Full throttle hesitation?
Old Oct 11, 2012 | 09:10 PM
flying phil's Avatar
If steady throttle at 3500 RPM then 'floor it' in 3rd, 4th, or 5th, there is a hesitation that never really clears until releasing throttle part way. If 'flooring it' from 2000 RPM or less, problem is not apparent throughout. Any thoughts as too what the problem is?
Old Oct 12, 2012 | 06:09 AM
louied9's Avatar
replace the MAF !!! Trust me its worth the 40-50 buck! I just did and instant Gratification!!! i had the same problem, read the forums for days and everyone point to the MAF as your 1st replacement. don't waste your time cleaning it with the MAF spray..
http://stores.ebay.com/Fuel-Injectio...=p4634.c0.m322
dont wait and keep searching, just do it.
Old Apr 25, 2013 | 02:55 PM
Here goes
I'll try it!!!!
Old Apr 25, 2013 | 03:27 PM
SSJRICH's Avatar
Yea, I would do a bit of research before listening to the first person...
there are a few good threads with a little bit of searching...
There are a few common problems people have had with the same issue and different results. Although it maybe your MAF, it could be your coils, or even a fuel supply problem...
As much as you like to have a quick and easy answer to your problem... There have been countless people on countless forums that have dumped hundreds and even thousands on people opinions without a proper diagnostics.
Do youself a favor and use that search feature and do a little bit of reading before you go out and spend the dough...
Good Luck
Old Apr 25, 2013 | 05:06 PM
theblackone3.5's Avatar
If you are going to buy a MAF, don't be cheap and get an OEM MAF. It will save you in the long run.
Old Apr 25, 2013 | 06:14 PM
JWatZ's Avatar
Original question: 10/12/12
Original answer: same day
Response to the answer six months later???
Better late than never I guess...
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
Socalstillen
Sep 26, 2015 12:01 PM
