2K1 SE 0-60 Times
Old Jan 8, 2002 | 10:55 AM
MaximaMan44's Avatar
2K1 SE 0-60 Times
What is the best 0-60 time that you have gotten on a stock 2K1 Maxima SE? Thanks
Old Jan 8, 2002 | 02:58 PM
RastaManMax's Avatar
I've seen someone with light mods claiming a 6.1, (not to say that was proven, just saying what i saw), but there's plenty more faster ones
Old Jan 8, 2002 | 03:04 PM
Trev_Daddy's Avatar
Re: 2K1 SE 0-60 Times
Stick or Auto?
Old Jan 8, 2002 | 03:23 PM
Y2KMaxGXE-R's Avatar
I highly doubt that a lightly-modded 2k1 5 spd will do 6.1 sec. Automatics-forget that!
Old Jan 8, 2002 | 03:40 PM
Amazing2's Avatar
Hi MaximaMan44,
I just got myself an AE 2001 5 speed and I'm also wondering about the 0-60.
I think it's around 7 sec for the 5 speed.
Any 2k1 5spd owner want to share there times?
BlackAE's Avatar
So far, with my G-tech pro, the best I've done is an 8.2sec And that was with OD off, torque-braking and manual shifting! Don't ask.
Old Jan 8, 2002 | 03:43 PM
Trev_Daddy's Avatar
Re: Re: 2K1 SE 0-60 Times
Hmm...I thought I saw Motortrend's test and if I recall, it was around 6.7 seconds with a manual...I could be wrong, though...
Originally posted by Amazing2
Hi MaximaMan44,
Old Jan 8, 2002 | 03:46 PM
Amazing2's Avatar
Re: Re: Re: 2K1 SE 0-60 Times
Trev,
I've seen those numbers but I think that "real life" is different than those mag numbers. BUT I also could be wrong!
Old Jan 8, 2002 | 03:51 PM
Trev_Daddy's Avatar
Re: Re: Re: Re: 2K1 SE 0-60 Times
No, you're probably right....Those are "perfect" test conditions, i.e. wind is right, track is perfect...My bad! Ooops....
Trev,
Old Jan 8, 2002 | 03:52 PM
MichaelAE's Avatar
I could be wrong too.
Old Jan 8, 2002 | 03:56 PM
jkratzer's Avatar
You have an auto obviously. Manuals don't have an OD off switch and you don't need to torque brake. I've seen 7.7 secs for 2K1 autos and 6.7 secs for 2K1 manuals listed in Motor Trend.
Old Jan 8, 2002 | 04:24 PM
Sorry for the confusion guys, but it is a 5 speed. Thanks
Old Jan 8, 2002 | 10:17 PM
DOHC 30 V6
Did someone say the difference between stick and auto was a whole second?? PLEASEEEEEE..... the differences are marginal at best, like, .2 or .3 quicker. That doesnt make it worth it for me to brave a manual in thick nyc traffic - manuals really arent as fast as all you who row your own gears think... my .02
Old Jan 9, 2002 | 06:07 AM
jkratzer's Avatar
Check the numbers in any magazine or here on the org. Manuals are much faster than autos.
Old Jan 9, 2002 | 06:38 AM
maxse01's Avatar
I got a 6.1 with nobody in the car, tire psi at 14 and no gas in it on a 45 degree day.
Old Jan 9, 2002 | 09:18 AM
carguyrob's Avatar
I would say the 0-60 times on a 5 speed would be right about 6.7 seconds. I have raced a number of TL-S' and always won, but just by 1/2 a car length or so. They are rated at right about 6.7 seconds. My car is totally stock.
BTW, the difference between a stick and auto trans is always more than .2 or .3 unless you are driving a 540i auto or a Porsche. Those German autos are very aggressive and can hold their own with a manual. Most autos are rated at about a second slower than a manual. Remember, the auto is less efficient and weights more.
Just my .02.
Old Jan 9, 2002 | 10:04 AM
Trev_Daddy's Avatar
In every test I've seen with a Maxima, the manual is quicker-By much more than .2 or .3 seconds....It's not just about how quick you can shift; usually they are geared better for accelerating and you are also able to hold a gear longer than an auto...Just my .002 (for what it's worth )
But I can certainly appreciate your point about heavy traffic...An auto would be better.
Old Jan 9, 2002 | 10:10 AM
NmexMAX's Avatar
dot dot dot ...
4Th gen auto can hold a gear til 6.5K but is still slower
Old Jan 9, 2002 | 10:18 AM
Trev_Daddy's Avatar
What do you think of your auto? Does it perform well?
Old Jan 9, 2002 | 11:49 AM
Burton069's Avatar
I got 7.89, so the Max's should do better than that since they are lighter (intake don't do ****)
Old Jan 9, 2002 | 07:34 PM
well as I said, it is hard to believe that a totally stock 5th gen will achieve 6.1sec so stop b.s.'ng us. Your signature says "mods too many to list". What mods did you have at that time, and how did you measure your results?
My 2k GXE 5spd loaded with a passenger and a heavy bass box hit it in 6.8 sec, dont know about pressure, and it was around 45 degrees, too. 6.1sec is a very good result.
To those driving automagics and still in denial that manual Maxima is MUCH faster than auto, need to have a reality check.
Old Jan 9, 2002 | 08:46 PM
NickE39's Avatar
Times of the 2k automatics are as follows:
0-60 7.8-8.1
1/4 mile 15.9-16.1
The same would apply for 2k1's. These are magazine times. Motortrend DID test a 2k 5speed and did 6.7 seconds, BUT it was a preproduction model. In other test from different magazines, most have got'n 0-60 in 7.0 seconds. Some might argue with me on that and say "well I got this and this time" I don't really care, you're just a better driver than they are.
