02 infiniti i35 few questions
Old Mar 9, 2012 | 09:27 PM
nurvcom's Avatar
ok i have 02 infiniti i35
and today i worked on 06 Altima SE R and it STOCK and sounded so bad a$$
motor look identical to my i35 Would the exhaust and ECU for the altima SE R work on my car (aka as a performance upgrade? )
Old Mar 11, 2012 | 01:57 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
Maybe if you had an 04 dude. But there sre enough documented difference between the 04 plus 3.5 and the 02 03 3.5 to say it will probably require more considerations than a simple plug and play.
Old Mar 11, 2012 | 03:21 PM
02whitemaximase's Avatar
No and no, the ecu has much more to do than just the engine.
Old Mar 12, 2012 | 06:29 AM
MrEous's Avatar
^ Jeff™
Old Mar 12, 2012 | 01:19 PM
Shinjiduo's Avatar
+1 on that. In fact you minus well start think in terms of changing the whole wire harness if you change the ECU to thatk of a different engine and model. It would probably be easier than all the splicing you would have to do to get it to work with your current car properly. Not to mention it would probably never work properly with your current car you could get it close but there would always be some sort of bug to work out.
Old Mar 12, 2012 | 02:19 PM
spock's Avatar
Different animals. If you want more performance and sound from your Infiniti, buy some bolt-ons. Y-pipe, (or headers), catback, intake, intake spacers, etc.
Or, buy an 06 SER.
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
RinconI30
Nov 10, 2015 10:55 PM
Hdnseek
Sep 9, 2015 05:55 AM
