Multiple Missifre code
Old Aug 13, 2012 | 05:11 PM
Hillsboromax's Avatar
No leaks, air or otherwise anywhere else.. Will a tune up fix the stalling and sputtering?
Old Aug 13, 2012 | 05:24 PM
foodmanry's Avatar
Da Roller Coaster!
Post the engine codes so we can better assist you.
Old Aug 13, 2012 | 05:26 PM
stocked out max's Avatar
What code(s) is your car throwing?
Old Aug 13, 2012 | 05:29 PM
Amerikaner83's Avatar
if OP claims misfires, and judging by profile has a 2k max, what little money I have is betting on ignition coils But OTOH, stalling and sputtering could be MAF...
codes WOULD be nice...
Old Aug 13, 2012 | 06:17 PM
My bad fellas,damn kids...CODE: P0300
Old Aug 13, 2012 | 06:37 PM
so there's no specific cylinder associated with it...damn.
you mentioned stalling and sputtering...does the car rev past 3K?
Old Aug 13, 2012 | 06:44 PM
multiple cylinder misfire...hmm
Originally Posted by david100
Plz mention the car code then i can assist you in better way.
you asked this AFTER the code was already posted...
Old Aug 13, 2012 | 07:52 PM
steelcitymax's Avatar
I had this same code P0300 just about a month ago. I tried everything to fix it, compression test, leak down test, ignition coils, injectors....everything. As soon as I ripped off the exhaust, I found out that my rear precat was all messed up. The precat completely failed and debris blow back into two of my rear cyclinders, thus blowing my engine. After a new engine and install with gutted cats $1800.00, all cyclinders are firing now and the car is running like a beast. So if you get a chance, check out your precats, if thats not the problem, still have them gutted asap.
Old Aug 13, 2012 | 09:57 PM
Max_5gen's Avatar
When you say 'stalling' do you literally mean that engine dies completely or it's just idles rough? Any pattern on when this happens? Is it cold/warmed up/driving/sitting at stop sign? How often does this happen? How exactly did you check for leaks? What do you exactly mean by
I'm sorry but your very short and vague description can only get vague speculations in response.
I doubt any 'tune up' commonly offered everywhere is able to fix anything. They break things quite often instead, like damaging MAF in the attempt to 'clean' it. Modern cars don't need tune up, it's a marketing gimmick.
Old Aug 13, 2012 | 10:21 PM
Brl24's Avatar
I recently had this code, it was a vacuum leak in the intake manifold, but as stated above you need to elaborate on what "no air leaks" means and how you came to these conclusions. Also any work recently done to the car before the code appeared would be helpful. This can be a real sob of a code to figure out, so the more info you give the more you will get, and unless your a mechanic your gonna need the help
Old Aug 14, 2012 | 04:50 AM
When cold it won't idle past 1000 rpm til it warms up and even then sometimes it still stalls or idles real rough.. No leaks as in a mechanic came and checked it out,checked manifold,tightened the clamps on the intake and it stopped shaking,but still sputtered a lil.. He suggested that I do a tune up.. I think Ima let a shop tell me what they think before I start spending all this $$$...
Old Aug 14, 2012 | 10:22 AM
Grand_hustle17's Avatar
p0300 can be numerous things, i've had a p0300 code for bad o2 sensor wiring and again for MAF wiring... check both, not sure if you have ever messed with ur o2 sensors before, if not try the other... my maf wire by the ecu was messed up
Old Aug 14, 2012 | 11:03 AM
dfj240's Avatar
I've been dealing with this problem for ages now.
http://forums.maxima.org/5th-generat...kets-help.html
^That's a link to my thread. I spent approximately $2k trying to solve the P0300 and poor running issue. I have figured it out however, and the cause of mine is clogged precats. Save yourself the money and time, and test everything before replacing anything. I didn't and it cost me.
Read through that thread though, there should be a TON of information to help you in the right direction. Also check my sig for a link to getting the factory service manual for the Maxima. The P0300 code will be under EC.pdf.
-Nathan
Old Aug 14, 2012 | 08:13 PM
Thanks for all da help fellas.. Im getting to it 2moro..
Old Aug 15, 2012 | 04:04 PM
DjHackStyle's Avatar
-Nathan
dude i read through your entire thread, im amazed at how determined you are, i would have drove the car off a cliff and certain points. i know you determined it was your precats but did you ever get to gut them yet and 100% prove that theory ?
Old Aug 16, 2012 | 06:24 AM
Got car checked.. Removed front coils and used Spark tester and a few other tests were done. After removing and replacing 3rd coil rough idling stopped. Was suggested that I replace da coils.. Still stalls when cold but no more rough idling.
Old Aug 16, 2012 | 08:06 AM
foodmanry's Avatar
Da Roller Coaster!
Did that take care of the P0300 code?
I wouldn't replace all the coils unless you got money to spend. The stalling while cold sounds like an issue unrelated to coils such as dirty throttle body, MAF going out, idle air problem, etc.
Old Aug 16, 2012 | 09:06 AM
All codes cleared,light came back on after car sat while @ work.. Will have it all checked again to c if the code has changed..
TKHanson
Nov 24, 2018 01:39 AM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
