Warranty coverage of Brake Rotor TSB
Old Jan 2, 2002 | 08:39 PM
ru4real's Avatar
If you've had your rotors fixed according to the TSB, did you have to pay any charges, or does the warranty fully cover everything that was done?
Old Jan 2, 2002 | 08:58 PM
RBa's Avatar
RBa
Re: Warranty coverage of Brake Rotor TSB
I had my brakes replaced twice under warranty... As long as you still have under 36k, you're still covered for most defects and malfuctions... They don't charge you until you authorize to do a repair that isn't covered!!!
IE.. If your rotors are warped and you have no thread left on your pads, you'll have to pay!!!
Or if you are like me and paint the calipars and ask them to do the TSB... They still did the work but also voided my warranty on brakes..
Old Jan 2, 2002 | 09:07 PM
ru4real's Avatar
Re: Re: Warranty coverage of Brake Rotor TSB
Before I go to the dealer, I'll remove the OSCAI hose, but I'm wondering what they'll say about the FSTB and RSB. I haven't been to the dealer for any service since I bought my car last February.
Old Jan 2, 2002 | 09:28 PM
RBa's Avatar
RBa
Re: Re: Re: Warranty coverage of Brake Rotor TSB
LOL.. I went to the dealer so they can check out this rattling I had under the hood... They told me it was my cold air intake hitting against the edges of the hole... They actualy wrote that on the service sheet... I have silicone hoses, SS wires & looms, polished and painted Valve cover etc... Only thing dealer told me was stop beating on the car and comeback later if I have any other problems in the future!!!!
Old Jan 3, 2002 | 05:49 AM
ru4real's Avatar
I hate getting flashed in public! I feel violated.
Old May 1, 2002 | 01:59 PM
blkturbo3's Avatar
Where can I find that TSB for rotors? I need to replace my rear brakes after only 18k.
Old May 1, 2002 | 02:02 PM
[maxi-overdose]'s Avatar
it said 3 year / 36k miles on the TSB for 2000 max. not sure about 2k1. I know a lot of dealers will say that brake is a "wear and tear" items.....I got mine fixed once but I believe it is going to warp again soon...it is turning blue again,.
Old May 1, 2002 | 02:12 PM
ru4real's Avatar
Look in the *Important* TSB thread at the top.
Old May 1, 2002 | 02:16 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i had my rotors cut and pads replaced at 10k. the steering wheel was shaking like crazy and they replaced both at no cost. they said if they warp again, they will replace them with new rotors and pads because they wouldnt advise cutting them again. i went in with my fstb and rsb and they didnt say a word about it.
Old May 1, 2002 | 02:21 PM
blkturbo3's Avatar
Re: Re: Re: Re: Warranty coverage of Brake Rotor TSB
I can't find it. I don't see anything on top of this page that reads "Important" TSB. I must be dense or something.
Old May 1, 2002 | 02:26 PM
sloppymax's Avatar
http://www.punkdork.net/max/rotor%20tsb.jpg
sorry it wont let me link it for some reason.
Old May 1, 2002 | 02:30 PM
blkturbo3's Avatar
I've seen that TSB before somewhere but I don't think this TSB regarding the brake judder (strange name) would apply to my rear brakes going out after 18k....right?
Old May 2, 2002 | 10:59 AM
sloppymax's Avatar
the brake judder comes from the rotors warping prematurely. when the rotors warp, the steering wheel will shake, and the pads will eventually get messed up from running on warped rotors. that would cause the pads to go out. braking is typically 80% front and 20% rear. if the pads are gone, id guess the rotors are shot too espically with that low of miles.
Old May 2, 2002 | 01:44 PM
maximaman14's Avatar
Dealers will only honor the TSB for 2000 maximas not 2001. I just paid 90$ to get my front rotors machined. The dealer claimed that Nissan fixed the problem in the 2001s. hmmm ...then why do all of us with 2001s still have the problem??
Old May 2, 2002 | 02:35 PM
ru4real's Avatar
Sorry to tell you this, but I went to a dealer that honored the TSB for my 2k1. Read about it in this thread
AFAIK, Nissan did jack **** to fix it in the 2k1. They're the same rotors, aren't they?
Old May 2, 2002 | 02:51 PM
Lumbee799's Avatar
Take this to the dealer and see what they say about it.
Brake Rotor TSB
Old May 2, 2002 | 02:58 PM
The TSB says 2000 Maxima..nothing about the 2001. The dealer told me they changed the pads in the 2001. I know its total BS..I plan to call Nissan NA and find out what real story is. Basically I just wanted the problem fixed. I had the TSB but they didn't care.
Old May 2, 2002 | 04:05 PM
sloppymax's Avatar
that is complete crap. they are the same pads for 4th gen, 5th gen and 2k2. the only difference is the rotors. actually the altima uses the same pads as well, at least back in 95. i cant stand it when service people say theyve changed the part just so they can get out of fixing what needs to be done.
Old May 2, 2002 | 04:38 PM
this is what I heard from a nissan serv. rep. he told me that early 5th gen has problem with rotor wrapage is due to the excessive heat generated on the rotor. (doh!) and the cuase is the material of the brake pads. The TSB will replace our early model 5th gen brake pad to a newer one.
but....even after my rotors were cut....pads were changed...the rotors still turn blue......I bet it will warp again anytime soon.
Old May 2, 2002 | 07:57 PM
Highlander's Avatar
Ahhh... yess... so this explains why my front end has started to shake when braking (started about 500 miles ago, at about 24,500 on my 2000 SE)... F**K... I thought I had left those warped rotor problems behind when I ditched the Ford last fall... Oh well, here we go again..
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
