Car feels wobbly
Old Jun 27, 2012 | 11:39 AM
District's Avatar
Car feels wobbly
What do I do? Everywhere I drive it is wobbling...constantly...straight clear road it even wobbles a little.
Old Jun 27, 2012 | 11:43 AM
AznRyan's Avatar
Wheels aligned, tires balanced? All the lug nuts tightened?
Old Jun 27, 2012 | 11:52 AM
District's Avatar
Could it be the suspension?
Old Jun 27, 2012 | 11:53 AM
NmexMAX's Avatar
dot dot dot ...
Answer his question first.
Then do the obvious.
10 & 2, 6 & 12.
Old Jun 27, 2012 | 12:00 PM
EuroDriver's Avatar
I'm willing to bet it's worn suspension compontents - ball joints, control arms or endlinks. It would behoove you to take it to a shop & have it checked out. Usually not a problem but you never know when it might be a dangerous situation.
District's Avatar
10 & 2, 6 & 12.
How do I know if they are alligned and balanced?
What is 10 n 2 and 6 n 12?
Old Jun 27, 2012 | 12:06 PM
NmexMAX's Avatar
dot dot dot ...
Do you have your old alignment spec sheet?
Jack the car up at the front wheels, and try and wobble your wheel & tire assembly at the 10 o'clock and 2 o'clock positions, and then again at the 6 & 12 positions.
Old Jun 27, 2012 | 01:20 PM
clintb3astwood's Avatar
Are you hearing any funny sounds at all?
Old Jun 27, 2012 | 06:20 PM
gavin68's Avatar
I'm having the same issue! Make sure your tires are properly inflated.
Old Jun 27, 2012 | 08:04 PM
Chris Gregg's Avatar
Get Off My Lawn
I'm struggling with the description. What exactly is wobbling? The whole car, steering wheel, front end...?
Did it start all of a sudden or has something changed?
As indicated, without clarification some more info, not sure how to help. Could be suspension issue, ball joints, bad tire balance, busted belter in tire, warped rotor, bent rim, loose lug nuts, etc.
Old Jun 27, 2012 | 08:08 PM
chrome91's Avatar
lift the front up in the air and see if theres any play in the front wheels. otherwise as said it could be anything, might have a bad tire or rim, could be out of balance, etc. probably a tierod
Old Jun 28, 2012 | 04:04 PM
District's Avatar
Well, it started after my car was lifted at the mechanics shop when he changed the alternator.
When I am driving, and there is the slightest bump on the road, the car wobbles up and down....not rough...but like water, just BLA BLA BLA BLA BLA, up down up down, and isn't it rough, just powerful. So it feels like, all of the shock is going into the car, as it is wobling. The whole car is just wobling like a bish...it is so much, that it is disrupting my foot control, and my foot randomly presses the gas because of the wobling...so it is become a danger to driving.
I am worried as fk, because it started right after my visit to my mechanic...and he was messing around near the wheels...to take out the alternator...so I am wondering if he broke it on purpose so i go back to have this fixed tooo...
Any brahs in NYC know a good mechanic?
Old Jun 28, 2012 | 04:10 PM
AznRyan's Avatar
If it happened at the shop after they changed the alternator, that'd be the first place I stopped back at to have them check it out.
Be firm about it, without being an @ss. Let them know that it started wobbling after you got it back, and you feel unsafe driving it with it as it is.
Old Jun 28, 2012 | 05:55 PM
Get Off My Lawn
I'm imagining a blown strut. Perhaps after being extended that far then compressed again. Just adding another item to the list, but that really helps!
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
jhontelj
Aug 17, 2015 04:07 AM
MikesChevelle
Aug 14, 2015 12:31 PM
Trin1j23
Aug 12, 2015 08:31 PM
