For Supercharged Maxes....
Old Jan 2, 2002 | 01:37 PM
jhans114's Avatar
Anyone running a 3.33 or 3.25 pulley? and if so any new problems? How much boost will you get for these sizes? Thanks in advance! Also do I need a new belt?
Old Jan 2, 2002 | 02:13 PM
jhans114's Avatar
ANYONE!?
Old Jan 2, 2002 | 03:42 PM
UMD_MaxSE's Avatar
Got Bent?
I am not SC'd, but, from what I hear, the 3.25" pulley will give you around 10.5-11 psi of boost and the 3.33" pulley will give you about 9 psi. Y2KevSE is running 3.25" pulley I think.
Old Jan 2, 2002 | 04:06 PM
jhans114's Avatar
Thanks!! 1 out of 50 viewers has some info on this. Im currently running the stock 3.60 and I can only get up to 5 1/2psi. Actually Kev is running 3.125 which is really high boost.
Old Jan 2, 2002 | 04:13 PM
Deac's Avatar
Oooohhhhhh!!!
I just got my Supercharger a week ago and I was wondering why I was only getting up to 5psi of boost...I was beginning to think something was wrong with my SC!!! Where can you get the smaller pulleys from anyways?
Old Jan 2, 2002 | 04:30 PM
jhans114's Avatar
Re: Oooohhhhhh!!!
Not your SC. Mine is only boosting 5-5 1/2psi. Here is the link for smaller pullies.
http://www.vortechsuperchargers.com/...es/pulley.html
The one for our supercharger is the one with the 6ribs.
Good luck and how do you like you SC and what type of tranny do you have?
Old Jan 2, 2002 | 04:34 PM
Deac's Avatar
Re: Re: Oooohhhhhh!!!
I meant to say that I'm running the stock pulley too and I was wondering why I wasn't getting alot of boost! I have a 2k1 5spd and I love my SC so far...love that SC "whistle"!!!
Old Jan 2, 2002 | 04:37 PM
Deac's Avatar
Re: Re: Re: Oooohhhhhh!!!
What measurement is the stock pulley? Is the 3.125 the 6-rib or the 3.33... which one is the best to get without pushing it too much?
Old Jan 2, 2002 | 04:42 PM
jhans114's Avatar
Thats normal. The highest boost I got was 5 1/2psi. Im gonna get the 3.33 size for now and see how much I can boost, plus a custom water-cooler for the SC. Right now im about 245fwhp and 230lbs torque. After the smaller pulley and the cooler I should be around 275fwhp. By the way saw your page, nice max! Im Superblack on black 2! Check it out!
Old Jan 2, 2002 | 04:48 PM
jhans114's Avatar
Re: Re: Re: Re: Oooohhhhhh!!!
The smaller you go the more boost. 3.125 is pretty high the only guy here that is running that is Y2KevSE.
STOCK: 3.60 = 5-6psi - safe
3.48 = 6-7psi - safe
3.33 = 8-9psi - safe
3.25 = 9-10psi - not sure
3.125 = 11-12psi - not sure
Old Jan 2, 2002 | 04:56 PM
Deac's Avatar
Re: Re: Re: Re: Re: Oooohhhhhh!!!
Tht link you posted has a small write-up after each pulley...once you get down to the 3.125, it says..."will void vortech SC warranty!!" All the ones from that one on down say that so...I guerss its safe to assume that 3.125 on down is pushing it!!
PS I was looking at your site too nice max...
Old Jan 2, 2002 | 07:43 PM
max'n out's Avatar
5.5 is normal for the stock pulley espeically if your auto. 3.25 should be fine if you change the fmu and sparks. May want to mod the tranny some more to put it down better and the ecu to raise the rev limiter so you get all the boost and more power. 3.25 is 10psi you need a 6 rib belt MUST. Vortech and stillen prob arn't going to honer any warrenty at all so put that aside.
Old Jan 2, 2002 | 11:01 PM
jhans114's Avatar
I was thinking of going with 3.33 and the Super FMU from Vortech. It has 5 adjustable settings. And I already upgraded the ignition. Only thing is contemplating if I should go down to 3.25... hmmmmm
Old Jan 2, 2002 | 11:38 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
3.60 = 6.5 psi - safe
3.48 = 7.5 - safe
3.33 = 8-9 psi - safe but be careful
3.25 = 10 psi - somewhat safe, start to look for a new tranny
3.125 = 11 psi - not too safe, better have a tranny sitting around
2.87 = 13 psi - boom
2.62 = 14 psi - kaboom
Old Jan 2, 2002 | 11:39 PM
Dario's Avatar
hope u have a tranny sitting around
Old Jan 2, 2002 | 11:42 PM
jhans114's Avatar
Re: Re: Re: Re: Re: Re: Oooohhhhhh!!!
3.48 = 7.5 - safe
does anyone know how much of an increase each pulley downgrade gives to the wheels?
Old Jan 2, 2002 | 11:43 PM
Y2KevSE's Avatar
Me?
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Re: Re: Oooohhhhhh!!!
About 10 whp per psi... more or less.
Old Jan 2, 2002 | 11:47 PM
jhans114's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Oooohhhhhh!!!
Thanks! and tried to go edit profile and delete those messages but once i go in there it says there are no messages. im
Old Jan 3, 2002 | 12:09 AM
Y2KevSE's Avatar
Check your sent mail box.
Old Jan 3, 2002 | 03:52 AM
Deac's Avatar
Actually...
On the Vortech website under pulleys, it says they will still honor your warranty if you have a 3.25...anything less than that..."would be uncivilized"!!!
Old Jan 3, 2002 | 08:15 AM
max'n out's Avatar
I say call level ten no matter what. Mod the tranny real nice. It's worth it for everyreason in the world. Stronger trany. Bettershifts. More power going down. More performance all around. Faster than a 5 speed.
