BBMAF Apexi Neo Settings
Got a BBMAF from another member and hooked it up, knowing I would have to play with the settings to make it run right. The previous tuning settings I had was 1in 1out, single - single.
I read that you should use 1in 17out but the car didn't idle at all unless I gave it +50 and it still was slightly lean. I tried 1in and every setting out and nothing seemed to work right, even when adjusting the fuel.
Did I miss something? Is there a better setting to use? I'm did some searching (still am searching too) and didn't see anything. Any ideas? Thanks guys.
http://www.apexi-usa.com/manuals/ele...eo_diagram.pdf
Cilffs:
IN = Infiniti Q45 = HW 1
OUT = A33 = HW 17
First things first:
Have you verified everything is working properly? (i.e., initialized, the throttle % goes up when you press it, as does the MAF value and RPM, relative to their positions, i.e. use tach as a second verifier etc?)
You are using hot wire in the set-up?
Try reversing the #'s.
Cilffs:
OUT = A33 = HW 17
First things first:
Cilffs:
OUT = A33 = HW 17
First things first:
Cilffs:
OUT = A33 = HW 17
First things first:
I guess I will initialize it and start over. But 1in 17out definitely didn't work. You're saying make it 17in 1out??
Wait... just thought of something. I think I installed it wrong lol cause the maf wire was flipped now that I think about it. Wowwwwwww I I bet that's what was wrong the whole time. I JUST thought of that. I'm an idiot.
If you're an idiot, then I'm an idiot.
Did the same thing when I installed mine ..
After the reinstall, don't reverse the settings, leave them as is, 1in 17 out.
Practice makes perfect
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
