Brake help???
Old Aug 3, 2012 | 03:31 PM
ill12will8's Avatar
Brake help???
Changed rotors and pads today and when took for a test notice the sound of something rubbing (like metal to metal) but can't pinpoint it. Any help?
Old Aug 3, 2012 | 04:04 PM
madmax17's Avatar
How loud is it? Because i know when i changed my brake pads and rotors i could hear a slight metal rubbing but only when I was driving next to a building or in a parking garage. It went away after about 200 miles. It just took some time for the brake pads to wear in.
Old Aug 3, 2012 | 04:32 PM
ill12will8's Avatar
Yea it's very light but annoying but thanks I'm sure that's prob what it is
Old Aug 3, 2012 | 04:42 PM
TunerMaxima3000's Avatar
Probably just the dust sheild. Pinpoint the wheel and pul lit off for inspection. Snug the lugnuts back down on the rotor after yo upull the wheel, this will put the rotor in it's normal position, at this point you can inspect the dust sheild clearance, and if necessary use a screwdriver or something to bend the sheild away a bit.
Old Aug 3, 2012 | 05:21 PM
ill12will8's Avatar
I checked it but it still makes the sound after I apply the brake but slowly disappears
Old Aug 3, 2012 | 05:25 PM
Grand_hustle17's Avatar
happens often when you change the rotors and pads, give it about a week or so and see if it stops
Old Aug 3, 2012 | 06:03 PM
Yeah try a burn in (google how to do this properly). Sometimes they go away, sometimes you need to add shims. Sometimes you need to grind the edge of the pad (light bevel)
theres a ton of things that can cause it, dust sheild is the most likely.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