Old Mar 8, 2002 | 10:04 PM
sp6040's Avatar
stillen v2
for those of you that have the v2.i hear that the down fall to these are the plactic sc pulley.so would it make sense to purchase a new pulley from vortech at the start? also if i go to a 3.33 pulley would i have to modify anything else i already plan on doing the vb first.
im just trying to get as much info as possible before i spend about 4,000 for the sc. and yes i have tried searching.didnt really find an answer to my questions.
Old Mar 9, 2002 | 11:16 AM
Y2KevSE's Avatar
Re: stillen v2
What sort of search did you use?
I hope you didn't find that the SC pulleys were made out of plastic.
Old Mar 9, 2002 | 11:43 AM
The New CLIMAX's Avatar
Re: Re: stillen v2
Old Mar 9, 2002 | 01:48 PM
sp6040's Avatar
Re: Re: stillen v2
ok with a little more research i found that its the v2 sc idle pulley that plastic and can melt.my question is when you go with a smaller pulley such as a 3.33 will this cause your idle pulley to melt? Or will it melt with stock pulley and just beating on the car such as taking it to the track and constant racing?
also if the sc idle pulley is the only problem where can we get a aluminum or titanium idle pulley can any machime shop custom make one?
Old Mar 9, 2002 | 10:05 PM
Y2KevSE's Avatar
Re: Re: Re: stillen v2
The plastic pulley will melt no matter which SC pulley you use. Stillen didn't do a good job designing it. It's not the idler pulley that melts, it's the tensioner pulley. I don't know why people call it that, because they are two totally different things.
A couple members are trying to get aluminum pulleys made.
Old Mar 9, 2002 | 11:28 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Re: Re: Re: stillen v2
Kev, you should contact Brian Catts about making that pulley. I'm pretty sure his fab shop could copy the stock one and make it out of whatever.
Also, I know not too many people have a SC, but more and more do and some such as myself like to keep up on the "learning pains" you guys go through incase someday we actually score a SC. Anyways, do you think a "SC Q&A" sticky would be worthwhile to keep all the SC Q&A in? Plus, it would be a list of current SC owners for people to ask questions from.
That way everyone will know where to find answers to the basic questions without so many repeats such as what pulley size = what psi, what is a safe boost level if I do/don't have an intercooler, is this normal behavior, what mods do I need to add if I have an auto, what additional accessories do I need to monitor fuel pressure/EGT/A/F, and soon to come how to replace my tranny.
P.S: When are you going to swap to a 3" Y-pipe and exhaust? I'm betting your flowing enough air to need one. I've heard that a less restrictive exhaust can prevent preignition on engines pushing a lot of boost. Any truth?
Old Mar 10, 2002 | 04:38 AM
sp6040's Avatar
sticky for sc
i think this a very good idea because i have a few more question that are listed in the prievious reply.kev didnt you have a tensioner pulley custom made? was it expensive to have it done? what type of metal is it made of? i hear even the aluminum pulley can melt so i guess titanium is the way to go. i definetly will not purchase a sc enless the pulley issue is resolved.
Old Mar 10, 2002 | 07:22 AM
ohboiya's Avatar
just curious ... has n e 1 w/ a SC taken it 2 the track? how much time does it actually take off your 1/4 mile & 0-60?
Old Mar 10, 2002 | 10:24 PM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: stillen v2
The SC Q&A should be in the General Forum if we do decide on this. I did put up a list of boost and pulley sizes in our 5th gen FAQ. If you guys see something you want to get FAQ'ed, just give me a PM or email and I'll be happy to include it in our list.
I'm not sure if I want to go with a 3" pipe. I know I'll make more power with the boost I'm running, but then I would have to sell the GReddy and Stillen y pipe (which has the EGT probe in it already).
I've never heard of an exhaust causing preignition. It'll kill your hp and torque though (just like an exhaust that is too big).
P.S. I'm working with someone on the pulley situation.
Old Mar 10, 2002 | 10:38 PM
Y2KevSE's Avatar
Re: sticky for sc
I'm working with someone on a new pulley. He should have it completed really soon.
Old Mar 10, 2002 | 10:40 PM
Y2KevSE's Avatar
8.93 @ 152.6 mph... need to tune my NAWZ.
Old Mar 11, 2002 | 02:23 PM
sp6040's Avatar
Re: Re: sticky for sc
im glad to hear that. finally when im ready to purchase my sc i can have some peace of mind. let me know how it works out.
Old Mar 14, 2002 | 10:56 PM
jgadlage's Avatar
SC 1/4 time improvement
Best time before SC: 15.72
Best time after SC: 14.7
That on bad shocks, bad tires, and a full tank of gas. Not bad. Time to try out my new Kumho's!
Old Mar 15, 2002 | 02:44 PM
jhans114's Avatar
Re: SC 1/4 time improvement
Just curious what pulley are you running and how much fwhp?
Old Mar 15, 2002 | 04:13 PM
IceY2K1's Avatar
Kev,
What is the crank pulley diameter in inches?
What is the MAX rpm you can shift at?
Thanks.
Old Mar 15, 2002 | 08:14 PM
jgadlage's Avatar
Re: Re: SC 1/4 time improvement
I am running the stock pulley (3.60) and running about 315hp at the crank or 255hp at the wheels.
Old Mar 16, 2002 | 04:33 AM
sp6040's Avatar
smaller pulleys
so i take it that the smaller the pulley the more boost and hp it adds. it this correct?
Old Mar 16, 2002 | 07:30 AM
jhans114's Avatar
Re: smaller pulleys
That is correct. Im running a 3.33 and I have about 298.2hp to the wheels which is about 348hp to the crank. Each pulley you go down in size is about 10-12 whp.
