how many FP gauges are needed in a 5th gen??
MAX2000JP wants me to post this question because he can't log on for some reason.
Anyway, since there are 2 FP regulators on a 5th gen, do that mean that there are 2 different fuel lines coming into the engine bay and that one would need 2 underhood FP gauges to monitor idle fuel pressure??? I'm assuming the split is after the fuel line enters the engine compartment, necessitating only 1 gauge.
Re: how many FP gauges are needed in a 5th gen??
the 2 on the 5th gen work together(one's primary and the other's secondary)
Re: Re: how many FP gauges are needed in a 5th gen??
Originally posted by N1sMO
When I took my intake manifold off, I could see that the fuel rail is continuous with a fuel pressure regulator at each end of the rail. Another word, the fuel rail is "U" shaped. There is 1 fuel line going into the engine and 1 return. The fuel line going in is the one feeding the front fuel pressure regulator. To install a gauge, you would tap into the fuel line before the front fuel pressure regulator. Hoon, if this info is wrong, please correct me.
Which is more important, the fuel pressure that's going into the engine...or that's coming out?
Re: Re: Re: how many FP gauges are needed in a 5th gen??
Originally posted by Driven EF9
Look at it this way...
In any case, I'm going to upgrade to the Walbro pump soon! Car is detonating when under stress and it is not the coils.
Re: Re: Re: Re: how many FP gauges are needed in a 5th gen??
I don't understand how fuel pressure regulators work. Do they raise the pressure before or after the regulators? If it raises the pressure after, then why would they need a regulator on the return line?
Why does it have it on the return line? This is just assumption, but, the one before the fuel goes into the rail is a FPRiser, the one exiting the fuel rail is a FPRegulator. The riser builds pressure, while the regulator opens and closes to maintain pressure in the fuel rail...but, this is just a guess.
Re: Re: Re: Re: Re: how many FP gauges are needed in a 5th gen??
We actually only have one FRP, the other is a dampner. The fuel comes from the pump and through the dampner (which acts merely to surpress fuel surges/spikes). Then the fuel moves into the main part of the fuel rail.
At the end of this fuel rail is the actual FPR, which works off of vacuum pressure, and has a return line. Fuel is being pumped by the pump and forced into the mail rail, and is trying to escape through the return line, but the pressure regulator is there to control how much can return. Everything that doesn't return is sent to the injectors. So, as the regulator is restricted, via vacuum pressure, it let's less fuel escape and more is forced into the injectors.
Moral of the story, only 1 FP gauge is needed.
Finkle
Sep 27, 2015 09:53 PM
TonyJr
Aug 20, 2015 12:14 AM
