Help!!! Service Engine Light on after CAI Install--------------
Old Jan 4, 2002 | 03:38 PM
MaxTuner's Avatar
After I put on the PR CAI last week, the engine light has come on twice already. The first time, I disconnected the battery for an hour, then it was fine for one day, today the engine light came back on again. What can I do ???
Old Jan 4, 2002 | 04:17 PM
MaxTuner's Avatar
Re: Help!!! Service Engine Light on after CAI Install--------------
help
Old Jan 4, 2002 | 05:10 PM
UMD_MaxSE's Avatar
Got Bent?
is MAF sensor plugged in nice and tight? Also, try unplugging battery overnight rather than just one hour.
Old Jan 4, 2002 | 08:46 PM
victor's Avatar
Re: Re: Help!!! Service Engine Light on after CAI Install--------------
help
sorry i can't help but i want to know too, just in case i have the problem.
and uhm, can i see your modified front splitters??
Old Jan 4, 2002 | 10:00 PM
ispeed's Avatar
may be a stupid question, but have you checked and rechecked all the connections??? I only ask b/c I got the check engine light as well, but I had left a tiny plug unconnected and that was throwing my light on. On a side night, my car never shifted better when I forgot to plug that thing in ... ahhh, I need VB recal!
Seriously ... check all the connections, and if they are all tight and sound, unhook the battery overnight. Light comes back on, you have a problem. Take it somewhere you can have it connected to a scan tool to extract the trouble code.
Old Jan 5, 2002 | 01:42 AM
MaxTuner's Avatar
I am trying that tonight, oh how about going back to the dealer and have it reprogram the ECU???If disconnected it overnight thing doesn't work???
I heard you have to go back to the dealer to have the ECU reprogrammed it because Nissan has back up memory???
Old Jan 5, 2002 | 06:24 AM
UMD_MaxSE's Avatar
Got Bent?
sounds like you unhooked the tranny dropping resistor that sits on the strut tower.
Old Jan 5, 2002 | 09:04 AM
Foglght's Avatar
Re: Re: Re: Help!!! Service Engine Light on after CAI Install--------------
Here in lies the problem. My experience with dealers is that since you have modified it, they will not work on it. I'm out of warranty and they still won't work on it. I have the same problem with the MIL. I am getting a MAF code popping up. I am not totally sure what the problem is yet, but im narrowing it down to vaccuum lines being the wrong size. My induction is custom though, not through stillen or anybody else.
damn my car sounds ****ed off under WOT!
Old Jan 5, 2002 | 09:09 AM
ispeed's Avatar
we have a winner!
Old Jan 7, 2002 | 12:15 AM
MaxTuner's Avatar
Re: Re: Re: Re: Help!!! Service Engine Light on after CAI Install--------------
we have a winner!
Anyone knows how to reset the ECU?
Old Jan 7, 2002 | 04:23 AM
PCGuRu2K's Avatar
Re: Re: Re: Re: Re: Help!!! Service Engine Light on after CAI Install--------------
On a 5th Gen you can't reset the ECU like the 4th Gen's with a turn of a screw. It need to be done with one of those analyzer's. They hook it to you computer, grab the ECU Error code and then reset it.
I had the same prob your having after my Cai install. I got a "O2 in Bank1 is running lean". I had them reset it but it still came back. I'm waiting on my O2 sensors from DaveB..
Old Jan 7, 2002 | 04:54 AM
UMD_MaxSE's Avatar
Got Bent?
the only 'real' way is with a scan tool: www.obd-2.com
Old Jan 7, 2002 | 10:55 AM
MaxTuner's Avatar
Re: Re: Re: Re: Re: Re: Help!!! Service Engine Light on after CAI Install--------------
Yeah, after i got my error code scanned, that is what the mechanic told me, the front bank O2 sensor is messed up!!!
how much is it from DaveB??cuz a new one from Nissan is about $300 bucks???? Is that right?
Old Jan 7, 2002 | 11:57 AM
PCGuRu2K's Avatar
Re: Re: Re: Re: Re: Re: Re: Help!!! Service Engine Light on after CAI Install--------------
There are 2 Bank1 O2 sensor. Make sure you know which one is bad.. It was like $181 for one of them, and $89 for the other... I think..
Old Jan 7, 2002 | 12:31 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hmmmmmm....... so many bank 2 sensor 1 errors.
