transmission over heats
Old Apr 17, 2012 | 01:31 PM
somiter's Avatar
i have a 03 maxima that overheats any time i drive it. it happens more offten when the outside temperature is over 70F degrees or if i have the heater on. When it over heats, the transmission slips no matter what gear its in. i shut off the engine wait for about 10 minutes, start driving again. at this point everything seems normal untill it over heats again. no dtc...radiator was replace with the tranny fluid two weeks ago..
i appriciate any helpful comment.
Thank you
Old Apr 17, 2012 | 01:36 PM
CustomLowz's Avatar
Thank you
have you checked your transmission fluid? Is it low? Does it smell burnt? When was it last replaced? Any other info?
Old Apr 17, 2012 | 02:09 PM
TallTom's Avatar
Have you checked the radiator fluid level? The transmission lines run through it.
Old Apr 17, 2012 | 05:35 PM
piggylover1985's Avatar
Check the transmission fluid, make sure it's full and not smell burnt. But it sounds like the filter is clogged up with crap, meaning the transmission/ converter might be coming apart. You can try drop the pan and inspect for debris.
tarun900
19
Dec 20, 2021 06:57 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Pied
Sep 26, 2015 03:29 PM
