Thule rack and Fit kit help?!
Old Nov 2, 2011 | 02:56 PM
Xpcgamer's Avatar
So the wife went ahead and got the full Thule set up for my 5th gen and I can't seem to figure out the fit kit. Look at the following pic. Is the clamp sitting in the right spot? When I went with the exact width of 39 1/4 inches it pushes the clamp out too much. When I shortened it this is house it sits.
Then when I tighten it, it picks the entire foot up. Look.
Anybody have any ideas? The fit kit is #2077. It says 2000-Maxima.
Old Nov 2, 2011 | 04:12 PM
RA121625's Avatar
I have the same kit on my car. Its supposed to sit way lower, as in the metal part is supposed to go over the seal of the door.The rubber pad is supposed to sit closer to the edge of the roof too. I don't have pictures because its not installed right now.
The fitment is really precise, every part of that kit that touches the car is made to practically hug your vehicle. Widen the brackets and try it again.
Old Nov 2, 2011 | 04:15 PM
RA121625's Avatar
Oh and each one of the rubber pads and the brackets are meant to sit in a specified corner of the vehicle at a very specific distance from the front/rear windshield etc (i.e. you can't interchange left/right/front/rear). I would call thule if you don't have these instructions with you because they will make the install much easier and its also a good way to ensure you don't damage anything.
Old Nov 2, 2011 | 04:26 PM
Xpcgamer's Avatar
I had the center at 39 1/4 per the instructions. The pads listed as the fronts are installed but I can't figure out where the fit kit feet fit in the sides. I tried moving them down but they hold the door open a bit when I try to close the door.
Old Nov 2, 2011 | 04:45 PM
RA121625's Avatar
That means there's something wrong with the placement, the doors should obviously close properly when this thing is installed. Try moving it back and forth and find the spot where its not in the way of the doors.
Also many Thule dealers will give you tips on installing this stuff if you take it to them, they may even install it for you. I would suggest that if you're still having trouble with the install.
Old Nov 2, 2011 | 04:59 PM
Xpcgamer's Avatar
I got it from RackAttack.com. I will try digging the net to see if I find something. Not sure if there is a Thule dealer around me. I know ****s sporting goods sell Yakima thou.
Old Nov 3, 2011 | 04:36 PM
Xpcgamer's Avatar
I got it. I guess my hands work faster then my brain. I just laid the clamps on top of the rubber seals. Took my measurements and tightened them like crazy. They are on tight. One of the clips for my fairing is missing a section. I will get with the Rackattack tomorrow.
Thanks for the tips guys!
Old Nov 3, 2011 | 06:37 PM
03VQMAX's Avatar
Looking crisp Koben .
Old Nov 3, 2011 | 07:22 PM
RA121625's Avatar
Looks good man. Those Thule kits are truly versatile and bullet proof. My family has had ours for over 10 years now and its awesome for travelling.
Old Nov 3, 2011 | 07:32 PM
Xpcgamer's Avatar
Was just on the highway doing 80 for around 30 minutes with the sunroof open. The fairing makes a big diff. Not noisy at all.
Old Nov 4, 2011 | 01:39 PM
Maxgig's Avatar
I don't have the fairing but you're right you can drive high speed with it loaded no problem. I have mine set up to hold 4 bikes and it works great.
James92SE
142
Jan 2, 2024 09:23 AM
t6378tp
Sep 29, 2018 04:27 PM
fastcarny
Oct 12, 2015 07:06 AM
Pied
Sep 26, 2015 03:29 PM
Jamie Bolus
Sep 13, 2015 05:56 PM
