Car bogs when shifting from 1 to 2 (03 se AT)
Old Sep 13, 2011 | 10:57 AM
xumengpeter's Avatar
my max is 03 SE AT with 99k, and everytime i take off from a red light, when the car shifts from gear 1 to 2, I can feel a uncomfortable bog there, I dont floor my car and just do normal driving, it shifts around 2500 rpm, and the other gears are allright, just from 1 to 2.. anyone has an idea?
thanks
Old Sep 13, 2011 | 04:11 PM
tothemax2003's Avatar
clean your maf sensor , check to make sure none of the spark plug wires are broken.
Old Sep 13, 2011 | 05:12 PM
SJMaxSE's Avatar
Yep also check plugs too,MAF could be clogged
Old Sep 13, 2011 | 06:07 PM
Ive already cleaned the MAF sensor two days ago, if it is MAF, why only 1 to 2?
I`ll clean the TB sometime, I really cant see the coilpacks I think..
Old Sep 13, 2011 | 06:16 PM
Child_uv_KoRn's Avatar
Bad *** Newb
I had to check to see if you had 15 posts yet. Huge facepalm.
1990 called, they want their plug wires back.
I suspect maf, as well. Idk why it would only do it on the 1-2 shift, but you can test it. Unplug the the maf and go for a quick ride. She'll be running crappy and slow, but if it shifts okay that way, I guess that proves it's the maf?
Not sure of TCM symptoms, though. No auto.
Old Sep 13, 2011 | 06:17 PM
kvk2003max's Avatar
i have the same problem. Interested to see how the diagnosis goes.
Old Sep 13, 2011 | 08:30 PM
Chris Gregg's Avatar
Get Off My Lawn
Not fully clear on what you mean by "bog." What is the rpm zone you are bogging in?
This sounds to me like normal operation at partial throttle, as you've described it. The transmission is shifting into a higher gear, I'm assuming at a low rpm. Yeah, it's going to bog some.
My car does the exact same thing. If I'm pulling out slightly (10-15% throttle), the car will shift into second, the rpms drop and the car sounds like it's bogging, because it is. It's working harder at a lower rpm to pull the car forward. As soon as I give it 25% or more throttle, it moves right along though.
Does your car begin to accelerate with additional throttle? Then this is normal. IF it DOES NOT want to accelerate with additional throttle, THEN you've got a problem.
So, what if you give the car MORE throttle (25% or more) when pulling out, does it still bog after the 1-2 shift?
I just about bet a Sprint Booster would resolve all your concerns!
Old Sep 13, 2011 | 09:31 PM
well, I mean its a rough shifting from 1 to 2, its very easy to feel its shifting, its so obvious..
Old Sep 13, 2011 | 09:40 PM
02pearlmax's Avatar
I have this too. The shift from 1st to 2nd jerks the whole car around. All the other gears are fine. And it only occurs when the tranny fluid is warmed up, when its cold it shifts smooth as butter in all gears. I did a drain and fill and it made no difference, so I'm going to do another drain and fill while dropping the pan and cleaning the magnets/screen.
Old Sep 14, 2011 | 05:09 AM
Get Off My Lawn
I have the Transgo HD2 kit, I don't think it gets much more firm that than! My 1-2 shift had been a bit too smooth prior to the kit...slipping. It's just so hard to get a clear picture becuase experiences are subjective. So it's difficult to really say if there is a problem.
You talk about bogging, then we got on to the transmission operation. If the car is tuned up, I suggest you get us some information about when the car is shifting and the rpm band you say it bogs under.....help us with some more specifics. For example, I noted this morning that in light throttle, my car will shift into second and run about 1500 rpm. Not a lot of power being created at that point.
You also realize if you're running your defroster, it kicks on the a/c compressor? That will rob some power.
Old Sep 14, 2011 | 06:04 AM
tcb_02_max's Avatar
Originally Posted by xumengpeter
my max is 03 SE AT
Shift for yourself and WIN!
6MT FTW
Old Sep 14, 2011 | 09:07 AM
amack's Avatar
I have the same problem, its always in first gear right around 1500 rpms and only ever in first gear. If I rev it just above 1500 rpms though and milk the clutch more than I'd like then its fine. its really pissing me off. the whole car bogs like almost stops until I push on the gas to get it past that powerband area. 80k motor just installed, brand new clutch ,new coil packs and plugs.(00' SE 5-speed)
Old Sep 14, 2011 | 12:38 PM
Get Off My Lawn
I would also add to check your VIAS for proper functioning. The diaphrams are known to go bad sometimes. Many ways you can check this. Harbor Freight sells cheap vaccuum tools which create vacuum to check if vacuum controled devices are operating mechanically as they should.
Old Sep 14, 2011 | 05:50 PM
it happens all the time no matter the ac is on or not, and the only way to relieve it a little bit is I let go the throttle pedal before it shifts, then it will be smoother..
Old Sep 14, 2011 | 05:53 PM
i had a similar problem recently and found out that the oxygen sensor that goes before the precat was bad.It did not have a check engine light and everytime a stepped on it a little form a dead stop it would bog and then go like a freight train.It was bank 2 sensor 2 the red wire sensor. I fixed it and no more bogging and as a member from here said it runs like a raped ape lol.
Old Sep 14, 2011 | 06:24 PM
02pearlmax's Avatar
how did you find out the sensor was bad?
Old Sep 14, 2011 | 09:48 PM
kvk2003max's Avatar
Any way to test this sensor, or do you have the part number for Denso or Bosch. Nissan one costs 150 bucks. Thanks for the info.
Old Sep 15, 2011 | 04:30 PM
you have to check with ob11 scanner , the bosch part is 13969
Old Sep 15, 2011 | 04:32 PM
but you have a 2005 so you have to first check with the code scanner and find out if you have a bad sensor and what part , because you have a 3.5 motor.
sorry 2003
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
jhontelj
Aug 17, 2015 04:07 AM
Trin1j23
Aug 12, 2015 08:31 PM
