Code PO335 CPS and P0725 help.
Old Apr 20, 2012 | 02:36 PM
piggylover1985's Avatar
Hi, after i did an engine swapped, 06 Max motor into an 03 automatic, everything sounds good, but it took a long time cranking for it to starts. Charging system and battery is good. also i have no tachometer and no odometer, It threw have 2 codes, 1 is a P0335 Crank Position Sensor A circuit and the other is P0725 Engine speed input circuit. I think both codes are related some how. Need help from you guys.
I cleared the codes and they came back right away, i swapped out both used cam sensors and another crank sensor and still same problem. Checked the voltage from crank sensor wire, i have battery voltage, which is good. Checked the ground wire by the crank sensor, no good ground so i think it has a bad ground, but when i jumped the ground wire going to the CPS to the chasis ground it still cranks for a long time, wth ? I check for engine ground also. there are 2 ground on top timing cover hold on by 10mm bolt, 1 in front of timing cover above alternator hold on by a bracket. 1 ground goes to the back cover of the transmission, and 1 big one from battery terminal to engine block. I think that's all the ground that i took out to remove the engine and transmission. I missed anything ?
Old Apr 24, 2012 | 05:43 PM
I found the problem, during re-installation of the engine, somehow i plugged the O2 connector into the crank sensor harness, both of them are green in color and the same plug, so after i switched the plugs around it still doing the same thing, took along time to start and no tach. I went and bought and brand new crank sensor, put it in and still the same thing, what the heck ? Everything checked out good ? Found out the new crank sensor is defective, i took it back and get another one, put it in and it cranks right up every time now, and the tach is functioning as it should. Thanks for reading guys.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
