steering wheel controls failing
Old Jan 3, 2012 | 02:40 PM
Blackwind's Avatar
anyone have trouble with the stereo controls responding intermitenly (sp?)
mine only work when they want and its annoying.
Old Jan 3, 2012 | 03:02 PM
maximase86's Avatar
I love lamp.
My volume up/down and tuner are intermittent. However that's more a 'feature' of the PAC remote adaptor going into my Pioneer HU.
BTW, happy new years Navfe.
Old Jan 3, 2012 | 04:01 PM
Blackwind's Avatar
you too man!
same here, the mode works fine but the vol ^v and the main ^v are laggin, its getting on my nerves, i dont wanna have to buy a new switch
Old Jan 3, 2012 | 04:41 PM
essential1's Avatar
My axles cry for mercy...
It works when it wants to on my brothers max. On mine the volume will astop every once on a blue moon.
Old Jan 3, 2012 | 04:43 PM
essential1's Avatar
Another thing, mine will change stations by itself every so often too.
Old Jan 4, 2012 | 08:41 AM
Blackwind's Avatar
Twilight zone!! lol
Old Jan 4, 2012 | 11:35 AM
Montego Murph's Avatar
I've noticed that when my audio controls don't work, if you tilt the wheel a degree or two, they work fine. I can't make heads or tails out of that.
Old Jan 4, 2012 | 12:30 PM
djfrestyl's Avatar
Suspension Yoda
Any relation to ambient temperature?
For those using PAC, switch to the Axxess ASWC. MUCH better product.
Montego Murph - you've got PM.
Old Jan 4, 2012 | 04:23 PM
Blackwind's Avatar
im gonna check my wiring, my car is a 98 so its not native, but ill also pull the switch and open it up to do some research
Old Jan 4, 2012 | 04:24 PM
Blackwind's Avatar
NELLLLLLLLLISH!!!!!!!!!!!!!! LOL
whats up man?
Old Jan 4, 2012 | 04:48 PM
unrealii's Avatar
My car used to do that. When I replaced the unit with a new unit from Daveb it stopped doing that. Maybe a loose connection with the unit itself or on the cable.
Mine have trouble working when it is cold outside (<60). The contacts could also be dirty. I took mine apart and cleaned the contacts. The buttons worked significantly better after that.
Old Jan 4, 2012 | 04:50 PM
unrealii's Avatar
Here is a write up I did several years ago:
http://forums.maxima.org/audio-elect...-controls.html
Old Jan 4, 2012 | 04:54 PM
unrealii's Avatar
How many commands can you program? When I used the IR version of the SWI-X, I programmed Vol Up + Vol Down = mute, etc.
Unfortunately, lost all of those extras when I switched to the directly connected version for my Eclipse Radio.
nsnrider's Avatar
your clock spring is bad and needs replacing.
I have had the steering wheel switches fail, usually just swap them out and good to go, every once in a while encounter the clock spring breaking and needs replacing.
Old Jan 4, 2012 | 04:57 PM
unrealii's Avatar
Mine used to do that, but when I replaced just the buttons, that problem disappeared...go figure
Old Jan 5, 2012 | 04:31 AM
djfrestyl's Avatar
Suspension Yoda
whats up man?
Hey buddy - how's it goin?
Not 100% on that. It definitely does everything the OEM buttons do. It's just MUCH faster in response time than the PAC units.
mvm062
Nov 30, 2020 09:00 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
coasterswim
Sep 2, 2015 07:43 AM