Did you know that Swirl Valve Controller DTC number is same as the generic Bank 2 Sensor 1 number? Something like 1130.
Maybe you didn't hook up one of your vacuum lines correctly (meaning it could be pinched).
Or maybe I don't know what I'm talking about and talking out of my other end. Not like I've experienced this or anything.
Old Jan 7, 2002 | 12:33 PM
Y2KevSE's Avatar
One more thing, don't buy the O2 sensor until you grab the DTC number and compare it to a service manual.
Old Jan 9, 2002 | 10:35 AM
MaxTuner's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Help!!! Service Engine Light on after CAI Install--------------
HUH? 2 O2 sensors??? Are you Cali Emission or Fed emission? I only have like 2 sensors in front of front exhaust manifold. Mine is Fed Emission tho!!!
BTW, since they cleared the code, it has not come back on..should I replace it anyway???
Old Jan 9, 2002 | 10:54 AM
PCGuRu2K's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Help!!! Service Engine Light on after CAI Install--------------
No don't replace it.. The code I got with the scanner said that my 02 sensor in bank 1 was running lean. That usually means that the sensor is going bad.. I got a Cali.. 5thGen
Old Jan 9, 2002 | 11:05 AM
MaxTuner's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Help!!! Service Engine Light on after CAI Install-----------
That's what I was thinking, I am still waiting to see if the engine light will come back on
Anyway, I will keep on eyes on it, thanks guys!!
Old Jan 9, 2002 | 01:41 PM
Foglght's Avatar
ok ok ok....As another person has said, "I had them reset the computer, but the same code came back." Did you fix the problem? Cause the DTC codes will keep coming up if you don't fix it. Depending on your year and emissions, you have a bank one and two o2 sensor. These are called "upstream egos". The other(s), is called a "downstream" or cat monitor. We call these HEGOS. The downstream sensor only monitors the catylitic converter operation, and does not run on a switching voltage. The upstreams on the other hand "switch" in voltage. These upstream o2 sensors relay to the pcm how much o2 is in the exhaust, thus determining how rich or lean the car is running. If you are getting a bank 1 lean and not bank 2, it is probably just the upstream bank 1 oxygen sensor. If you had both banks running that way, it could be both sensors, or an itake leak. There can be other problems than the two I just mentioned, but you are getting into high performance, or other than stock. Scanners are great tools, but the code you get does not necessarily mean that is what's wrong with the car. That is why the mechanics can charge so much because they know all about the diagnosis process.
Think about this. Have any of you that have the CAI installed or any other devices besides a supercharger, that let more air into the throttle body? Did you ever notice that once in a while the exhaust pops, like its running rich? What happens is the computer is using the same amount of fuel for a starting point. The o2's send a reading that the car is running lean. At that point the computer compensates for that adding fuel, so you get a slightly rich run, especially under WOT. My max dips down into the mid 11's for A/F ratio on the dyno under WOT. If i could just raise it up to another point I would be making probably about 10 more hp.
anyway
I'm bored now
cya
ryan
Old Jan 9, 2002 | 01:49 PM
PCGuRu2K's Avatar
anyway
I'm bored now
cya
ryan
So since I'm only getting the error on Bank1, it does sound like a bad O2 right?
Old Jan 9, 2002 | 04:08 PM
kafene's Avatar
u may have to live w/ it as some of us others have. when i put in my stillen y-pipe, my engine light went on. i had exhaust also. after the car was checked, the mechanic told me it was because i had no precat (computer was giving some kind of exhaust error). he said he reset it, but would come back on. eventually it did go off permantly, BUT came back on when i put in the stillen hi-flow intake. it goes off and on now..
i'm sure you don't have this issue w/ a CAI, but i have this sensor that doesn't plug into anything (i believe it was the air temp sensor that was part of the stock airbox), but since i removed all parts of the stock airbox, i have it zip tied to another cable in the engine bay. if anyone else knows different, please post.
kafene.
Old Jan 10, 2002 | 02:59 AM
PCGuRu2K's Avatar
kafene.
You should be plugging that Air Temp sensor directly to the whole in the tube of the Cai...
Old Jan 10, 2002 | 07:34 AM
kafene's Avatar
i never said i had a CAI ... i said i have a stillen hi-flow (cone intake)
kafene.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
