Quick question for replacing window switch?
Old Sep 15, 2012 | 09:41 PM
gavin68's Avatar
I'm in the process of LEDing my window switches in my 2000 GLE. But, I messed up pretty bad on this first one. Fortunately it's only the rear drive side one. I tried soldering it back together, but I'm no good at that either...
So I'm going to give up on this one and order a replacement from www.nissanpartsasap.com. But, what part exactly should I be looking for? Here's what I'm seeing:
I think this is the part I need, but I'd like to confirm this with you guys. I need this to replace the rear driver side switch. I assume the back seat ones are interchangable (I already did the passenger side with success and no mess).
So, is this part (25750M) what I need? Thanks in advance.
Old Sep 15, 2012 | 10:46 PM
DennisMik's Avatar
Yes, that is the part you want. It is used in the 2 rear doors and the passenger front.
Old Sep 15, 2012 | 10:47 PM
Amerikaner83's Avatar
Holy fcukballs, batman!
Old Sep 15, 2012 | 11:11 PM
gavin68's Avatar
Thank you sir. I'm ordering now
And I think I'll stay away from the soldering iron until I learn how to do it right ... or at least how not to make a mess of it.
Old Sep 15, 2012 | 11:15 PM
lol Soldering just takes practice, that's all
If you want to change your interior LEDs, let me know
Old Sep 16, 2012 | 12:50 PM
DennisMik's Avatar
One of the secrets of soldering is to have the proper amount of heat. For soldering small wires and the LED leads, you should have a 12 to 15 watt soldering iron. Too hihigh a wattage iron means too much heat which melts connectoer and burns up components.
Old Sep 16, 2012 | 02:48 PM
gavin68's Avatar
I've been doing this on my spare time and only have 1 done so far (not counting that soldered mess).
Instead of soldering, I took out the original LED and just added in a new one and a new resistor. Works perfectly with no issues. So, I'll probably do that for the other ones. It's the driver's side I'm dreading...
Old Sep 16, 2012 | 03:02 PM
TunerMaxima3000's Avatar
This.
Gavin, kudos for trying, might I suggest practise on something that isn't important?
You should be sanding down any components before you solder, specifically the copper contacts, they have a coating on them and won't solder well, or will require excessive (plastic melting) heat before they adhere because you're basically melting the coating off with the solder gun.
Just like welding, the adhesion/solder/weld is only as good as the prep work.
Clean components/mating surfaces are MANDATORY for this stuff.
Old Sep 16, 2012 | 05:16 PM
Originally Posted by tunermaxima3000
this.
Gavin, kudos for trying, might i suggest practise on something that isn't important?
Clean components/mating surfaces are mandatory for this stuff.
agreed 100%
Although, I wonder why you're doing it the hard way... you can re-use the little rubber part, bending the leads the same as the original LEDs in there. No soldering required on the leads aside from a tiny bit of a resistor to the positive LED leg.
Old Sep 16, 2012 | 07:44 PM
^That's true. But given that picture, well..... maybe just a touch beyond the capacity.
Old Sep 17, 2012 | 11:09 AM
gavin68's Avatar
This is easier.
Old Sep 17, 2012 | 11:12 AM
Originally Posted by gavin68
This is easier.
yes, yes it is So how did you do that without soldering the resistor to the LED leg, I wonder?
Old Sep 17, 2012 | 02:46 PM
Now ya got it Gavin
vingodine
45
May 21, 2016 12:46 PM
mpbclutch33
Aug 21, 2015 06:09 AM
shaunkey1
Aug 18, 2015 10:09 PM
classymax420
Aug 6, 2015 06:35 PM
kjm900r
Aug 5, 2015 07:14 AM
