.49 4.5
6450 3.48 2.83
6500 5.73 4.63
6550 4.41 3.53
6600 5.47 4.36
6650 4.65 3.68
6700 4.89 3.83
6750 4.87 3.79
6800 5.02 3.87
6850 5.94 4.56
6900 4.82 3.67
6950 6.97 5.27
7000 5.21 3.91
7050 6.11 4.54
Old Sep 7, 2011 | 09:29 AM
It would be great if one existed, but sadly it seems the demand just isn't there.
Old Sep 8, 2011 | 08:48 PM
7speed's Avatar
Differences :
RPM__hp___tq
3750 10 13.98
3800 8.72 12.03
3850 8.41 11.47
3900 9.03 12.17
3950 9.27 12.32
4000 8.79 11.54
4050 7.34 9.53
4100 5.02 6.43
4150 2.9 3.68
4200 1.48 1.86
4250 -0.08 -0.11
4300 -1.88 -2.29
4350 -0.32 -0.39
4400 1.77 2.12
4450 1.48 1.75
4500 3.91 4.56
4550 4.75 5.48
4600 6.29 7.18
4650 7.03 7.94
4700 6.52 7.27
4750 4.56 5.04
4800 4.64 5.08
4850 4.28 4.64
4900 2.65 2.84
4950 5.06 5.37
5000 1.5 1.57
5050 4.02 4.17
5100 2.07 2.13
5150 2.47 2.52
5200 2.04 2.06
5250 0.82 0.82
5300 1.42 1.42
5350 1.03 1
5400 1.73 1.68
5450 1.16 1.12
5500 2.96 2.82
5550 3.25 3.08
5600 3.53 3.31
5650 3.46 3.21
5700 4.33 3.99
5750 3.72 3.39
5800 5.67 5.14
5850 6.31 5.66
5900 5.91 5.26
5950 8.08 7.13
6000 8.75 7.66
6050 11.09 9.62
6100 10.21 8.79
6150 10.35 8.84
6200 10.34 8.77
6250 7.78 6.55
6300 8.02 6.69
6350 5.39 4.46
6400 5.49 4.5
6450 3.48 2.83
6500 5.73 4.63
6550 4.41 3.53
6600 5.47 4.36
6650 4.65 3.68
6700 4.89 3.83
6750 4.87 3.79
6800 5.02 3.87
6850 5.94 4.56
6900 4.82 3.67
6950 6.97 5.27
7000 5.21 3.91
7050 6.11 4.54
Well damn, I see I may have to make some adjustments.
Old Sep 8, 2011 | 09:40 PM
Yeah there used to be one floating around eBay for $50, but the resonated section was only around 5" long. I will probably end up making my own if I can find a reasonably priced 10" long resonator.
Old Sep 9, 2011 | 09:17 AM
NmexMAX's Avatar
dot dot dot ...
If you do, I'll but the second one you make
Old Sep 9, 2011 | 10:48 AM
02AutoMax's Avatar
Differences :
RPM__hp___tq
3750 10 13.98
3800 8.72 12.03
3850 8.41 11.47
3900 9.03 12.17
3950 9.27 12.32
4000 8.79 11.54
4050 7.34 9.53
4100 5.02 6.43
4150 2.9 3.68
4200 1.48 1.86
4250 -0.08 -0.11
4300 -1.88 -2.29
4350 -0.32 -0.39
4400 1.77 2.12
4450 1.48 1.75
4500 3.91 4.56
4550 4.75 5.48
4600 6.29 7.18
4650 7.03 7.94
4700 6.52 7.27
4750 4.56 5.04
4800 4.64 5.08
4850 4.28 4.64
4900 2.65 2.84
4950 5.06 5.37
5000 1.5 1.57
5050 4.02 4.17
5100 2.07 2.13
5150 2.47 2.52
5200 2.04 2.06
5250 0.82 0.82
5300 1.42 1.42
5350 1.03 1
5400 1.73 1.68
5450 1.16 1.12
5500 2.96 2.82
5550 3.25 3.08
5600 3.53 3.31
5650 3.46 3.21
5700 4.33 3.99
5750 3.72 3.39
5800 5.67 5.14
5850 6.31 5.66
5900 5.91 5.26
5950 8.08 7.13
6000 8.75 7.66
6050 11.09 9.62
6100 10.21 8.79
6150 10.35 8.84
6200 10.34 8.77
6250 7.78 6.55
6300 8.02 6.69
6350 5.39 4.46
6400 5.49 4.5
6450 3.48 2.83
6500 5.73 4.63
6550 4.41 3.53
6600 5.47 4.36
6650 4.65 3.68
6700 4.89 3.83
6750 4.87 3.79
6800 5.02 3.87
6850 5.94 4.56
6900 4.82 3.67
6950 6.97 5.27
7000 5.21 3.91
7050 6.11 4.54
That was the dyno with just changing to the 3.5 inch intake setup over 3 inch, correct?
Does taking out the hemholtz and replacing it with the mid-pipe show any gains or just noise increase on the stock 3 inch intake?
Got bored today and thought about replacing the hemholtz if there were any added benefits
Old Sep 9, 2011 | 10:46 PM
No. The info is in here:http://forums.maxima.org/dyno-discus...7-245-ish.html
Old Sep 9, 2011 | 11:05 PM
The cheapest I see one of those resonators is for ~$45 each when you buy two. At least another $16 for flanges (mild steel). Probably looking at $80 when all said and done.
Still interested?
Old Sep 9, 2011 | 11:42 PM
NmexMAX's Avatar
dot dot dot ...
Still interested?
Do you know how much I spent on an intake manifold? PM me your price
Old Sep 10, 2011 | 12:39 AM
Touché. I will send you a PM once I find a suitable resonator.
Old Sep 10, 2011 | 02:12 AM
This may be a suitable Resonator Size for all those looking for a 3" resonator to make a test pipe into. Just Need to Get Flanges on it, and it would be a near perfect fit(maybe need to add 0.5"). it is a vibrant resonator that is 3" by 12" overall length.
http://www.amazon.com/Vibrant-Standa...=pd_sbs_auto_2
Old Sep 10, 2011 | 03:23 PM
fishtale6spd's Avatar
Hey im looking to get a test pipe and a y pipe whats the best test pipe to get and the cheapest. 02 maxima 6spd. Found the megan racing one and all but everyone is saying to long? I want bolt up fit to my catback exhaust
Old Sep 11, 2011 | 06:17 PM
That's one of the ones I had my eye on. Here is another one I've been looking at. http://www.summitracing.com/parts/WLK-22538/
Old Sep 11, 2011 | 08:09 PM
I just bought the 3" S13/14 one from ebay, will post pics when it comes in. I think 1/8" off from stock cat isn't going to impact the appearance of the muffler at all.
Old Sep 13, 2011 | 06:55 AM
NmexMAX's Avatar
dot dot dot ...
Let us know how it goes.