Old Jan 9, 2002 | 08:58 PM
Trev_Daddy's Avatar
Where did you get the numbers for the autos? I have not seen these in magazines-Only manual times...
0-60 7.8-8.1
1/4 mile 15.9-16.1
Old Jan 9, 2002 | 09:10 PM
WILLSE's Avatar
0-60 7.8-8.1
1/4 mile 15.9-16.1
HA i believe it!!!i have a 2k1 auto and i have driven my friends 2k 5 speed BIG DIFFERENCE..... i am an auto guy that knows his place in the food chain..... a 5 speed stock will walk all over me.... its not just rowing your own gears faster its less of a driveterrain loss thus resulting in more HP to the ground.... launchs are another area where a 5speed will KILL an auto... no replacing a 5 speed!!! I might be able to build a faster auto but it will never be as much fun to drive thats y i am going to buy a 2k2 6 speed..... look at my mods and see that my car isnt slow..... just tired of the car driving itself! i want to have control of what i do how i do it and when i do it!!
Old Jan 9, 2002 | 09:12 PM
2001SE's Avatar
People here you should know that the Auto Gear Box on the 2000 and 2001 Maxima ....sucks moth* fuc*** as*. There is more then a whole sec sometimes, and its so stupid. There is nothing more to say but a manual can dust an auto maxima with no problem at all. It much more faster and fun to drive but again in traffic it sucks. Performence wise they 5sp are much more better and worth the money. the 2k2 ones are awosome. you can get around 6.5 easily, i heard its a really good tranny
Old Jan 9, 2002 | 09:25 PM
Tony Fernandes's Avatar
No one has asked this question yet, so I thought I would. How much would a VB calibration bridge the gap between the auto vs. manual? I would consider this as an option only if the gains were large enough and if the whole process was trouble-free. I wouldn't want to do something to my car that affected its reliability and resale value.
Tony
Old Jan 10, 2002 | 05:06 AM
MichaelAE's Avatar
Maybe its better said...the manual has the potential to be a second, if not more than one second, faster than an automatic. The performance of a manual is far more reliant on the performance of the driver than in an automatic. However, I think you are fooling yourself if you don't believe the potential is there.
Old Jan 10, 2002 | 05:21 AM
Blackgums100's Avatar
I think Y2KevSE
Tony
Did the VB mod, maybe he did some before and after testing. From what I have read it seems to be a must have mod if you have an auto. The only drawback is I think it voids your warranty, and tranny work can get very expensive. Then again with all the mods Y2KevSE has the only thing left on his ride still covered under warranty is probably Nissan's paint.
Old Jan 10, 2002 | 10:00 AM
sleepur's Avatar
1/4 mile for my 2001 SE automagic was 15.6, on a chilly night around 45 degrees. I think i read somewhere that the VB mod would get you about .3 sec on your 1/4 mile, but i could be wrong. It would definitely help bridge the gap, but you still have a greater drivetrain loss with the auto.
Quit picking on the auto's> I like mine, sure its no 5-spd, but it is still a MAX!!
Old Jan 10, 2002 | 10:43 AM
mzmtg's Avatar
Minister of Silly Walks
See my sig...
...a 5th gen 5spd should be able to blow me away, so, you do the math...
Old Jan 10, 2002 | 12:44 PM
Max_Gator's Avatar
Hard to measure 0-60 times but I'd bet stock 5spds easily do the 6.7 reported in the mags (with a decent driver). When I got my 2k - first time at the track I ran a 15.2. That's right at the magazine reported time so I presume my 0-60 was as well. Ultimately got it to best of 14.7x with y and intake in pretty cool weather (and I still needed a lot of practice launching).
With Y and intake, I'd say you can chop off a few tenths and would be around mid to low 6s.
Old Jan 10, 2002 | 12:59 PM
this post is about love for 5speeds, so if I can ask automagic drivers to get your sorry behinds and start your own thread. Too much stuff no one needs on the performance of 5th gen autos.
Old Jan 10, 2002 | 01:33 PM
Trev_Daddy's Avatar
Werd. And they're slower, so that's all there is to it.
Old Jan 10, 2002 | 02:56 PM
jkratzer's Avatar
No love for autos I guess.
Old Jan 10, 2002 | 04:41 PM
nc00max
Blow me and my auto. Automatics are Maximas too, and people buy their cars with the options they have for different reasons. Mine was $4k less for a new 2K auto than a new 2k1 5spd. My car is slower than every 5spd out there, but I don't think that makes it inferior in any way. Hop off your high horse and have some respect for your fellow Maxima owners.
Old Jan 10, 2002 | 05:06 PM
2Maxed-out4u's Avatar
People buy Auto maximas because it's more convenient and easier. When you have to drive a lot or want to relax, the auto is your best friend. 95% of the maximas out there are auto. That should tell you something, most people like to enjoy the ride w/0 having to shift in between. Also, the automatic version of the car is 2k more expensive than the 5 speed. So, don't clown on the auto because people have reason to spend 2k more on autos. (no flame intended.) Just representing the Maximas.
P.S. If I wanted a car to race in, I'd buy a 98 supra and trick it out.
Old Jan 10, 2002 | 05:16 PM
costcowholesale's Avatar
Old Jan 10, 2002 | 05:38 PM
Loe max's Avatar
Read the first post, they guy just asked for stock times. No mentioning of auto's or manual's.
Old Jan 10, 2002 | 06:13 PM
Craig Mack's Avatar
All YOUR grammer belong to me
'95 Auto maxima's do 0-60 stock in 7.3-7.6 And we have no rev limiter and are light on our feet
Old Jan 10, 2002 | 06:25 PM
Loe max's Avatar
I know, My 2k is slower than the 95 Max
