camshaft sensor Relarn? Car Dead!!
Old May 22, 2012 | 05:34 PM
blackmax42's Avatar
Oh man! help please! Replaced front camshaft sensor - due to hard starting
now will not turn starter. Sounds like starter is locked!?!
Slight whirring from maybe starter? Is there a relearn or something
Old May 22, 2012 | 06:01 PM
Froggmann's Avatar
Unrelated. Sounds like the starter pinion is messed up in some way. Either your missing teeth on the flexplate, have a shattered pinion, the pinion spring is broken or the teeth have been stripped off the pinion.
In all cases you need to pull the starter to investigate.
Old May 22, 2012 | 06:50 PM
blackmax42's Avatar
Thanks- after an hour I used the old hit the starter with a hammer trick just as a last ditch resort. It started. Same rough starting (cranking a few sec. then mercifully starting). What a relief. Perhaps it was the starter all along. Odd it happened after replacing the crankshaft position sensor (the one by the oil filter) Will replace starter tomorrow.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
wingnut2006
Aug 15, 2015 04:16 PM
