clutch hard to engauge?
Old Sep 23, 2011 | 08:15 AM
dnice02's Avatar
Ok the car shifts through all the gears fine. When I try to put the car in 1st and reverse I have to damn near push the peddle through the floor. I adjusted the rod on the master cylinder all it could go, because at first it wouldn't even go into gear. That solved that problem. But its still hard to get it into first and reverse, and it will shake you to death when letting off of the clutch when pulling off. I even had my dad pry the fork back and that didn't help. I then shined q flupash light down into the hole and saw the that release bearing was touching some but not all of the teeth on the pressure plate. I'm stuck on what the problem could be. Sorry for the long post. Oh and my setup is fidanza and competition stage 2.
Old Sep 23, 2011 | 08:33 AM
QT1 5MT AE's Avatar
Gram Lights addict
Stiff clutches will do that to you, rattle your teeth out. did you put in the disk backwards?
Old Sep 23, 2011 | 11:05 AM
dnice02's Avatar
I wanna say no I didn't but not absolutely sure. As soon as the rain let up here I'm gone try and the tranny back out and double check.
user 11122324
42
Jul 18, 2022 03:35 PM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
jaydot901
Sep 29, 2015 01:18 PM
